2 Questions | Using MIS Cleaning Cartridges / Warranty Voiding
2005-03-24 by Brian
Hello
I've recently purchased a new Epson 7600. I plan to use the UT7 ink
set. I have two
questions:
1 - Do I need to use the MIS Cleaning Cartridges, even though I have
NOT used the Epson
UC inks?
2 - Will the use of 3rd party ink sets void the Epson warranty?
Thanks in advance for any responses.
Brian.
Brooklyn, USA
PS: I got a great deal on the Epson 7600 from Logix.com.
RE: [Digital BW] 2 Questions | Using MIS Cleaning Cartridges / Warranty Voiding
2005-03-24 by Paul Roark
Brian,
> set. I have two
> questions:
> NOT used the Epson UC inks?
I just purchased a used 7600 that had OEM UC ink in it.  I put the UT7 inks
in directly.  It worked fine.  But, there are some who say that the Epson
inks should be used first to be sure the printer is working.  The cleaning
fluid would not help there.  Some used to claim the OEM inks were better at
cleaning out some substance that was in new printers.  I've loaded other new
Epsons with MIS pigs initially and have never had a problem.
No, they'll just harass you.
Congratulation on the 7600 purchase.  I'm still experimenting with mine to
see what the best approach is.  I've posted some initial RGB curves for the
printer using the Epson driver.
Re:2 Questions | Using MIS Cleaning Cartridges / Warranty Voiding
2005-03-24 by Brian
Paul -
Thanks for the advice concerning my questions. And of course, thank
you for all the great
pioneering work you have done for art of digital black and white
printing.
Brian.
<paul.roark@v...>
wrote:
> Brian,
ink
> > set. I have two
> > questions:
have
UT7 inks
Epson
cleaning
better at
other new
mine to
for the
> Paul
> www.PaulRoark.com
