whither the 1200?
whither the 1200?
2005-02-19 by mojojones2001
Why is the 1200 not supported by so many of the workflows that include
the 1280?  Is it that much different?
thanks,
John
Re: [Digital BW] whither the 1200?
2005-02-19 by Steve Bell
> thanks,
> John
I suspect because it is much older, so there are less about, and its ink
nozzle size is larger. There's less of an incentive to produce support for
the newer inks.
I have one here, used as a backup for printing colour. If I wanted to use if
for B&W, what would be the best inkset to use?
Steve Bell
2005-02-19 by john dean
Steve,
I have a 1200 set up with Piezzotone Carbon Sepia and it works great. I've had no cloggs
or banding or any issue, though I don't use it a lot. I'm sure the MIS quads will work great
on it too. I really don't see a lot of difference in output from the 1270-80 machiines and
the 1200. However, the tolerances between these older machines were far more different
from unit to unit than the Ultrachrome printers are. The 1200 is also a fairly slow printer.
John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Bell <steve@l...> wrote:
> > thanks,
> > John
> the newer inks.
> Steve Bell
2005-02-19 by Richard Smallfield
I used the 1200 with UT1 and the blacks weren't nearly as dense as my new 2100 plus UC inks - the earlier MIS inks had curves that were designed specifically for that printer, but using those curves with UT1 inks yielded disappointing results from me ... and I gave up in the end because of clogs, anyway.
Richard
http://smallfield.vze.com
http://photos.smallfield.vze.com
   "There is not enough darkness in the whole world to put out
   the light of a single candle."
   --Anonymous
2005-02-20 by Brubaker family
Steve,
Last week I finished printing a series of BO photos on
my 1200.  I used the Eboni ink on Dot Works Nature Jet
paper.  This is a 100% cotton paper with no coatings.
I used it because I had a supply at hand.  I am really
pleased with the results.  I started my B&W printing
around Christmas with a C84 and the EZ-N inkset and
was very pleased with them, but I wanted some larger
versions of the prints too.  Thus my experiment with
the 1200 and BO.  To my eye the 11X16.5 BO prints from
the 1200 looked similar to the difference between an
8X10 from a 35mm negative and an 11X14 from the same
negative.  In this case I was comparing the 10X6.6
EZ-N prints to the 11X16.5 Eboni BO prints.
Successful experiment, and I'm sure I will be printing
more.  One advantage to the 1200 is that they can be
bought used on eBay very reasonably.
Mike
> > thanks,
> > John
> the newer inks.
> Steve Bell
Do you Yahoo!?
The all-new My Yahoo! - Get yours free!
http://my.yahoo.com
