BO on R800
BO on R800
2005-02-14 by Stephen Kobrin
I would like to try BO on my R800 but cannot find an option in the
driver to tell the printer to use only black ink.  Will sending a
gray-scale file accomplish the same purpose?
While I am on the topic, I find the paper feed in the R800 very
touchy, to say the least.  I am begining to wonder if there is a
problem with my printer or if that is a general characteristic of
this model.  Any thoughts appreciated.
Steve
Re: BO on R800
2005-02-14 by scott_now_coming
The R800 has no "Black Only" option in it's driver.
I have noticed that my R800 has a hard time with "grabbing" Kirkland
Glossy.
Sometimes it willpass the paper through 2 times before it will print.
Don't know why, though.
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen Kobrin"
> Steve
[Digital BW] Re: BO on R800
2005-02-14 by Martin Sluka
You may feed any paper to 1.3 mm thick from front. Exactly as you print CD.
M.
Re: [Digital BW] BO on R800
2005-02-14 by Arthur Fink
No thoughts ... just frustration!
Sometimes it's fine.  Other times it just feeds paper through, rejecting
each sheet.  I can't find a clear pattern -- paper type, weight,
humidity.  Perhaps it correlates with the amount of time I have before the
next boat from Peaks Island!
Printer was replaced under warranty once.  New printer has the same issues.
		A r t h u r    F i n k     P h o t o g r a p h y
		Ten New Island Avenue               207.766.5722
		Peaks Island, Maine 04108  arthur@...
one dirty trick - try to plug out the power cord from your printer
when printing. Wait one minute and plug in again.
This reset the internal memories of all Epson devices.
Martin
I am not sure whether I am relieved or concerned to find out that it
is not just my priter.  One thing that seems to help sometimes is to
have either backing and/or a stack of paper behind the sheet you want
to print.  I keep a wad of laser paper in the feed, but it does not
always work, especially with EEM.
Thanks for all of the replies,
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Arthur Fink
rejecting
before the
issues.
> 		Peaks Island, Maine 04108  arthur@a...
