You have to observe the positions that carts are intended for
because of the chips. if you are at a loss to figure out which
half of the inkset to put where, I'd say call inkjetmall for some help.
As long as you have 3 grays for each tone (plus the Black of your choice)
you should be OK.
Beware of CIS if you won't be using the system every day. Even
so, remember too stir, not shake, (!) from time to time.
Once the carts are in place, and jets are firing properly, you can
use IJC to profile the system. You can opt to make a Sel profile
and a Cool profile and then blend them in OPM when you print.
Or you can fix the tone in a profile that blends the two.
Remember that it's not a good idea to leave jets without
firing at all. So, even if you make an all-selenium profile,
it's a good idea to let just a bit of the Cool inks come through
so the heads don't dry out.
Antonis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "chmmagma" <chmmagma@y...>
wrote:
> Hi,
> I have a 2200 printer would like to use Piezotone Selenium tone and Cool tone inks
> with it.
> Is it possible to configure the inks in the 7 cartrige system and have both installed?
> How do i go about doing this?
> Is there a way to use to install both ink sets and create a working profile for either
> using Selenium or Cool tone?
> I would like to install a CIS.
> CHM MAGMA
