UT7 and curves not working
2005-02-06 by lovelipp
I have UT7 inks in my 7600. When I print without using curves or sliders, I get a good neutral print. But when I use any of Schwab's curves or Paul's slider suggestions, the ink lays down blotchy - as though it was sponged on. The neutral setting looks almost purplish. I stay on RGB,8 bits per, set paper to Smooth Fine Art, 360 dpi, HPR, Epson driver. This is a new problem. A few months ago, I was able to get all the tones from cool to sepia - with the same quality print using the curves and/or the sliders. Also, perhaps Paul or Bill can suggest slider settings or a curve just a little warmer than carbon and not as brown as sepia? Thanks for any suggestions - Arlene www.arlenelove.com ArleneLoveL@...
