IJC/OPM How do you lighten a profile
2005-02-03 by bwbonkers
I have a profile which is linerized but is printing too dark. If I print using this profile in OPM and adjust exposure to lighten by 15 units, I get a good print match with calibrated monitor. What I would like to do is lighten this profile so I require no adjustments in OPM. Peter
2005-02-03 by Nick H. Nugent
Hi Peter, Is the vertical slider in the linearization tab at 0 to start with? This slider adjusts the Aim curve to lightten or darken your profile. Adjust this slider then save the profile (using a different name) and see if it makes a difference. Up=brighter. --nick --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bwbonkers" <PeterDLevis@a...> wrote:
> > I have a profile which is linerized but is printing too dark. If I > print using this profile in OPM and adjust exposure to lighten by > 15 units, I get a good print match with calibrated monitor. What I > would like to do is lighten this profile so I require no > adjustments in OPM. > > Peter
Nick Yes the vertical slider is set to 0. With my setup moving the slider down to -6 has lighten the print. I now have a green aims curve below the red readings straight line. Would I now need to relinearize? Peter --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Nick H. Nugent" <nghin@p...> wrote: > > Hi Peter, > > Is the vertical slider in the linearization tab at 0 to start with? > This slider adjusts the Aim curve to lightten or darken your profile. > Adjust this slider then save the profile (using a different name) and > see if it makes a difference. Up=brighter. > > --nick > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bwbonkers" > <PeterDLevis@a...> wrote: > > > > I have a profile which is linerized but is printing too dark. If I > > print using this profile in OPM and adjust exposure to lighten by > > 15 units, I get a good print match with calibrated monitor. What I
> > would like to do is lighten this profile so I require no > > adjustments in OPM. > > > > Peter
2005-02-03 by Joe Berndt
Hello Peter, If your reading in density values, a ( - 6 ) would be typical. With Density readings the idea is to set your step 13 in the AIM to about .63 - .69 range. The ³green² line is the ideal plot calculated from your paper white to your D-Max ( the DR range). The ³red² line is your actual read in values. IJC, will adjust your profile to conform to the new AIM line. Joe Berndt On 2/3/05 1:48 PM, "bwbonkers" <PeterDLevis@aol.com> wrote: > Nick > Yes the vertical slider is set to 0. With my setup moving the slider > down to -6 has lighten the print. I now have a green aims curve below > the red readings straight line. Would I now need to relinearize? > > Peter > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Nick H. Nugent" > <nghin@p...> wrote: >> > >> > Hi Peter, >> > >> > Is the vertical slider in the linearization tab at 0 to start with? >> > This slider adjusts the Aim curve to lightten or darken your > profile. >> > Adjust this slider then save the profile (using a different name) > and >> > see if it makes a difference. Up=brighter. >> > >> > --nick >> > >> > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bwbonkers" >> > <PeterDLevis@a...> wrote: >>> > > >>> > > I have a profile which is linerized but is printing too dark. If > I >>> > > print using this profile in OPM and adjust exposure to lighten by >>> > > 15 units, I get a good print match with calibrated monitor. What > I >>> > > would like to do is lighten this profile so I require no >>> > > adjustments in OPM. >>> > > >>> > > Peter [Non-text portions of this message have been removed]
Hi Joe Unfortunately I'm not reading in density values but instead using L values. With the aims slider set to 0 I get a nice straight line match between aims and readings. However this prints too dark. If I set the aims to -4, step 13 remaps from 50 to 40 and the aims straight line becomes a curve. The test image now prints lighter and is a better match with the monitor. However is this good practise? How would you lighten a perfectly good profile ? Peter. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Joe Berndt <joeberndt@v...> wrote: > Hello Peter, > > If your reading in density values, a ( - 6 ) would be typical. With Density > readings the idea is to set your step 13 in the AIM to about .63 - .69 > range. The ³green² line is the ideal plot calculated from your paper > white to your D-Max ( the DR range). The ³red² line is your actual read in > values. IJC, will adjust your profile to conform to the new AIM line. > > Joe Berndt > > On 2/3/05 1:48 PM, "bwbonkers" <PeterDLevis@a...> wrote: > > > Nick > > Yes the vertical slider is set to 0. With my setup moving the slider > > down to -6 has lighten the print. I now have a green aims curve below > > the red readings straight line. Would I now need to relinearize? > > > > Peter > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Nick H. Nugent" > > <nghin@p...> wrote: > >> > > >> > Hi Peter, > >> > > >> > Is the vertical slider in the linearization tab at 0 to start with? > >> > This slider adjusts the Aim curve to lightten or darken your > > profile. > >> > Adjust this slider then save the profile (using a different name) > > and > >> > see if it makes a difference. Up=brighter. > >> > > >> > --nick > >> > > >> > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bwbonkers" > >> > <PeterDLevis@a...> wrote: > >>> > > > >>> > > I have a profile which is linerized but is printing too dark. If > > I > >>> > > print using this profile in OPM and adjust exposure to lighten by > >>> > > 15 units, I get a good print match with calibrated monitor. What
> > I > >>> > > would like to do is lighten this profile so I require no > >>> > > adjustments in OPM. > >>> > > > >>> > > Peter > > > > > [Non-text portions of this message have been removed]
2005-02-03 by Nghi Nguyen
Hi Peter, I'm sorry I told you the opposite of what you should have done to lighten the profile. In my case 0 is just right so I assumed the slider behavior without looking at the aim values which actually get "darker" as you move the slider upward (isn't it kind of backward?). You can print the target with linearization for verification or if there is no blown out highlights in your image you should be fine. nick Message: 3 Date: Thu, 03 Feb 2005 22:32:12 -0000
From: "bwbonkers" Subject: Re: IJC/OPM How do you lighten a profile Hi Joe Unfortunately I'm not reading in density values but instead using L values. With the aims slider set to 0 I get a nice straight line match between aims and readings. However this prints too dark. If I set the aims to -4, step 13 remaps from 50 to 40 and the aims straight line becomes a curve. The test image now prints lighter and is a better match with the monitor. However is this good practise? Peter. [Non-text portions of this message have been removed]
2005-02-04 by Joe Berndt
Hello Peter, On L* values you would start with the slider at ( 0 ). This produces a linear response( straight line ). This gives you a standard baseline where each step is spread out with equal luminance. But as we know a linear response, won¹t always print the best pictures. So to control the overall density of the profile you would bring up or down the slider just as you are doing. Sometimes when I¹m printing I¹ll make a view profiles with different mid-tone settings, then I print the same image using those different profiles. I then find the profile that works best for the subject matter. Joe On 2/3/05 2:32 PM, "bwbonkers" <PeterDLevis@...> wrote: > > Hi Joe > > Unfortunately I'm not reading in density values but instead using L > values. With the aims slider set to 0 I get a nice straight line > match between aims and readings. However this prints too dark. If I > set the aims to -4, step 13 remaps from 50 to 40 and the aims > straight line becomes a curve. The test image now prints lighter and > is a better match with the monitor. However is this good practise? > > How would you lighten a perfectly good profile ? > > Peter. > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Joe Berndt > <joeberndt@v...> wrote: >> > Hello Peter, >> > >> > If your reading in density values, a ( - 6 ) would be typical. > With Density >> > readings the idea is to set your step 13 in the AIM to about .63 - > .69 >> > range. The ³green² line is the ideal plot calculated from your > paper >> > white to your D-Max ( the DR range). The ³red² line is your actual > read in >> > values. IJC, will adjust your profile to conform to the new AIM > line. >> > >> > Joe Berndt [Non-text portions of this message have been removed]
2005-02-04 by Nick H. Nugent
Peter, The digest came to me a little late and there have been several responses to your question. But just in case you haven't got this one figured out yet - which I think you did - the answer is no, there is no need to relinearize. However, maybe Joe or Lou or Antonis may want to jump in here, I think we can fine tune the profile by printing the target with linearization and read each patch and make correction, if any, to the linearization table. But I have never had to do this re- linearization step because I don't think it is necessary. As long as the test image comes out smooth with no bumps or flat spots. --nick --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bwbonkers" <PeterDLevis@a...> wrote:
> > Nick > Yes the vertical slider is set to 0. With my setup moving the > slider down to -6 has lighten the print. I now have a green aims > curve below the red readings straight line. Would I now need to > relinearize? > > Peter
2005-02-04 by bwbonkers
Hi Joe / nick Many thanks for your help. I think now I have a better understanding of what the aims slider does. To lighten my test print to match my monitor I have moved the aims down -4, which has remapped the L values, step 13 from 50 to 40. If I keep my original linear profile (aims set to 0) and print in OPM with the exposure slider set to lighten by 10 units, I get a very similiar print. This begs the question, is the exposure slider doing a similiar job as the aims slider. Hmm.... Peter. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Nick H. Nugent" <nghin@p...> wrote: > > Peter, > > The digest came to me a little late and there have been several > responses to your question. But just in case you haven't got this > one figured out yet - which I think you did - the answer is no, > there is no need to relinearize. > > However, maybe Joe or Lou or Antonis may want to jump in here, I > think we can fine tune the profile by printing the target with > linearization and read each patch and make correction, if any, to > the linearization table. But I have never had to do this re- > linearization step because I don't think it is necessary. As long as
> the test image comes out smooth with no bumps or flat spots. > > --nick > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bwbonkers" > <PeterDLevis@a...> wrote: > > > > Nick > > Yes the vertical slider is set to 0. With my setup moving the > > slider down to -6 has lighten the print. I now have a green aims > > curve below the red readings straight line. Would I now need to > > relinearize? > > > > Peter
2005-02-04 by ldina
Nick, That is my experience. If you want to lighten the midtones in your profile, just move the slider a few points in the minus direction. Your raw data is still plotted on the curve based on the L* or density units you originally entered (unless you click the clear button, in which case you would need to reenter the data). So, the green curve represents the absolute value and spacing between each of the 26 steps after IJC performs auto linearization. All you need to do is save your profile after moving the gamma slider and you will have a finished, linearized profile. Lou --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Nick H. Nugent" <nghin@p...> wrote: > > Peter, > > The digest came to me a little late and there have been several > responses to your question. But just in case you haven't got this > one figured out yet - which I think you did - the answer is no, > there is no need to relinearize. > > However, maybe Joe or Lou or Antonis may want to jump in here, I > think we can fine tune the profile by printing the target with > linearization and read each patch and make correction, if any, to > the linearization table. But I have never had to do this re- > linearization step because I don't think it is necessary. As long as
Hi Lou, Yes. The entered linearization data is fixed. It's the aim slider value that is stored in the profile that tells OPM how to adjust the output gamma. Peter has a question about the exposure slider which I haven't played with much at all. Does the OPM brightness slider work like the aim slider? I asked Joe Berndt about the possibility of adding a way to tweak the aim curve like a Photoshop curve. The OPM constrast slider gives me additional constrast but I like the characteristic of Paul Roark's curve for the 1160/FS/Mild-EEM combination. I will boost the OPM constrast curve and compare it with Paul's curve to see how close they are. But being able to tweak the aim curve will make it much easier to fine tune a profile for a particular type of image. --nick --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ldina" <lbdina@c...> wrote:
> > Nick, > > That is my experience. If you want to lighten the midtones in your > profile, just move the slider a few points in the minus direction. > Your raw data is still plotted on the curve based on the L* or > density units you originally entered (unless you click the clear > button, in which case you would need to reenter the data). So, the > green curve represents the absolute value and spacing between each > of the 26 steps after IJC performs auto linearization. All you > need to do is save your profile after moving the gamma slider and > you will have a finished, linearized profile. > > Lou
2005-02-04 by johndavidgill2003
There is a problem with the Brightness slider in OPM (Windows version 1.0) whereby the action is reversed. Joe Berndt is aware of this and a fix is due in the next version. - Have we a date for this yet Joe? -
2005-02-04 by ldina
Hi Nick. "Does the OPM brightness slider work like the aim slider?" The AIM slider in IJC applies a single point gamma adjustment to the linearization. So, if you move the slider to -2, for example, the midpoint of the scale will be made lighter. The white and black points are held constant. The adjustments are heaviest in the middle of the tone curve and become smaller and smaller as you move toward the end points. From my experimentation, it appears the contrast slider in OPM acts very much like an "S" curve in Photoshop. The end points appear to remain fixed. Moving the slider to the right increases contrast (ie, brightens the 1/4 tones and darkens the 3/4 tones). Moving the slider to the left lowers the contrast (darkens the 1/4 tones and lightens the 3/4 tones). I'm not 100% certain about the brightness slider in OPM, but visually it seems to hold the end points constant and brighten all the points in between, much like the gamma slider in IJC. I loaded the 26 step grayscale in OPM to experiment. I used a piece of cardboard to cover steps 1-25 on screen so only step 26 was visible. Moving the brightness slider from one extreme to the other showed no visible change in step 26, at least to my eye. I did the same with step 1 and saw no difference. Of course, steps 2-25 do change as you adjust the slider. I'm not sure if this works exactly the same as the gamma slider in IJC or not. We'd have to ask Joe Berndt to be absolutely certain. At present, IJC only allows a single point gamma adjustment with the slider. I'm not sure I would need or want more ~ I'd have to think about it some. I'd probably prefer to keep the profile simple and linear, then make any desired tonal adjustments in PS. If I have an accurate soft proof preview in PS and make my adjustments there, I have fewer variables to contend with and fewer ways to screw up my print. (Actually, you CAN build and save a non-linear profile in IJC if you wish and make any adjustments you want. You would set ink limits, adjust curves, etc, as always. Print a target for linearization and read with a densitometer or spectrophotometer, entering the data in the linearization window. Once you have a raw curve shape you like (based on your density readings), switch to the Ink Shapes tab and click the Save button. You will be prompted as to whether you want to save without linearization. If you say yes, IJC will skip the Auto linearization and let you save your raw data as the final profile. If using Save from the linearization tab, IJC always applies an auto-linearization to your raw data.) Regards, Lou --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Nick H. Nugent" <nghin@p...> wrote: > > Hi Lou, > > Yes. The entered linearization data is fixed. It's the aim slider > value that is stored in the profile that tells OPM how to adjust the > output gamma. > > Peter has a question about the exposure slider which I haven't played > with much at all. Does the OPM brightness slider work like the aim > slider? > > I asked Joe Berndt about the possibility of adding a way to tweak the > aim curve like a Photoshop curve. The OPM constrast slider gives me > additional constrast but I like the characteristic of Paul Roark's > curve for the 1160/FS/Mild-EEM combination. I will boost the OPM > constrast curve and compare it with Paul's curve to see how close > they are. But being able to tweak the aim curve will make it much > easier to fine tune a profile for a particular type of image. > > --nick > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ldina" > <lbdina@c...> wrote: > > > > Nick, > > > > That is my experience. If you want to lighten the midtones in your > > profile, just move the slider a few points in the minus direction. > > Your raw data is still plotted on the curve based on the L* or > > density units you originally entered (unless you click the clear > > button, in which case you would need to reenter the data). So, the > > green curve represents the absolute value and spacing between each
> > of the 26 steps after IJC performs auto linearization. All you > > need to do is save your profile after moving the gamma slider and > > you will have a finished, linearized profile. > > > > Lou
2005-02-04 by ldina
John, This has been fixed. Windows v1.0.3 is now available for download. Contact Bowhaus if you need the link. Your original user ID and password should work. Lou --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "johndavidgill2003" <jdgill@l...> wrote: > > There is a problem with the Brightness slider in OPM (Windows version > 1.0) whereby the action is reversed. Joe Berndt is aware of this and > a fix is due in the next version. > - Have we a date for this yet Joe? -
