Epson Ultrasmooth paper: soon to be in 13x19" sheets
2005-02-15 by Arlen
For anyone who has avoided Epson Ultrasmooth Fine Art paper because
it has only been available in large sheets or rolls, I saw an
announcement (by InkjetGoodies.com) that it will be available in
13x19" sheets starting Feb. 28. This makes it practical for those of
us with Epson 2200 printers. I plan to try it. Anyone have experience
printing on this paper?
Re: [Digital BW] Epson Ultrasmooth paper: soon to be in 13x19" sheets
2005-02-16 by Walt Farrell
I've played around with the roll version using my 2200 (cut by hand, and
flattened).  If the info that Epson provides on their web site is
accurate, the sheet versions are significantly heavier and thicker than
the roll version.
They list the roll as 250 gsm but show two versions of sheet, at 325 and
500 gsm, with thicknesses of 21 and 30 mil.
	Walt
RE: [Digital BW] Epson Ultrasmooth paper: soon to be in 13x19" sheets
2005-02-16 by Paul Roark
I have used UltraSmooth from a roll for a couple of years.  While the dmax
is less than the best acid free papers, I generally like it, and it does
very well in fade tests.  My conclusions are that it is basically the same
as PremierArt Fine Art Hot Press.  See the specs at
http://www.premierimagingproducts.com/pdf/media/Premier_Art_Hot_Press.pdf
and compare them to the new Epson sheets.
____________________________
Sent: Wednesday, February 16, 2005 4:12 AM
Subject: Re: [Digital BW] Epson Ultrasmooth paper: soon to be in 13x19"
sheets
the roll version.
	Walt
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
Re: Epson Ultrasmooth paper: soon to be in 13x19" sheets
2005-02-16 by Chris Hargens
Have you tried Inkjetart's Illuminata Ultra Smooth? The specs & price
look pretty impressive. I'm wondering how it would compare to Epson's
Ultrasmooth. Also, considering its price, I've had good experience
with the Alphasmooth paper. Although the paper is somewhat flimsy and
the dmax is not great, I like its smooth rendition of tones -- great
for proofing for a more expensive (better) non-OBA paper.
Chris Hargens
the dmax
does
the same
pdf
> Paul
> www.PaulRoark.com
> From: Walt Farrell [mailto:wftemp1@h...]
13x19"
> sheets
because
of
experience
hand, and
than
> the roll version.
325 and
> 	Walt
resources as
wish to
this same
> page.
to keep
> them short.
flames.
B&W
removed from
> the membership.
Owner and
section:
PRINT
LIABLE TO YOU
EXEMPLARY
THE  "OWNER" AND
OF THE
INABILITY
ACCESS TO OR
CONDUCT OF ANY
OTHER
2005-02-16 by john dean
I've done a number of tests with my favourite rag and dual rag media, including all the
Hahnemuhle I use and the Ultrasmooth has no ink transfer in a bound book situation when
sprayed with either Premier Art, Lyson Printguard, or Lascaux. Actually there is no transfer
that I have seen with this paper even when not sprayed.
All the other rag media I tested did have some black ink transfer over time with
compressed under weight against a pure white sheet sprayed and unsprayed.
The great thing about Ultrasmooth ( Premier Art hotpress) to me is is durability. I belive
they worked hard on this. I like that coating for tonal characteristics also. It  has the most
scuff and scratch resistant surface that I know of, similar to Somerset but with a better
tonal rendition, black, and smooth texture. It's only possible downside to me is its slightly
less brilliant appearance in the hightlights becaue it is a natural color paper without
optical brighteners.
 But like Paul said, that might make it more permanent in the long run. This is an issue
that I would LOVE to know with more clarity. I stumble whenever I try to explain it to
clients- the actual fade differences between 100% high-end rag papers with and without
OB's?  Are there any actual tests to refer to? I think a lot of us are confused about the real
differences and what we should be doing regarding this . I use them all these days. I spray
all my papers that contain obs. I also know that all the old fiber darkroom prints had obs,
but because of the surface of coated inkjet media, that may be mixing apples and oranges
to discuss them in the same context.
John
> Paul
> www.PaulRoark.com
John,
>... Ultrasmooth has no ink transfer in a bound book situation when
>Actually there is no transfer that I have seen with this paper
>over time with compressed under weight against a pure white sheet
>is durability.
I agree.  Epson PremierArt Scrapbook paper is a related coating.  I think
durability and longevity were primary design goals.  The paper also seems to
smooth out all the dots, similar to what Photo Rag also does.  But the Photo
Rag surface is really sensitive.
>It's ... slightly less brilliant appearance in the hightlights becaue it
>is a natural color paper without optical brighteners.
>... that might make it more permanent in the long run.
>This is an issue that I would LOVE to know with more clarity.
>I stumble whenever I try to explain it to clients- ...
Whether the OBAs make any difference in fade and age testing seems like an
open question and may depend on the type of brighteners used, and there are
apparently a number of different ones.  Note, however, that Epson Watercolor
Paper -- Radiant White has OBAs and does about the best in Wilhelm fade
tests.  On the other hand, while most acid free papers in dark storage tests
have a "more than" symbol (">") before the rating, Watercolor Paper has a
flat "250."  This is, of course, so long maybe it doesn't matter. But, the
other papers that lack the ">" symbol are EEM and Mate Heavyweight, clearly
not archival papers.  This observation may not, of course, have any
significance.
One reason I worry about papers with OBAs in them is that even if the paper
is archival, we know they will yellow as the OBAs burn out.  I think this
will be seen as purchasers as a sign that the paper is cheap.  If, for
example, the image was matted with a white border showing and is removed
from the matte & frame for storage after a few years of display, the
purchasers might see an outline of the matte board.  It might look like a
yellowing and deterioration of the paper that was exposed to light.  I don't
know how long it takes in typical display for this to show up, but it
clearly shows in my faded tests of, for example EEM.
On the other hand, while UltraSmooth will not show any fading, per se, in
this same time frame, the carbon will have yellowed a bit, while it might
have actually gained density.  If the image was over-matted, this would also
be visible.  But, if there was a white border of UltraSmooth showing, there
would be no obvious "shadows" on either the image or paper of the
UltraSmooth print.
OB's and UltaSmooth
Thanks Paul,
Right, it is wrong to group all rag papers with Ob's as being the same. That is a mistake a
lot of us make. There are various degrees of OB content and chemical composition. Say if
you compare Legion Matte or Hawk Mt. bright white Condor, or Red River Premium Matte,
they all have a lot more brightening going on than say H. Photo Rag or Somerset or even
Enhanced Matte.
I guess what still is unclear to me is the results of Wilhelm's tests with Somerset rag and
the Epson Watercolor media which both contain Ob's yet have excellent ratings that often
exceed 100% rag media without any ob's present at all. These tests are supposed to reflect
discoloration of the whites ( yellowing) as well as image fade. How much of this is the
result of uv and how much is the result of air pollution is also not clearly established.  The
Premier sprayed Somerset prints have super major improvements in his data. That is why
when in doubt I spray. I really wish he would test Hahnemuhle media. I've written so many
times to them and gotten no response. They know half of us out here are using Photorag
and William Turner for fine art applications.
Go look at the  new test results on Henry's site for the Ultrachrome black and white
process. He's uped the permanence estimates and in many cases far beyond what I'd ever
imagined. And, I image Pauls inks beat these results because they are carbon with no color
content at all.
John
-One reason I worry about papers with OBAs in them is that even if the paper
Re: OB's and UltaSmooth
2005-02-17 by Clayton Jones
Hello John,
According to Diana York of Hawk Mtn papers, there are different kinds
of OBAs and the OBA technology is constantly improving.  I've also
gathered from some research that OBAs "burn off" (not a trade term,
BTW) in different ways, or with different effects.  Some may lose some
reflectivity (not be as bright) but not change color significantly.
Some papers have OBAs in the paper and the coating, some only in the
coating (but who knows what that means...).  According to Diana, the
paper can't get any yellower than it was to begin with.  She said in
their papers they use white colored fibers to begin with, so that
there shouldn't be a dramatic color change (please see the OBA section
in the "Great Paper Chase" article at the link below).
My own experience with two of their papers bears this out.  I have
noticed that prints on Condor BW (pure white) lose some brightness
after a few months exposure (comparing an old print with a fresh one),
but haven't (so far) shown any color change - the print doesn't look
degraded or yellow, just a tad softer on the eyes.   With Merlin
Smooth, a warmer color to begin with, I haven't noticed any change at
all.  Of course, none of this is scientific and only spans about a
year.  We don't know what will happen over many years.
All of the above, however enlightening, tells us nothing, really.  In
the various papers we use, we don't know what kinds of OBAs are used,
or how much, whether it's in the paper, coating or both, or what will
happen over time.  That detailed information doesn't seem to be
available.
I'm not terribly worried about it myself.  One reason is that I've got
some silver prints on OBA containing paper (Oriental Seagull, etc)
that have been laying around for 20 years and they still look
extremely bright.   Also, my windowsill ink fade tests on PR prints,
some of which have been receiving bright daylight and partial sunlight
every day for over a year, have shown ink fading but not paper color
change under the cover strips.  My feeling is that these papers are
using the latest in OBA technology, and I just don't expect to see
significant changes.  I know I'm taking a chance, but I really don't
like the look of the warmer papers as much.
Everyone is going to have to make up their own mind based
on...whatever.
Clayton
