QuadToneRIP 2.2b for Windows Update
2005-03-21 by Roy Harrington
There is a new update for QTR on Windows.
1) There are a couple of minor bug fixes.
2) 2880dpi is now working.  Caveats:   with so many more
   dots the ink limits must be reduced.  To use 1440dpi profiles
  set the ink limits in QTRgui to -45%.   This will give very similar
  densities.  The other major issue is that it is quite slow and most
  of the time not worth it.   I find the best results on my printer
  by using 1440dpi, better.  1440super is also good but slower.
3) Also all the profiling files are now included in the download.
4) Additionally there is a separate curve making tutorial that can be
   downloaded separately.  It has info that is relevant to both PC and Mac.
Roy
Re: QuadToneRIP 2.2b for Windows Update
2005-03-22 by Johnny Eades
I downloaded the update to QTR and installed it. I had been working
on an image that was giving me trouble with being much too dark in
the print, compared to the monitor. I've started getting quite a few
of those lately, and don't understand why. I was debating what to do
to get a better match when I saw the below message from Roy about the
update. Reading about reducing the ink limit for 2880, and even
though I am using the 1440 profiles; I decided to try just reducing
the ink limit -45 to see if it made any real change in the resulting
print that had been to dark. Well, lo and behold, it now almost
matches the monitor enough that I can pretty much rely on the screen
image to give me almost exactly matching results in the printed
image. If I only could get a densitometer and create the profiles for
my paper/ink combination!!! This will have to do for now, though.
This is the only print I've tried this on, but will try another to
see if it's a fluke or the real deal.
Your friend in Photography,
Johnny
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington"
similar
most
be
and Mac.
> Roy
