Re: [Digital BW] Fixing a clogged Epson 1280
2005-02-17 by Bob Frost
Keith,
Not sure about the 'perfect' that you mention. AFAIK each printhead is
tested by Epson and has a series of numbers (stuck on the side?) that have
to be entered into the EEPROM by the service program to correct the output
of the particular printhead (none are exactly the same). So you may be very
lucky in that your old and replacement printheads had exactly the same
correction factors, or you just aren't seeing the difference.
Bob Frost.
I soaked the print-head (not the electronics!) in cleaning solution
for a couple of days.  Still nothing.
However, I happened to have an old 890 that I don't use very often.
It has the identical print-head.  I put its print-head in the 1280
and, voila, perfect nozzle check and prints.
2005-02-17 by keithd2010
Just lucky, I guess.  I found and downloaded the Epson Adjustment
Program from http://www.resetters.com/downloadfiles.php and was
prepared to spend time making adjustments.  But before doing that, I
just printed the regular head alignment in the driver and got a very
smooth dither without adjusting anything.
-Keith
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Frost"
<bob@f...> wrote:
> Keith,
is
that have
output
be very
same
> Bob Frost.
