Only one ink working
2005-03-21 by jgm818
I'm using the MIS EZ inks for my C86.  I've done purge tests
courtesy of the downloaded zip files from MIS.  I did all four at
once and each one seperatley and the black cart is the only one
printing.  Any suggestions?
Re: Only one ink working
2005-03-22 by scott_now_coming
Are you using re-fillable carts?
Are these the first carts you've installed (of MIS inks).
Sounds like an air bubble.
Run a nozzel check and if it that doesn't work, let the printer sit
for a few hours and then try again.
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jgm818"
