color film for B&W?
color film for B&W?
2005-03-06 by Scott Graham
Hi
Does anyone out there regularly (mainly) use color film to produce gallery quality fine art
B&W prints?
If so, two questions:
1.  what kind of film and why?
2.  what disadvantages do you find?
as a standard of comparison, I am currently using Plus X.  For samples of my work see
www.sgraham.com.
I am also familar with many reasons for using color film for B&W (in the digital age), but
not potential disadvantages.
Thanks
Scott
Re: [Digital BW] color film for B&W?
2005-03-06 by hogarth@snappydsl.net
I've made some photographs that capture a subject brightness range (SBR)
of 11 stops. The scene was a magnolia blossom in direct sunlight. The
range from dark green leaves to white flower highlights was 11 stops
according to my zone VI modified Pentax spotmeter. I used 4x5 Tri-X
which captured this SBR effortlessly.
I've done similar work with a passion flower in my backyard, again in
full sun, this time with 4x5 160PortraVC and "only" 10 stops, but the
color negative film stayed with it. I expected color shifting in the
denser regions, but didn't get any. I also exposed a sheet of Tri-X for
this scene. I scanned them both on my drum scanner. Photoshop's default
method to change mode to grayscale was a better match for the Tri-X than
I would have imagined. But abstracting out the color didn't work for
this scene, so I didn't take the idea any farther.
But what this little experiment said to me was that it was possible to
do what you want. The real question is, is it desirable? I would say no.
I can think of three reasons off the top of my head why:
1) Color film response curves are not the same as B&W negative film
curves. You can overcome that in Photoshop if you want.
2) You loose control if you aren't processing it yourself, and
processing C-41 on your own is a pain unless you have the volume. That
brings us to:
3) the extra cost of the film, and the processing.
I'm sure there are other reasons to use B&W film when you want a B&W
result, but that's all I've got off the top of my head right this minute ;-)
Bruce Watson
Scott Graham wrote:
> Hi
> B&W prints?
> of my work see
> www.sgraham.com.
> Thanks
> Scott
RE: [Digital BW] color film for B&W?
2005-03-06 by Paul Roark
I concur with what has already been said, but would like to add that the
image quality just is not as good.
I used Impresa 50 for a couple of years, thinking that the ability to do
variable filtration in the computer would add more than the disadvantages
took away.  After that extended experiment, I went back to B&W film.
With respect to image quality, the real reduction in quality occurs when you
"filter" the image.  If you think about it, the only way the individual
color layers can be exposed by just using a small part of the spectrum is if
those individual layers are much "faster" relative to B&W film of the same
nominal speed.  When the color film is un-filtered, the various emulsions'
dye clouds act as multi-sampling the even out some of the grain (noise).
But, when you want that nice dark, red-filtered sky, and use only the
red-sensitive layer, what you thought of as slow, fine-grained film looks
more like 400 speed film.
So, for me, the image quality just was not there, and the usefulness of
multi-filtering (red for the sky, green for selected foliage, for example)
did not off-set the quality loss.
Then there is my psychological problem -- I can't resist the pretty colors
if I have color film in the camera, and those shots usually make bad B&W
prints.  I shall remain a purist B&W guy as long as possible.
_____________________________________
Sent: Sunday, March 06, 2005 1:03 PM
Subject: [Digital BW] color film for B&W?
Hi
quality fine art
B&W prints?
work see
www.sgraham.com.
digital age), but
Thanks
Scott
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
2005-03-06 by njfranknj
Scott,
If you *know* you only want B&W output and are skilled with filters
and other specific techinques for it, there is no reason to shoot
color negs. BUT, if you mix color and B&W in your print output, it
makes a lot of sense to shoot color negs only.
I use Portra 160 in 220 MF size for scanning because of the 10+ stops
of contrast range (under controlled conditions, a friend measured as
much as 12 before all detail was lost). The cost of developing without
prints is not significantly more expenseive than do-it-yourself B&W
($7 a roll), especially if you count the cost of your time; there is
no need for on-camera filtration most of the time and many images have
significant improvements and flexibility when a careful channel mixer
conversion method for B&W is used.
Judging by the images on your webpage, I doubt, however, that those
advantages will amount to much for your nudes, unless you decided to
combine different colored lights and mixed image channels for some
kind of effect.
Frank
> Scott Graham wrote:
> > Hi
> > B&W prints?
samples
> > of my work see
> > www.sgraham.com.
> > Thanks
> > Scott
2005-03-07 by Harold Goldberg
Check Out Scott Graham's  website. You can subscribe to the B &  W  website
and get all of these.
HG
njfranknj <kolwicz@...> wrote:
Scott,
kind of effect.
Frank
> Scott Graham wrote:
> > Hi
> > B&W prints?
samples
> > of my work see
> > www.sgraham.com.
> > Thanks
> > Scott
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See �Group Topic, Rules and Guidelines� in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
   To visit your group on the web, go to:
Celebrate Yahoo!'s 10th Birthday!
 Yahoo! Netrospective: 100 Moments of the Web
2005-03-07 by Scott Graham
Thank you Frank and others for the info to date.
Frank is of course right any potential advantages of color film would not really apply to my
nudes.
I think that I dozed off during my intial post.  Should not have mentioned my website, but
expressed a interest in other subjects that actually contain color (landscapes, etc.)
:)  sorry
Scott
 probably would --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Harold Goldberg
> HG
> njfranknj <kolwicz@e...> wrote:
> Scott,
> kind of effect.
> Frank
> > Scott Graham wrote:
> > > Hi
> > > B&W prints?
2005-03-08 by B. Ellis
digital age), but
I make gallery quality fine art b&w prints (occasionally) from scanned
negatives but I always use black and white film (TMax 100 and Ilford HP5+).
It's never occurred to me to use color film, partly because I didn't think
there were any advantages to doing so and there were at least two known
disadvantages (loss of the ability to process the film myself using the zone
system for contrast control and the additional cost involved in buying the
film and having a lab process it).  I realize this isn't responsive to your
question but why would you use color film instead of the black and white you
now use?
Sent: Sunday, March 06, 2005 4:03 PM
Hi
quality fine art
B&W prints?
work see
www.sgraham.com.
digital age), but
Thanks
Scott
page.
them short.
the membership.
Yahoo! Groups Links
2005-03-08 by Scott Graham
Well for something with color in it, not my nudes :), it is often easier to select
something by color.  Want to select a leafy bush with light streaking thru it? (golly knows
why), select "green" so to speak.  And you can of course apply a red filter or some other
one later, but more especially you could apply it to the sky and not the ruby red lips for
ex.
However, both Paul (a few answers back) and you have made me think I will stick with Plus
X "forever".
I do zone system too, but with scanning and photoshop it is less important (NOT
unimportant).  On cost, when I consider the value of time developing it probably is not
more expensive to have it done, IF it could be done well.
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "B. Ellis" <bellis60@v...> wrote:
> digital age), but
> now use?
> From: "Scott Graham" <gebilwil@n...>
> Hi
> quality fine art
> B&W prints?
> work see
> www.sgraham.com.
> digital age), but
> Thanks
> Scott
> page.
> them short.
> the membership.
YOU
ANY
