MIS UT7 - Epson 2100 - Epson Driver vs QTR
2005-02-15 by Marco Ristuccia
Hi all,
A week ago I received from MIS the UT7 full ink set for my Epson
2100 (with ebony black).
Before receiving this set I usually print with Epson UC standard
inks and QTR on EEM paper.
As soon I printed a test image with UT7 and Roark Neutral EEM Curve
(following the workflow) I noticed that the shadows areas are much
lighter than the QTR ones. Indeed the overall image seems less
contrasty then the QTR one.
In order to make some side by side comparison I decided to:
1)
Print a 21 step test pattern with QTR (QTR Gray Matte profile, UT7
curve 50% cool and 50% warm).
2)
Print the same test pattern with PS8 and Roark Curves (EEM Neutral
one).
According to my firs impression I noticed 2 things:
1) Linearity
QTR closes shadows too much (the last two step, 95% and 100%, are
almost the same full black). To my eye it seems that from 55%-60%
level the gray curve begins to go down much faster than the rest
part.
The gray curve of the print made with PS8, Roark Curve and Epson
Driver seems perfectly linear. The 95% and 100% steps are well
different (mybe too much). To my tastes I would prefer a little more
contrast and deeper shadows than this.
2) Dither pattern (seen with an enlarger lens)
QTR has much better dithering pattern. Dots are wery wel diffused
without some visible pattern.
The print made with PS8, Roark Curve and Epson Driver shows too much
aligned points (quite like a micro-banding). This is visible also to
a naked eye.
In conclusion, I will go with the Epson Driver if there were a way
to change dither algorithm of the Epson Driver. Is there a way to do
this?
Or do I have to edit/recreate the QTR UT7 curves to correct their
shadow closing problem and go with it?
Have you suggestions?
Have you also noticed those thinhs in your own tests?
Thanks in advance
Marco
Re: [Digital BW] MIS UT7 - Epson 2100 - Epson Driver vs QTR
2005-02-15 by Daniel Staver
Hi Marco,
I'm the one who created those curves. Others have also reported back to
me that they seem too dark in the shadows, but here 95% on the stepwedge
is actually a bit lighter than the same stepwedge printed with Paul's
curves.
I don't have an explanation for this except that one of my inks may be
configured incorrectly or that my printer is behaving differently than
others.
Fortunately, with todays release of QTR with profiling you can now tweak
your own curves. You can even linearize using your own scanner if you
don't own a densitometer. See my separate post on this.
Daniel Staver
http://daniel.staver.no
Marco Ristuccia wrote:
> Hi all,
> 1)
> 2)
> one).
> 1) Linearity
> part.
> a naked eye.
> this?
> Thanks in advance
Re: MIS UT7 - Epson 2100 - Epson Driver vs QTR
2005-02-16 by Marco Ristuccia
Hi Daniel,
Thank you for the answer.
Yesterday a made a scan of the two printed 21-step-wide test pattern.
Then I scanned it and made an excel table with the average values of
each step. Printing a line graph together with an ideal linear one I
verified that while the UT7/Roark/Epson curve is quite perfectly
linear, my QTR ones have a different slope.
I'll follow your suggestion and linearize the QTR curve using my
flatbed scanner as a desitometer, hoping it has a linear output
curve :o)
Ciao
Marco
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Daniel Staver
<daniel@p...> wrote:
> Hi Marco,
back to
stepwedge
Paul's
> curves.
may be
than
> others.
tweak
you
> Daniel Staver
Re: [Digital BW] Re: MIS UT7 - Epson 2100 - Epson Driver vs QTR
2005-02-16 by Richard Ross / RH Designs
Marco, Daniel,
 >curve :o)
I've been doing this for a while, using my flatbed to help derive standard
Photoshop curves.  I use Vuescan because the software with my elderly Agfa
Snapscan isn't up to it but checks with a densitometer verify the system
works.
Richard
