Re: Photokit sharpener and inks used for QTR
2005-03-10 by Diane Fields
I apologize for my redundancy in answering the request for how to use the sharpening action.  Need to scroll down through my emails before answering from now on.
I will say that using the plugins was much faster than using PK Sharpener (plus it works in 16 bit and greyscale) and if you are familiar with how PKS works, it makes it easier to understand what is happening as the action progresses.  If not, it may take a bit of experimenting to find the right settings.  I downloaded both the sharpening set and the custom sharpening set and tried both--I'd recommend that also--the sharpening set has 4 actions--and, as with PKS, you may find one works better than another for a particular image.
I'm really liking QTR---I got more EEM today and found that there is still a warm caste to the images when using 'none'.   I worked until I found a blend of profiles that suited me (quite 'neutral')--at least for the image I was working on, but  I'm still curious why I'm getting 'warm' with NO profile.  Is it because its using mostly 'black' ink (which is 'warm' on the 2200) or for some other reason?   I am very curious as to what inks it uses (did I read somewhere that its mostly lt. cyan, lt. magenta and black--I happen to be using MK right now---and no yellow???)    I searched within the group messages but didn't find much.
Diane
Diane B. Fields
picnic@...
photo site  http://www.pbase.com/picnic
  Sent: Thursday, March 10, 2005 2:31 PM
  Subject: [Digital BW] Re: Photokit sharpener and B&W
  Andrew,
  Extract the files from the Stuffit archive and place those files in
  the Photoshop Actions folder.  On my WinXP machine the proper
  location is Program Files > Adobe > Phoroshop CS > Presets >
  Photoshop Actions.
  Relaunch Photoshop and open the Actions palette.  Click the right
  facing arrow in the upper right hand corner and select "Load
  Actions".  You should see the actions you placed into the folder
  above.  Select the action you want and it will show up in your action
  palette.  Then run as you do any action.
  Lou
  --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Andrew Unger"
  <ungram@v...> wrote:
  > I've been following this thread and encouraged by Diane's
  experience
  > I downloaded the files, extracted them but couldn't figure out how
  > to get them to work in my PS-CS, Windows XP-Home setup.  There was
  > no "install" process so I copied the files to the folder where
  other
  > filters are but they didn't show up in the listbox.  Thanks for any
  > help.
  > Andrew
  - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
  BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Yahoo! Groups Links
Re: [Digital BW] Inks used for QTR
2005-03-11 by Carolyn Frayn
On 3/10/05 2:04 PM, "Diane Fields" sent the following verbage:
The black and grey UC inks are warm themselves, somewhat similar in tone to
the carbon sepia piezos to my eyes, in order to lesson that warmth you'll
have to blend with a higher percentage of the cooler profiles which have the
color inks come into play. Another thing you might want to look at is a
print using the same percentages you've been using, but on a different
paper, Epson Velvet, photoRag or German etching for example. You'll notice a
slight difference to the apparent tone of the inks due to the difference in
paper white.
Carolyn
2005-03-11 by john dean
Yea, I've personally found that when doing warmish mono output with QTR and UC inks,
papers with optical brightners like HP Rag and EEMatte don't have the beauty of papers
without them such as Premier Art Cold Press and H William Turner or German Etching or
Concorde Rag. A really interesting hue can be obtained with 80% Sepia curve and 20% Cool
Curve on the above mentioned media. It even looks nice on EE Matte.
John V. sent me this breakdown to describe the way the channels are being seperated.
This may give you some idea. He is such a helpful guy ( and Roy Harrington is King).
Hi John,
You asked on the list about making curves with QTR.
Also you mentioned how do you know how much of the color inks are being used
to tone? Just open a profile and look at this:
N_OF_INKS=7
DEFAULT_INK_LIMIT=50
LIMIT_K=
BOOST_K=60
LIMIT_C=0
LIMIT_M=0
LIMIT_Y=0
LIMIT_LC=12
LIMIT_LM=12
LIMIT_LK=36
The above is from the 76/9600 PhotoRag Cool profile. I'm not good at math so
don't laugh too much... but K=60 is the maximum for the Black ink. So this
60 becomes 100%, as related to the other inks, as it's the most ink laid
down.
Next is LK=36. 36 is a little more than half of K=60 so just a little more
than 50% of light black is being used.
Both Light Cyan and Light Magenta is being used at 12. So about 20% of LC
and LM are being used with this profile.
Best,
John V.
> paper white.
> Carolyn
2005-03-11 by Diane Fields
Thanks Carolyn.  That confirms, more or less, what I thought--that there must be a very large amount of the black and grey UC inks used in QTR since I knew they were 'warm' (having tried the BO method several years ago).  I've found a nice blend that comes up to a fairly neutral print on the EEM, but may have to adjust as EEM is usually only my 'test' paper.  I generally print on Velvet and HPR and I haven't tried those papers yet since I've just been demoing QTR.  I'll print on Velvet today to confirm my thoughts on QTR (which is excellent and I'm ready to send Roy my Paypal share *smile*).
What has been harder for me to get my head around (altho' I know it 'intellectually') is that when I print from a color managed PS environment, my print matches my calibrated monitor (but, unfortunately, with metamerism)--- but when printing with QTR and using gray-lab, gray-matte, my 'NONE' is a warm toned print.  Now I do understand that QTR uses primarily MK and LB  (warm toned) and am saving blends for each of my papers since I also understand the tone of the paper influences the print (and am also glad to have confirmed that the cooler profiles bring the color inks into play).  I guess I just wanted to be sure I understood what 'none' meant.
Diane
Diane B. Fields
picnic@...
  paper white.
  Carolyn
John, this is very helpful.  Thanks very much.  I'm going to print today on Velvet which is one of my favorite papers.  I have some WT around also so will try that.  Since I had tried BO several years ago, I knew that the UC-K inks were warm toned, but wasn't sure what other inks were involved in the profiles.  I thought I had read that only the K inks and LC and LM were used but couldn't remember where I had read it.
Diane
Diane B. Fields
picnic@...
  Sent: Friday, March 11, 2005 2:00 AM
  Subject: Re: [Digital BW] Inks used for QTR
2005-03-11 by Steve Kale
The bottom line is none means none - seriously you are not meant to use
"none".  You are meant to use one or a blend of two - none is there to
simply fill the gap ie a second curve is redundant if using 100-0 mix (or
0-100).  You would have to ask Roy what happens when you tell it not to use
a curve.  BUT this is not the intended use of the product.
> From: Diane Fields <picnic@...>
> Date: Fri, 11 Mar 2005 08:13:33 -0500
> Diane
Thanks Steve--I do understand that now and see where it fits into the 'curves' blend situation.
  Sent: Friday, March 11, 2005 8:29 AM
  "none".
  SNIP
On 3/11/05 6:13 AM, "Diane Fields" sent the following verbage:
I think you'll be please at the difference, slight, but there, I find a
depth and a more pleasing tone over EEM, which I also use to test.
> toned print.
What do you mean by "none"? I had assumed you meant "none" for the second
profile choice in the RIP control.. You are inputting a profile though
right? Always keeping the percentages at 100% total?
Sorry to have misunderstood your original question Diane... I don't know
what printing with "none" brings in, you will always want to pick one
profile, then blend with a second to achieve the 'tone' you desire. I use
100% warm for a lot of my work. But I love that tone, I think when I first
started with QTR and IJC I was trying to emulate the look of carbon sepia
piezo which I had been enjoying.
Have fun today with the other papers,
Carolyn
LOL--see, that's what happens when someone doesn't REALLY understand what to expect a RIP to do (I more or less do know for other purposes--i.e., my printer for commercial work uses a RIP and I expect spot on color with it, but obviously didn't know how to use one myself)..  Yes, I printed with 100% NONE--so, I got basically what one would get with a BO print more or less.  Learned my lesson, been there, done that--and all that nonsense-- and now I know better--thanks to help on this list which is always informative.  I have come and gone on this list over several years primarily because if I'm out of town/busy, it just gets way WAY ahead of me and I never get caught up so I unsub.  Then when its slower, I resub, but I do miss a lot in between.
Diane
  Sent: Friday, March 11, 2005 11:06 AM
  SNIP
  SNIP
2005-03-11 by B. Ellis
My understanding, gained from where I don't remember, is that QTR uses only
black, light black, light magenta, light cyan, and yellow inks.
Sent: Friday, March 11, 2005 1:42 AM
a
blend
Is
for
messages
paper white.
Carolyn
page.
them short.
the membership.
Yahoo! Groups Links
2005-03-11 by Carl Schofield
QTR can use any inks you want to use.  For the UC inks the following
generally applies.  Most of the warm (carbon) profiles use just K and
LK.  Neutral and cool profiles will add LC and LM to cool or neutralize
the warm tone of the LK and, more recently also C and M to
cool/neutralize the warm Epson UC K inks (PK and MK).  Sepia adds LM
and Y, in the proportions desired so that when mixed with LK a sepia
tone is obtained.  A "cool Selenium" tone is generated by adding
slightly more LM relative to LC when making a neutral or cool tone
profile.
Carl
>> to be
> only
> From: "Carolyn Frayn" <carolyn@...>
>> still
> a
> blend
>> I was
>> profile.
> Is
>> or
> for
>> read
>> to be
> messages
> tone to
> you'll
> have the
> notice a
> difference in
> paper white.
> Carolyn
