Re: [Digital BW] Refilling EZ Carts in Printer
2005-03-28 by toliwel@aol.com
Getting the plugs out is something I haven't tried yet! Resetting the chip while in the printer is not a problem since I use the SSC utility. My thought was that refilling in the printer might avoid getting air into the nozzles if the carts were not removed. I did have a heck of a time to get the yellow nozzles to work upon initial fill with the EZs. I find that getting a good connection to the chip can be a problem at times when reseating the cart. I've filled the sponge carts for years while still in the printer. Sooo.. Has anyone tried to refill the EZ Carts while in the printer? Paul, could opening the fill hole disrupt the venting system when the poppet valve is open? Tom Wells
