R800 marks HPR
R800 marks HPR
2005-03-15 by Richard Morton
Greetings,
I'm using an R800 for printing images with large areas of black and
noticing that the printer marks the surface of HPR.
The marks are made by the D shaped pick up roller on the left hand side
(opposite the adjustable paper guide) and are only visible if that area
is black.  Unfortunately most of what I'm currently doing are just
that.
My first R800 died prematurely (due to paper feeding problems as it
happens) and it exhibited the same behaviour.  I suspect they would all
do it to HPR, though neither of them mark EAM but it's really not
noticeable unless the area is black.
Someone suggested I try feeding sheets into the roll feed slot in the
back but I haven't been able to make that work - can't get the paper in
the right place.
Does anyone have any suggestions on how to use sheets in the roll feed
slot or anything else to try?
Thanks & cheers,
Richard Morton
Re: R800 marks HPR
2005-03-15 by Stephen Kobrin
Richard,
I have had serious paper feed problems with my R800, to the point
where I am sorry I bought it.  I have found that the problems tend to
be minimized when there is a substantial stack of paper in the feed
slot.  I am not sure if that will help with your problem, but it does
seem to minimize, if not eliminate feed issues.
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard Morton
<soulman@n...> wrote:
> Greetings,
side
area
> that.
all
paper in
> the right place.
feed
> Thanks & cheers,
> Richard Morton
Re: [Digital BW] R800 marks HPR
2005-03-16 by Richard Morton
Hi Steve,
When my original R800 stopped accepting paper, I found that I could
eventually get it to work again but only with plain paper and only if I
had a stack of it in the feed tray.  Yours could be afflicted with a
similar problem.  The new one seems fine in this regard but it hasn't
done a lot of work yet.
FWIW, Epson Tech Support were extremely helpful.  They guy I spoke to
asked me a few questions, including how old the machine was, then gave
me a DOA authorisation number without any prompting from me and in
spite of the fact that it was just outside their 14 day window for such
things.
>> noticing that the printer marks the surface of HPR...
>> ...Does anyone have any suggestions on how to use sheets in the roll
>> feed
Doesn't sound like anyone else has tried feeding sheets into the roll
slot on an R800 then...
Thanks anyway,
Richard
