Need new film scanner for 35mm?
2005-02-26 by Charles Wilber
My old HP film scanner finally died so I am in the market for a new
one. The Nikon Coolscan V and the Minolta Scan Elite 5400 appear to be
the highest rated in the lower price level. I scan 35mm color slides
and XP2 negatives and print mainly black and white prints. Do people
have recommendations for a good scanner and is it worthwhile to add
the Silverfast software? I scan medium format negatives with my Epson
3200 using Silverfast and like it but probably don't scratch the
surface of its capabilities. Thanks for any help.
Chuck
RE: [Digital BW] Need new film scanner for 35mm?
2005-02-26 by Seth
My opinion only--based on my experience.
I have found Nikon software to be cumbersome.  I bought one of the earlier
Coolscans and had nothing but terrible responses from their tech support.
I eventually switched to Minolta and never looked back.
For software, whatever you choose, I recommend Vuescan at www.hamrick.com.
Inexpensive, very customizable, Ed is rsponsive and constantly updates.
Seth
==-----Original Message-----
==From: Charles Wilber [mailto:cwilber@...]
==My old HP film scanner finally died so I am in the market for
==a new one. The Nikon Coolscan V and the Minolta Scan Elite
==5400 appear to be the highest rated in the lower price level.
==I scan 35mm color slides and XP2 negatives and print mainly
==black and white prints. Do people have recommendations for a
==good scanner and is it worthwhile to add the Silverfast
==software? I scan medium format negatives with my Epson 3200
==using Silverfast and like it but probably don't scratch the
==surface of its capabilities. Thanks for any help.
==Chuck
Re: [Digital BW] Need new film scanner for 35mm?
2005-02-26 by tgos3
Just to add another opinion based only on my own experience-- I use a
Nikon Coolscan 8000 (since i do MF work).  I believe the software is
similar if not identical for the 35mm Nikon scanners.
I initially found the Nikon Scan software interface annoying, but
updates from version 3.X to 4.X (free from Nikon) have improved it a
bit.  The actual capabilities of the Nikon software are rather good,
(exposure, gamma, density, curves, color correction, highlight and
shadow management, etc.) especially if you don't use Photoshop which
does pretty much all the same things with a more convenient user
interface.
I tried Vuescan (versions 6.X), and find it more cumbersome and
slower than the Nikon software, although also capable of very good
results, and an incomparable bargain, well supported by it's author.
I don't use it anymore, and went back to the Nikon software.  It may
have improved since I tried it.
I have not tried to use Nikon human tech support.
ted
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Seth"
earlier Coolscans and had nothing but terrible responses from their
tech support.
www.hamrick.com.
updates.
