persistent bad noozle check on my 7500-FSN+ / Yellow position
2005-02-16 by chartwigp
Hi all !
I'm converting my 7500 to MIS UT-FSN+, Paul's new inkset...
I've done two prints, both with obvious noozle problems... but
encouraging.
After many attempts with normal cleaning, I tried loading the lines
again in maintenance mode... 3 times actually...
Now my carts are almost empty, and I still can't get a good check for
the yellow ink... 10 noozles are not firing (yesterday, it was at
50%!). The other colors are OK.
I used the transportation procedure to empty the color inks (Epson's
ColorFast) before installing the MIS carts...
When I first loaded the lines, I saw clearly air bubbles in the yellow
ink line... But now almost 100ml of ink has gone through it, I think
it should be ok !!!! and I can't see bubbles anymore...
What am I missing ? I didn't try KK1 or KK2, just KK0 cleaning and ink
charging... and my carts do not contain air... I checked this morning,
before yet another ink charge...
I'm really stuck ! I must add that the printer worked perfectly in
color...
If some of you have had the same kind of problem, please HELP ME !
Thanks !
Chris
PS : I'm afraid I'll have to order new ink bottles... it took me 2
days (the printer had much rest !) to empty the carts :-(
PPS : I'll copy this message to MIS support...
