LINEARIZING BLACK & WHITE
2005-03-01 by rjtthomaselli
Hello I am new to the group.
 I am using UT7 inks with the epson print driver on a 2200 printer
I have acces to a Monaco spectrophotometer and would like to be able to linearize my
printer so I can write profiles for differnt paper types and take advantage of photshop
cs softproofing feature. I have tried the procedure using the 21 step wedge and
making custom dot gain cuves however this limits you to working in 16 bit grayscale
if you are working with a monotone rgb file it wont softproof. could anyone recomend
a way around this ideally I'd like to be able to write profiles or at least linearize using
the monaco software and the dtp41 spectrophotometer. however the linearization
chart that is packaged with the monaco software does not have a complete strip form
white to black it is composed of 2 colums and the second has some yellow wedges in
it. anyone recommend any tutorials etc on this subject.
thanks Josh T.
Re: LINEARIZING BLACK & WHITE
2005-03-16 by makicombospecial
Hi- go to <http://harrington.com/QuadToneRIP.html#softproof> and download the files
for the i1Match. You can follow the directions substituting your Monaco instructions. I
have used this with a Gretag Spectroscan with excellent results.
Greg W
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "rjtthomaselli"
> thanks Josh T.
