Epson 2200 & switching inks
2005-03-26 by rbehr2001
I'm currently using an Epson 1280 with UT2 for B&W and a 2200 with
Ultrachrome inks for color. The 1280 seems to have major clogging
issues that I don't seem to be able to resolve.
The question is, since I seldom print color (every couple weeks),
should I buy UT7 CIS inks for B&W on the 2200 and then put the
Ultrachrome back for the ocassional color print or should I get
replacement 1280. The 2200 seems to have less clogging problems and
probably higher quality B&W prints. I think I would go this way unless
there is a problenm with periodic ink cartridge changes.
Thanks
RE: [Digital BW] Epson 2200 & switching inks
2005-03-26 by Paul Roark
I think most of the 1280 problems were cart problems.  If you haven't tried
the new sponge-less carts, that might be the first step.  My 1280 was about
to get thrown in the trash before the new easy-refill, spongeless carts
arrived.  So far, they've been great.
I do not recommend continuous feed systems.  The easy-refill carts for 2200
are also excellent.
> From: rbehr2001 [mailto:rsbehr@...]
> Sent: Friday, March 25, 2005 6:16 PM
> Subject: [Digital BW] Epson 2200 & switching inks
> Thanks
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
1280 w Pigmnet clogs, was: Epson 2200 & switching inks
2005-03-26 by Bob Michaels
"Paul Roark" <paul.roark@v...> wrote: > I think most of the 1280
After singing the praises of the 1280 with pigmnet inks for years, I'm
now wondering if there is some long term use clogging issues with
pigment. Possibly there is some residual pigment build up over time
that accentuates clogs. My original 1280 became more and more prone to
clogs with pigments as it got older. It still cleaned up and worked
well with dye but the pigment probem worsened. I replaced it with a
new 1280 and the probelm went away. Now I'm hearing from others that
are experiencing the same.
Jim Arnold says he now has this problem with his 1280 and is using
carts filled with windex to try to clear it. He's getting globs of
black pigment breaking loose while printing with Windex.
Does any of this match with your experience using the 1280?
I agree that most of the problems are with carts and the new 1280 EZ
fill carts are great. But this doesn't seem to be a cart related
problem.
Bob Michaels
Re: [Digital BW] 1280 w Pigmnet clogs, was: Epson 2200 & switching inks
2005-03-26 by Andrei Aderca
Bob
Your experience matches mine to a large extent, this is one of the
reasons why I upgraded
to a 2200. I used a 1280 with CIS for about 6 months and found the
clogging to get
worse, especially on the black nozzle. Tried every method in the book
with Windex,
also unplugging the CIS and using dye carts to try getting a clean
nozzle check is also
a pain- so I guess that from this point of view, using the EZ fill carts
at least makes it
less painful when you have a stubborn clog. I am not sure either that
the issue is in the
cart design, my 1280 is now retired, I acquired the printhead
installation software but
I'm still considering whether it is worth putting in a new printhead,
given that I would not
use it for anything else except pigment.
The old printhead had build-up on the black nozzle, or spigot, don't
know exactly how
to call that part, but it's a little plastic piece which is cone shaped,
with minute holes in it.
I could not remove it with Windex and really did not want to consider
anything else more
drastic.
I also have a C84 and it seems more robust in terms of clogging,  must
be the printhead
design for Durabrite inks.
Just a silly remark but could be that the spongeless EZ carts keep the
spigots in the head
"whetted" to a better extent than the conventional design.
Andrei
> problem.
> Bob Michaels
2005-03-26 by Steve Kale
For what it's worth I find the MIS magenta UC equivalent inks to be really
bad - both M and LM.  I get continual bad clogs even with the new carts.
The other inks are not nearly as bad.
> From: Andrei Aderca <aderca@...>
> Date: Sat, 26 Mar 2005 09:02:21 -0500
> Subject: Re: [Digital BW] 1280 w Pigmnet clogs, was:  Epson 2200 & switching
> inks
> Bob
> clogging to get
> with Windex,
> at least makes it
> the issue is in the
> know exactly how
> anything else more
> drastic.
> be the printhead
> spigots in the head
> Regards
> Andrei
2005-03-26 by Diane Fields
Just coincidence, but this morning I was trying to get my 1280 back online (I think my USB cable may be bad after reloading the driver and still no success) and the several posts this morning have covinced me to really 'retire' it.  I was contemplating trying some MIS carts, but now I think I will stick with the 2200 which I like very much.
I had not had too many problems with it with OEM inks, but had only kept it going to be able to print once a week or so (until recently) just to keep it unclogged.  I never print with it--if I want a glossy one off for a client, I just print on my husband's networked 875, so was glad to read that others just didn't feel it worthwhile to deal with the 1280 as a pigmented printer.  I had spent time on the MIS page this morning trying to decide the best way to go---but now--its moot.
Diane
  Sent: Saturday, March 26, 2005 9:06 AM
  Subject: Re: [Digital BW] 1280 w Pigmnet clogs, was: Epson 2200 & switching inks
2005-03-26 by Kelsang Drime
This thread has come just in time. I ordered and have received a 1280
to start on my B&W printing adventure, using MIS inks. My plan is to
start BO and then perhaps try the UT2 set at some point.
The 1280 is still in the box. Should I return it?
I bought this rather than the 2200 because of cost but if it is going
to     clog with increasing frequency then perhaps I should rethink.
Maybe go with a C84 until I can afford a 2200.
All input will be gratefully received.
Thanks
Drime
P.S. Don't much care for the new Yahoo look/layout either
"Kelsang Drime" <kdrime@h...> wrote:. The 1280 is still in the box.
Should I return it?
I would suggest using it. If it develops the problem we are
discussing, you will have gotten a few years use out of it, spent 2X
what you paid for the printer on paper and almost as much on ink. At
the price they are a great deal even if they only last a few years.
And the prints are great.
Also consider:
1) this potential problem may or may not be real. Don't draw firm
conclusions from a few posts (including mine)
2) if real, they may be a solution.
Bob Michaels
I will say that I tend to agree with that.  I used mine for color printing for a number of years (OEM inks) --printing many hundreds of prints--and now (I finally got it printing again--reinstalled driver yet again) I have a very persistent clog.  Not sure I will worry about it and just retire it, but I loved this printer for a good number of years.  And--they are really reasonably priced now--altho' they look different than mine (is this what is being referred to as the 'silver' 1280--the new one??)
Diane
---- Original Message -----
  Sent: Saturday, March 26, 2005 10:22 AM
  Should I return it?
  Also consider:
  Bob Michaels
2005-03-26 by Steven Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Kelsang Drime"
1280
to
going
rethink.
> Thanks
Drime;
I used a 1280 with pigments for about a year; my opinion is that the
majority of the 'clogs' are due to those miserable foam-filled carts
that are virtually impossible to get air bubbles out of after the
foam has built up. Buy a couple sets of the new 1280 carts if you
haven't already, and if you have a clogging problem, you can fill
one with cleaning fluid if need be. Most will disagree with my next
suggestion, but I'm of the opinion the OEM dye carts should never
even touch the machine if you're going to put pigments in it. Mixing
the two may be a bigger source of trouble than we think.
Steve Karafyllakis
2005-03-26 by Drime
Dear Steve,
I have the new carts. It was and still is my intention to load the
printer with MIS inks from the very start. In fact that was going to
be my next question!
Thanks
Drime
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
> Steve Karafyllakis
2005-03-26 by John Vitollo
Keep it and use it. Maybe don't buy the CFS at first, but go for the refillable carts. If there
is a problem clog that can not be fixed, within the first year, call Epson to exchange it for a
new one.
I have a 1280 and it works very well and not temperamental at all. My 1280 got off to a
shaky start because of a bad CFS but MIS resolved the problem and have very few clogs.
2005-03-26 by Stephen Veillette
I bought a new 1280 a few months ago and loaded it with UT2 inks straight away... gave
the OEM inks to a friend who prints color.  I have subsequently switched to UT-FSN, and I
have not had any problems-- the nozzle checks are perfect every time, even after sitting
unused for a week or more.
My old 870 had issues.  First, it was old.  Second, I had used the Epson OEM inks in it first,
then the Lyson Quad Black inks, then finally the MIS QVM inks.  Towards the end, I pretty
much had to clean the heads any time I wanted to print.  It even had a total meltdown a
while back where nothing would come out of the print head... took it out, cleaned it
thoroughly, and reinstalled it... even used the Epson maintenance program to re-align
everything.  It worked great for a while, but then it started flaking out again.
I think the ink-mixing theory has merit, though my 1280 is still very new and it's not really
a valid comparison, but my experience with the 870 makes me believe this.
-Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Drime" <kdrime@h...> wrote:
> Dear Steve,
> Thanks
> Drime
> > Steve Karafyllakis
I'm wondering, after reading several threads (now that I have my old 1280 printing correctly again) if, since I used OEM inks in it for years, if it will work reasonably successfully with the MIS carts--or if I'm better off to stick with my 2200 and QTR.
Diane
  Sent: Saturday, March 26, 2005 11:32 AM
  -Steve
2005-03-26 by bfwoolner
My refurbished 1280 has been clog and otherwise trouble free using MIS UT
and UT2 inks.  I've been using it for 11/2 years.  I've used MIS filled
carts and filled my own using both the UT and UT2 inks.  Never a problem.
Barbara
Sent: Saturday, March 26, 2005 7:01 AM
inks
Thanks
Drime
page.
them short.
the membership.
Yahoo! Groups Links
I have not used them myself but from what I understand, Lyson inks have
a different pH so
flip-flopping without using the cleaning fluid would be a problem. As
far as using OEM dye carts
to try getting rid of a rebel clog, I think that the solvent in the dye
inks is actually the one doing
the heavy-duty work. I am not sure what solution is used to dilute the
pigments but it seems to be less
effective in that task.
Andrei
Steven Karafyllakis wrote:
> Drime;
> Steve Karafyllakis
even touch the machine if you're going to put pigments in it. Mixing the two
Sent: Saturday, March 26, 2005 7:47 AM
inks
An addendum to my last post - I never installed the OEM dye carts in my 1280
before using the MIS inks.  May be a key as Steve suggests.
Barbara
< I'm of the opinion the OEM dye carts should never
may be a bigger source of trouble than we think.>
<Steve Karafyllakis >
page.
them short.
the membership.
Yahoo! Groups Links
That's what I keep reading.  My 1280 has been around a good long while--can't remember when I got it, but its been used quite a lot until I bought the 2200 over 2 years ago and its not been used too much since--but, of course, was used with OEM inks all that while.
Diane
  Sent: Saturday, March 26, 2005 11:51 AM
  inks
  Barbara
RE: [Digital BW] 1280 w Pigmnet clogs, was: Epson 2200 & switching inks
2005-03-27 by Seth
Run cleaning fluid carts first, even though MIS says you don't need to.
Even Windex-filled carts.
Then switch.
Seth
==-----Original Message-----
==From: Diane Fields [mailto:picnic@...]
==I'm wondering, after reading several threads (now that I have
==my old 1280 printing correctly again) if, since I used OEM
==inks in it for years, if it will work reasonably successfully
==with the MIS carts--or if I'm better off to stick with my
==2200 and QTR.
==Diane
2005-03-28 by Thomas Keesling
I wouldn't. I just bought my second 1280 to use with UT2 inks. My original
1280 is over four years old and has seen moderate use over that time with
only pigment inks. The failure, when it came, was apparently due to a
circuit board problem according to members of this group who had previously
experienced the problem I'm now seeing. Until this problem cropped up, this
printer was performing nearly flawlessly. That's why I bought another and
plan to transfer my old CIS with UT2 inks from the old to the new one.
Tom Keesling
Intelligent Design
