> From: Ernst Dinkla [mailto:E.Dinkla@...]
> Sent: Friday, March 18, 2005 6:09 AM
> Subject: [Digital BW] Cyan overcoat, Cyan underlay for Black... was Glop
> etc
> Paul Roark wrote:
> >>> Have you tried a dark cyan overcoat?
> >>I will try that. But an overcoat of cyan pigment on a black pigment
> >>layer isn't producing a black dye layer though.
> >True, it's not a dye. But if it is truly transparent, then it relies on
> the
> >reflectance of the underlying substrate -- usually paper. Here,
> however,
> >that substrate is carbon. So, its absorbency, the way a subtractive,
> >transparent color works, takes out only certain colors of the underlying,
> >reflective substrate. Carbon is warm, so the cyan is absorbing the reds
> of
> >that warmth. The cyan part of the carbon reflection will come right back
> >through, but there isn't much of that.
> >I guess the question is, in part, how transparent the cyan really is.
> >>One of my concerns with colored overcoatings is that they may increase
> >>metamerism.
> >What I saw was so dark if there is some it's not of much consequence.
> >Only one way to see.
> Paul,
> No positive results.
> I have printed some proofs with the Epson 10K, WasatchSoftRip, MIS 7600
> inks (including Eboni black) on HPR. Spectrocam Status T measurements.
> The RIP was unlinearised, uncalibrated etc for this task, no need for
> that either. Straight CMYK fed it gives straight CMYK output. A square
> with strips descending from 100% black, 99%, 94%, up to 66% black, next
> to one another. First two prints of that. Forced dried and after 30
> minutes a similar Cyan square printed on the black but 90 degrees
> turned. The other black square was over printed with the Light Cyan
> steps = 50% > 33% C.
> The results, less visual blackness, a heavy magenta-aubergine sheen and
> a drop in Dmax of the best black strip (94%) from 1.747 to 1.54 for the
> 100% cyan overcoat to 1.65 for the Lightest Cyan strip.
> The other way around with Cyan first and black overcoat delivered a drop
> in Dmax of about 0.06 for the heaviest Cyan underlay and 0.02 for the
> lightest Cyan underlay. So no gain there either. Visually a bit bluer
> and lighter, which seems to increase in time, not much metamerism. I
> don't think I will measure them again, there's nothing to win there.
> Given the weaving of the Epson head and the color print order the truth
> will be somewhere in between when this is done in one printrun.
> This shows how much pigment inks reflect light. It may be different for
> another inkset.
> There's one thing we didn't discuss on the differences between dye and
> pigment inks. The dye ink will be more transparent but still have more
> coloring power, I don't think one can put a too heavy load of dye in an
> inkjet ink, it will still print. With pigment inks we are at the edge of
> consistency in inkjet printing, pigment settling and piezo pump capacity
> etc considered. The coloring power of the dye will result in a darker
> coating from the top to the bottom. Less reflection than with pigments
> and heavier filtering inwards.
> Ernst
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
