QTR and Banding - ALWAYS
2005-02-21 by joemulligan_68
I just wanted to find out if anyone out there is experiencing
banding while using QTR.  I first tried QTR using a 2100 and always
had banding.  This would be most evident in highlights or on skin
tones.  I upgraded to a 4000 and downloaded the latest QTR version
but still have the same problem.  QTR always has banding for me no
matter what profiles I try.  With ImagePrint I am normally banding
free but there are the occassional images that band.  With the Epson
driver, I never have banding.
I am wondering if the cause of this has got to do with the way the
curves/profiles are written and how these RIPS lay ink down on
paper.  I was also thinking that these RIPS probably use plenty of
Black ink and that if there was a slight problem with a black nozzle
banding would show up.  However, my nozzle checks are perfect and I
have no banding when printing BO on matte and glossy papers.
I like the flexibility of QTR but it always bands for me.  Hope some
experts out there can comment.  Thank you in advance.
JM
Re: [Digital BW] QTR and Banding - ALWAYS
2005-02-21 by Steve Kale
What resolution and speed?  I use 1440super and Better on my 2100.  No
banding.  I do get banding at straight 1440.  I also use Ordered dither.
> From: joemulligan_68 <joemulligan_68@...>
> Date: Mon, 21 Feb 2005 03:46:58 -0000
> Subject: [Digital BW] QTR and Banding - ALWAYS
> JM
2005-02-22 by joemulligan_68
Hi Steve,
Thank you for your response.
I also use 1440 super and better as well as Ordered Dither.  No
matter what settings I use QTR always bands. I am wondering if what
I am mistaking for banding is actually visible dithering but I tried
adding 2% noise and 5% and this problem is still evident.  I am
certain this is not a nozzle problem like I mentioned in my previous
post.
Am I the only one experiencing this problem?  Do you have any other
suggestions?  The flexibility of QTR is excellent, now only if I can
just get rid of these darned lines!
Many thanks,
JM
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
2100.  No
dither.
> > From: joemulligan_68 <joemulligan_68@y...>
always
version
no
banding
Epson
of
nozzle
and I
some
> > JM
2005-02-22 by Steve Kale
Banding will be parallel to the movement of the print head.  This I do not
get except with 1440 (not super).  I am a bit late to this thread but have
you done a head alignment etc?
> Date: Tue, 22 Feb 2005 00:51:15 -0000
> Subject: Re: [Digital BW] QTR and Banding - ALWAYS
> Hi Steve,
> post.
> Many thanks,
> JM
2005-02-22 by Nick H. Nugent
Hi JM,
I did a slew of profiles for multiple papers and inksets and actually
got one that gave serious posterization in the bright skin tone
areas. All I did was rescanned the target, entered linearization
data, and regenerated the curve and the problem went away.
I have no idea that might have caused the problem, but with the
problem profile I noticed a sharp dip just about where I noticed the
banding or posterization. This could not have been caused by my
reading an incorrect target because the dip is very sharp.
It could have been the data I entered manually and made a mistake
somewhere. For the rest of the profiles data are entered using a more
automated process to reduce possibility for errors.
I hope this help,
--nick
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "joemulligan_68"
<joemulligan_68@y...> wrote:
> ... I also use 1440 super and better as well as Ordered Dither.  No
> tried adding 2% noise and 5% and this problem is still evident.  I
> am certain this is not a nozzle problem like I mentioned in my
> previous post...
2005-02-23 by joemulligan_68
Hi Nick,
Thank you for your feedback.  I simply use the curves that are
loaded with the Windows version of QTR/QTRgui.  Yesterday, I printed
some images of rock formations with sky and clouds above.  What I
notice is that the highlights show some sort of "dither banding"
while with the shadows (rocks) this banding or dithering is
camouflaged.  It is highly obvious in high key images.  This banding
always runs parallel to the print head.  I have ruled out paper
alignment and nozzle problems because this problem only happens with
QTR.  It sometimes happens on some images with Imageprint but I have
never seen it printing the same files with IJC/OPM nor the standard
Epson driver.
I just want to know if anyone has the same problem.  I can try and
relinearize as you suggest but this problem happens with every curve
that is loaded with QTR.
Any other thoughts?
JM
-- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Nick H. Nugent"
<nghin@p...> wrote:
> Hi JM,
actually
more
> I hope this help,
> --nick
> --- In
No
what
I
> > previous post...
2005-02-23 by Nick H. Nugent
Hi JM,
I think I understand a little better now. At this point I can only
speculate as to what may be the source of this banding.
Each profile supplied with either QTR or IJC/OPM, or Imageprint for
that matter, are designed from a particular printer and media, and
ink. As we know all Epsons of a particular model are not the same.
What I'm leading to is the ink limits and densities may vary from
printer to printer. This may lead to a rare but very possible scenario
in which you get an extremely narrow overlap between the light and
medium gray inks.
One ink starts to fade out before the other gains in strength causing
a lack of a smooth transition in tones. I can easily see that the
transition from medium to light gray is the most vulnerable to
variation in printhead characteristic. So I think it just so happens
that the canned profile that came with QTR doesn't work properly in
your situation. Again I'm assuming that missing or deflecting nozzles
are not involved.
I think it is a good idea to create a profile for the paper/inkset
that you are having problems with. You can quickly create one within
just half an hour just to prove whether the problem is with QTR or not.
--nick
> Hi Nick,
> Epson driver.
> Any other thoughts?
> JM
> <nghin@p...> wrote:
> > Hi JM,
> actually
> the
> more
> > I hope this help,
> > --nick
> > --- In
> No
> what
> I
> > > previous post...
2005-02-23 by Steven Karafyllakis
Hi Jm;
I've had a fairly persistent banding problem with QTR on my 7600.
Sounds like yours is worst though. I can almost get rid of it
completely if I print at 2880, Better, and Adaptive Hybrid
dithering. test those settings & see if they help
Steve Karafyllakis
--- In
> Hi Nick,
printed
banding
with
have
standard
> Epson driver.
curve
> Any other thoughts?
> JM
Nugent"
> <nghin@p...> wrote:
> > Hi JM,
> actually
> the
mistake
> more
> > I hope this help,
> > --nick
> > --- In
Dither.
> No
> what
evident.
> I
> > > previous post...
2005-02-23 by Steve Kale
Ok one last thought - download the purge file from MIS and print it
Standard.  I still think you might have a nozzle problem.  See if you have
any gaps.
> From: "Nick H. Nugent" <nghin@...>
> Date: Wed, 23 Feb 2005 04:29:56 -0000
> Hi JM,
> medium gray inks.
> are not involved.
> --nick
>> Hi Nick,
>> Epson driver.
>> Any other thoughts?
>> JM
