Wilhelm Epson R1800 ratings
2005-02-15 by Paul Roark
Wilhelm's Epson R1800 ratings are posted at
http://www.wilhelm-research.com/epson/R1800.html .
I Notice Premium Glossy Photo Paper is up to 300 years of dark storage.
Note how much lower the "bare bulb" ratings are relative to the 4000 and to
the glass-covered ratings.
Re: [Digital BW] Wilhelm Epson R1800 ratings
2005-02-15 by Carl Schofield
I also noticed that neither the R1800 nor the R800 have any ratings for
B&W prints generated with the UC high gloss inks.  Both the 4000 and
9600 have ratings for B&W prints made with the UC inks.
Carl
> and to
> Paul
Re: Wilhelm Epson R1800 ratings
2005-02-15 by scott_now_coming
That printer is a "screamer".
Epson is claiming 1 mim 51 sec for an  11x14 inch print.
That's good for an 8x10!
Scott
storage.
4000 and to
> Paul
2005-02-15 by Ernst Dinkla
Strange, the Premium glossy results are better behind glass
for the 1800 and worse in bare bulb.
The Premium Luster result is lower in total but only
significantly lower in bare bulb exposure.
Just a few papers to compare though. For all the papers
together the extremes up and low in bare bulb and behind glass
are quite close and so are the results of exposure through UV
blocking glass.
The gloss enhancer may help but not on all fading aspects. To
compare the 1800 sans glop there should be identical matte
papers in both tests.
Given the changes in the pigment particle construction it will
be hard to tell what causes the differences. It could well be
a thinner ink layer as a result of the smaller droplet size
(pigmentation higher in the ink to compensate for the thinner
layer). If there were BO test results for both printers on
matte papers we could get a better idea what the smaller
droplet means in fading.
A lot of people speculated that the 800-1800 concept could
deliver a similar wide format printer in the future. The gloss
enhancer probably will appear in wide formats too, I'm not so
sure about the 1.5 PL droplet and the RB inks. Speed is an
issue with wide formats, consistency of the droplet size
another one, the last in relation to color consistency in
proof printing where the extra grey added helped too. So far
the wide formats kept a minimum droplet size about 3x that of
the same generation desktop models. If RB is included it will
be as an extra to the CcMmYKk inkset, with the gloss enhancer
that's 10 heads, a bit over the top in my opinion. The other
wide format manufacturers returned to the CcMmYK inkset,
Colorspan and Kodak's Encads are the exceptions in the
industry now.
Ernst
