hinge mounting
hinge mounting
2005-02-27 by Michael C
Hello all,
I am still fairly new to printing and preparing Fine art work for
framing. I have started cutting my own matting and mounting. I am
very interested in the "hinge mounting" technique. Can someone
explain this to me?
Michael
http://www.ChevalArts.com
Re: hinge mounting
2005-02-28 by Steve Gledhill
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Michael C"
<mcfotowurks@y...> wrote:
> Hello all,
> explain this to me?
> Thanks,
> Michael
Try a Google search for "hinge mounting" linen.  I found this in seconds:
http://www.trueart.info/hinging.htm
Steve Gledhill
http://www.virtuallygrey.co.uk
Re: hinge mounting
2005-02-28 by Michael C
Steve,
Thanks so much for directing me to that website. It contains very
detailed instruction, and more. Just what I needed.
By the way, your site is very nice, great work.
Michael
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve
> > Hello all,
for
am
> > explain this to me?
> > Thanks,
> > Michael
seconds:
> Steve Gledhill
Re: hinge mounting
2005-03-01 by lakecd
Here is another website you may find useful. Has good instructions
and diagrams.
http://www.nedcc.org/plam3/tleaf66.htm
Don
> Steve,
> Michael
> > > Hello all,
> for
> am
> > > explain this to me?
> > > Thanks,
> > > Michael
> seconds:
> > Steve Gledhill
Re: hinge mounting
2005-03-01 by mojojones2001
Just a tidbit:  Mounting to the window mat is generally frowned upon.
 Collectors/curator want to open the window to examine the full face
of the print, and let the print hang down from the backing to examine
the back of the print.
john
Re: hinge mounting
2005-03-01 by Clayton Jones
Hello John,
Good point.  What I'm doing now is I think the best of both worlds.
One of my frustrations with mounting on the backing has been that if
the matt moves even slightly during framing its spacing around the
image is messed up.  Hinging to the matt solves that, and the entire
process is quicker and easier.  So I am hinging the top of the print
the matt, and the top of the matt to the top of the backing.  This
allows the matt to be lifted and the print drops down to be fully
examined.  Seems like a good compromise.
Clayton
Re: [Digital BW] Re: hinge mounting
2005-03-02 by Steve Kale
Thanks for the references.  Not sure I want to mess with starch paste etc.
Are all comfy with using one of the mentioned acid free tapes eg Filmoplast?
> From: lakecd <lakecd2@...>
> Date: Tue, 01 Mar 2005 00:25:18 -0000
> Subject: [Digital BW] Re: hinge mounting
> and diagrams.
> Don
>> Steve,
>> Michael
>>>> Hello all,
>> for
>> am
>>>> explain this to me?
>>>> Thanks,
>>>> Michael
>> seconds:
>>> Steve Gledhill
One other question:  if one is going to hinge mount and NOT USE GLAZING, is
a window mat overlap of 1/4 inch enough or is more recommended eg 1/2 inch?
I would be using 8 ply mat board and endeavouring to follow the instructions
in the previously posted tutorials re hinging the mat window to the mount
board and then hinging the image to the mount board.
RE: [Digital BW] Re: hinge mounting
2005-03-02 by Seth
That's how I do it also.  Allows viewing both sides, leaves the print free
to move, still easily reversable.
Seth
==-----Original Message-----
==From: Clayton Jones [mailto:cj@...]
==>Just a tidbit:  Mounting to the window mat is generally frowned upon.
==> Collectors/curator want to open the window to examine the
==full face of
==>the print, and let the print hang down from the backing to
==examine the
==>back of the print.
==Good point.  What I'm doing now is I think the best of both worlds.
==One of my frustrations with mounting on the backing has been
==that if the matt moves even slightly during framing its
==spacing around the image is messed up.  Hinging to the matt
==solves that, and the entire process is quicker and easier.
==So I am hinging the top of the print the matt, and the top of
==the matt to the top of the backing.  This allows the matt to
==be lifted and the print drops down to be fully examined.
==Seems like a good compromise.
2005-03-02 by Seth
Polyvinylacrylic (PVA) adhesive is the alternative, but not as easily
reversible.  It comes pre-mixed.
Seth
==From: Steve Kale [mailto:stevekale@...]
==Thanks for the references.  Not sure I want to mess with
==starch paste etc.
==Are all comfy with using one of the mentioned acid free tapes
==eg Filmoplast?
2005-03-02 by Seth
I don't think 1/4" will hold things flat in a changing environment,
regardless of mat weight.
I think much depends on weight of the paper if you use narrow borders.  If
you're printing 11x14 on a 13x19, I'd leave all the border, assuming a 16x20
or so mat board/frame.
(Without glazing though you have no need to use barriers in the back either,
so a cost savings.)
Seth
==One other question:  if one is going to hinge mount and NOT
==USE GLAZING, is a window mat overlap of 1/4 inch enough or is
==more recommended eg 1/2 inch?
==I would be using 8 ply mat board and endeavouring to follow
==the instructions in the previously posted tutorials re
==hinging the mat window to the mount board and then hinging
==the image to the mount board.
Ok thanks.  Here is what I am thinking.  I am generally trying to find a
dimension mix that will fit one of framedestination.com's standard sizes.  I
think this is the best I can come up with with "rational" dimensions:
20x26 frame with exact opening of 11.75x17.75 inches.  4in 8 ply window mat.
Actual image is 10.35x16.75in (1.6181818 Fibonacci ratio - err not 35mm
dimensions but at least it has a story and looks excellent for most
landscapes) printed on 13x19in paper (5/8in overlap).  That leaves a top,
left and right border of 1/2in and a bottom border of 0.9in.  Hopefully that
will be sturdy enough - I really don't like the way the reflection of
glazing detracts from the whole image (and non-reflective glazing is very
expensive).
Thanks for all the help.
> From: Seth <seth@...>
> Organization: Serh Rossman Photography
> Date: Wed, 2 Mar 2005 08:38:30 -0500
> Subject: RE: [Digital BW] Re: hinge mounting
> so a cost savings.)
> Seth
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the membership
> without notice.
> printing. Users who persistently make off-topic posts may be removed from the
> membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See „Group Topic, Rules and Guidelines‰ in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE „OWNER‰ AND
> „MODERATORS‰ OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  „OWNER‰ AND „MODERATORS‰ OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
> DIGITAL BW, THE PRINT YAHOO GROUP.
2005-03-02 by Seth
Also, NOT recommended by LOC preservation since they usually etch with acid.
LOC isn't sure it can be completely eliminated.
Seth
==really don't like the way the reflection of glazing detracts
==from the whole image (and non-reflective glazing is very expensive).
