Puzzled by PS scratch drives
2005-03-22 by Gary Barnett
I just wanted to second, and perhaps emphasize, what Nick says here about a striped set (RAID level 0). You will get considerably more speed out of Photoshop if you are using a dual channel PCI card (Adaptec makes a dual 320MB/sec SCSI card) that is connected to at least 1 drive per channel, and then formatted as one very fast drive. The drives should all be identical and run at 10K RPM or better. Ideally, if you have the funds, a hardware-controlled (takes the processor time off your computer's hands; not subject to crashes) RAID tower holding at least 4 drives with two inputs (to make use of the dual channel PCI card) will give you about the fastest throughput you can attain, short of fibre channel RAIDs such as Apple and others offer. The scratch file setup can be the weakest link, after processor speed, in attaining maximum efficiency. Using internal IDE or ATA drives is not very productive by comparison. There are actually RAID setups out there that process approx 3 GB per second...for a whole lot of money. They are meant more for real time online video editing, but Photoshop can also take advantage of this kind of system. You don't need terabytes of drive space, just lots of drives striped on two channels. I suppose you could use two dual channel cards, split to two separate arrays, and double your speed again, but that is probably beyond your needs. Some companies, such as Sonnet, make a dual channel Serial ATA (SATA) card that allows you to avoid SCSI obsolence/conflicts. If you use a partition or two on a couple of disks for scratch files, the remainder of those drives should not be under intensive use. The drive should ideally be dedicated only to scratch files, and the remainder partition, if any, to "dead storage" of files unlikely to be accessed while you are in Photoshop. That being said, in no way should work be saved or stored on a striped array. Only scratch files are truly appropriate, because if one drive happens to fail, the scratch files on the array are toast. Using striped arrays therefore makes it imperative that you save your work frequently. Most I/T people prefer RAID 5 -- which requires at least 3 drives and becomes less expensive per GB with more drives within the array...5 drives makes a good setup, with a 6th held in waiting to replace any drive that fails -- or better for this reason. This setup provides speed and safety. Some people like 4 drive setups where two drives are set to RAID 0 (striping) and the other two are set to RAID 1 (mirroring). This is the most economical approach, but not quite as good as a RAID 5 setup. My 2¢ from years of occasionally painful, but mostly satisfactory, experience. Gary > Date: Tue, 22 Mar 2005 20:30:52 -0000 > From: "Nick H. Nugent" <nghin@...> > Subject: Re: Puzzled by PS scratch drives > > > Yes and no. > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale > <stevekale@b...> wrote: >> I'm not a computer engineer but wouldn't it make sense for PS to be >> able to access multiple scratch disks - at the same time? Seems >> that there would not be many situations when more than one scratch >> disk ... is helpful. > > Yes. Maybe someone who knows the inards of PS can tell whether PS > accesses multiple scratch disks on a multiprocessor system. Ideally PS > should be able to parallelize sub tasks for layer groups where > possible (maybe it is already doing it). Perhaps with a striped set > the need to access multiple drives (or partitions) is not that > urgent. > >> ... (being the "media" drive where the .psd ideally resides) > > Ideally the scratch disk should at least be in a dedicated partition > to avoid performance degradation due to drive fragmentation. It should > have nothing except the scratch file. Once PS opens a file it works > entirely off of its temporary image until it is saved (or reverted). > > --nick > > http://homepage.mac.com/barnettart/BarnettArt_Artwork/PhotoAlbum2.html 41° 19' 15" N 74° 17' 09" W [Non-text portions of this message have been removed]
