RE: 1160 and MIS UT-FS - an update
2005-02-14 by RH Designs
Well, I spoke too soon ... >If you give the printer a rest for >a few hours and then run a nozzle check, they may be better. Having done some testing and encouraged by a couple of good prints yesterday I was all ready to continue this morning. The first nozzle check of the day was good, so I made a quick test print. No black ink at all. A nozzle check confirmed no black, but colour positions OK. Head clean - black returned, colour positions faulty. Another clean - black faulty, colour better. Right, let the printer rest a while. Nozzle check - no black, colour faulty. Try the other black cart (PK vs EK) - same problem. After the usual attempts to get things running failed, I installed a brand new pair of standard dye ink carts. A perfect nozzle check at the first attempt. The 1160 doesn't have chipped carts of course, so I don't know if the UT-FS carts are running low, except that 2 A4 prints and a few 21-step greyscale tests *shouldn't* have emptied them surely? (And indeed a syringe pulls ink out of them OK.) Is this typical of 1160s and pigment inks? I have another 1160 which had a CIS installed with the older MIS Variable Mix and which ran OK for a while until it too terminally clogged up, and I can't get that running properly now even with dye inks and after trying all the "tricks" with cleaning solutions, carts, etc. So I'm somewhat disillusioned by the whole situation. My fully profiled R800 will make quite good b+w prints but there's the metamerism problem, and of course it's only A4. I can't afford an R1800 yet ;-( I'd really like to get the 1160 running reliably with the UT inks. Has anyone any suggestions please? Thanks Richard
