If you're using Panther, there is another driver. A GIMP driver, which you don't want.
Select the Epson driver 'SC 1160(USB)', not 'StylusCOLOR 1160', and you'll see the familiar
options.
I use version 1.29e, which has been around for quite a while. It's named in the Summary
window when you print. Under Panther, there is a ColorSync window that I don't think was
present under Jaguar. I ignore it.
FYI, I learned this from the piezography list. Hope it helps.
Michael
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "lambonick"
<BMWNick@i...>
wrote:
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
<paul.roark@v...>
> wrote:
SNIP
> > >Why does the driver not show the usual Epson settings?
> > It sounds like this might be a driver that was included on the OS
disc. I'm
> > not a Mac user, but with XP the disc has lots of drivers for
printers, but
> > they are not the same as the full Epson drivers. You need the
full driver
> > from Epson.
> No, I d'loaded the driver directly from Epson, and it's their only
OS X version. What's
weird
> is that it looks nothing like an Epson driver, and has none of the
usual settings. No
> "Speed-Quality", no PhotoEnhance, no "High-Speed", no
"Color-Black", no "microweave",
> no "Flip Horozontal", and the choice of papers and dithering
algorithms looks exactly
like
> those contained in the QTRgui, which I assumed were a std set from
GIMP Print. Oh yes,
> under paper you can choose Ilford Heavy Paper - I've never seen
Epson tout an Ilford
> product! And under Ink Type, I can select Four Color Std, Three
Color Composite, or
> Quadtone. I've never seen Epson officially support Quadtone either.
> OK, so after a little more research, I think I have an answer. I
found a newer driver on
> Epson's Eurpoean website, but it has the same behaviour as the US
driver. I suspect that
> there is no OS X driver for the 1160, that the plug-in is a bare
bones driver just to get
OS
> X to recognize the 1160, and then it relies on the underlying
CUPS/GIMP Print
technology.
> That said, I'm going to have to print under OS9 (no big deal, I can
hook the 1160 up to
> another machine), or I'm going to have to use the QTR.
