More on MIS UT2 cart problems/solutions (longish)
2005-02-26 by tgos3
I posted a while ago about the poor shadow density contrast and muddy prints I was getting with UT2 carts on my 1280. Like Jim Pagoda I apparently had the wrong inks or the wrong ink order in my carts as supplied by MIS (bought in Dec '04). Like him, once I got the proper carts my results were more in line with the good results others have obtained. Jim and I had been discussing our experiences off list, but a few details of my experience might help others, so: It is better to call MIS than to use email, as Jim has implied. I called them up and got instant no hassles replacement, shipped at their expense, of the eboni and 'color' carts. I was polite and restrained, and didn't whine about the lost time and paper, and they were upfront about problems with some runs of cartridges, and their plans to bring that all in house in March 05. The carts arrived in less than a week, whereas Jim's took a long time after email arrangements. My new carts, unfortunately, arrived with considerable ink leakage in the packages. I believe they had syringe sampled the inks to be sure they were in the right order. If I had paid for the carts I'd have been annoyed at the wastage, and I hope their 'normal' carts don't leak, but in the circumstances i just moved on. The new carts work fine, although it took a bit longer than last time to get a good head check pattern, even after a few purge pattern printouts. When printing out color patches using the 'purge pattern' files, my original 'wrong' inks had looked almost normal (compared to Paul's kindly supplied scans of his own purge patterns), due to the way the Epson print driver assigns the ink colors. I had not been certain that i had 'wrong ink order problems'. Nevertheless, with new carts the shadow density problems went away, especially using Roy's Gray Lab monitor and print profiles. Bottom line: MIS seems honest, upfront and willing to make good, but I hope they can get their QC nailed down, so more folks don't mistakenly waste paper and time trying to fix unfixable problems. I'll have to try another set of carts to see if the leakage problem is a common one. The output results from proper carts seem well worth the trouble, so far. Even the dither patterns are better, now that the proper ink gradations are laid down. ted
