Re: [Digital BW] Is my cart defective?
2005-03-20 by Steve Kale
I would check the spring on the output port. I had one cart flood all over the table because when I drew out some ink with the bottom fill adaptor it did not spring back properly. Not sure if it's a fix but worth checking. No air should be coming in through that port - only through the small hole at the top of that chamber (under the silver strip when shipped).
2005-03-21 by David Wroblewski
--- Steve Kale <stevekale@b...> wrote: > I would check the spring on the output port. ...[snip]... > No air should be coming in through that port - only through > the small hole at the top of that chamber (under the silver > strip when shipped). I wonder if that is the problem. When I squeeze near the output port, I can see bubbles form inside--but no ink leaks out. This does not happen on all the ez-fill carts I have, but it does happen on more than one, so I've thought it was normal. I'm going to call MIS today and ask if they've seen this before. -david
2005-03-21 by Steve Kale
I have small bubbles in each of my carts - I think you will get some forming as you remove and put back the carts. The question is how many. I tip the cart up and squeeze so that most of the bubbles roll into the filling chamber.
> From: David Wroblewski <dawroblewski@...> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Date: Mon, 21 Mar 2005 12:35:50 -0000 > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Subject: Re: [Digital BW] Is my cart defective? > > > > --- Steve Kale <stevekale@b...> wrote: >> I would check the spring on the output port. ...[snip]... >> No air should be coming in through that port - only through >> the small hole at the top of that chamber (under the silver >> strip when shipped). > > I wonder if that is the problem. When I squeeze near > the output port, I can see bubbles form inside--but no ink > leaks out. This does not happen on all the ez-fill carts > I have, but it does happen on more than one, so I've thought > it was normal. > > I'm going to call MIS today and ask if they've seen this > before. > > -david >
2005-03-23 by David Wroblewski
> I wonder if that is the problem. When I squeeze near > the output port, I can see bubbles form inside--but no ink > leaks out. This does not happen on all the ez-fill carts > I have, but it does happen on more than one, so I've thought > it was normal. > > I'm going to call MIS today and ask if they've seen this > before. Following up on my own post here... I talked to MIS tech support (Rob) yesterday--two things to report: (1) He suggested a possible cause might be that ink dried in the sponge part of the cart, forming a blockage that goofed up the flow of ink in the cart. He also said that letting carts sit half-full in the printer for a couple of weeks without printing daily purge patterns could lead to this. I've never heard anyone suggest this here, though, and it hasn't been a problem for me in the past. I thought the daily purge pattern was only for CIS setups... I'm confused. (2) He had no thoughts on the air bubbles forming in the cart when I squeezed the sides (gently) near the output port. Personally, that looks REALLY fishy to me. Can anyone confirm that this is either definitely normal or bad? There's no ink leaking out, which would of course mean there was definitely a problem. He said they would try to duplicate this but hasn't called back. I'm trying to figure out whether to scrap these carts and order new ones. Again, advice and opinions needed. I hate to just toss carts if they aren't the issue, but I can't think of what else to do. David
