Re: Tri-X's grainy scans
2005-03-30 by Gary Barnett
Hear, hear! I shot almost nothing but Tri-X in the '70s and kept
banging my head against the wall whenever I enlarged to 16x20. I was
not into grain. What I really should have been using was an 8x10, which
I eventually picked up. However, in hind sight, the grainy quality of
those Tri-X images has turned out to be part of the charm. If you scan
Tri-X and attempt to make it look like T-Max or better, you will need
to enlarge those scans on screen and blur out every piece of grain
manually...not recommended for the faint of heart. My film scanner has
the ability to set a negative USM value (-60 out of ±255 is
recommended) and also allows for defocusing the lens (it's an Imacon
Flextight II) by a tiny amount, and between these two settings I can
minimize the grain to some extent without losing sharpness discernably.
There's even a proprietary noise option that tends to smooth out
clumping in the grain if used properly. Then USM in Photoshop seems to
take up the slack.
But in the long run, the question really is why? Grain is in our
heritage, like monotypes, glass negatives, etc. Just because a great
digital camera can be set to avoid generating noise does not mean that
our B&W history should be re-written. I always shot my Tri-X at ASA200
AND overdeveloped the film, after I realized the grain was truly a
wondrous feature. One of the best rolls I ever shot was left in
overheated developer by mistake, looked nearly solid black, made for
very long exposure times under the enlarger, and produced some wedding
shots that drove my brother in law nuts with delight! So I left the
Plus-X for the 8x10, and got to have whichever effect I wanted without
bruising my head anymore.
BTW, does anyone have a great method for scanning 8x10 negs on a
flatbed? I use the Linotype-Hell Ultra Saphir 2 with Silverfast AI 6,
but there seems to be a problem with horizontal banding (or even thin
lines) when I try this (I'm at novice level with this software, to make
things worse). My Imacon, unfortunately, goes up only to 4x5. I
couldn't afford the big one that handles 8x10. For now, I have been
sending out my 8x10s for drum scans, which is fine but expensive. Any
advice...I think I saw some ideas about wet-mounting...would be
appreciated. I am wondering if the banding is indicative of poor or out
of adjustment mechanics in the transparency adapter because it never
happens with reflective art.
Gary
> Message: 18
>    Date: Tue, 29 Mar 2005 20:14:40 -0700
>    From: "Mike Johnston" <wpajohnson@qwest.net>
> Subject: RE: Really Grainy Tri X scans
> You could treat the quality as a feature instead of a problem.
> Mike J.
2005-03-30 by lulalake_1999
Gary,
The new Epson 4990 has 8x10 trannie scanning capability. I don't know
about the quality but the 4x5 scanning on the 4870 is excellent, so
this may be worth investigating.
Jules
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Gary Barnett
was
which
of
scan
need
has
Imacon
can
discernably.
to
> take up the slack.
great
that
ASA200
for
wedding
without
6,
thin
make
Any
out
never
> Gary
> > Message: 18
> >    From: "Mike Johnston" <wpajohnson@q...>
> > Mike J.
Re: [Digital BW] Re: Tri-X's grainy scans
2005-03-31 by Leslie Otterbein
Gary:
I have the same machine and I use Vuescan, on a Mac OSX10.2.8. You
could try that program for free, just to see if it bands.
I have scanned B&W 4 x 5 negs with this machine but do not recall
seeing any banding.
Leslie Otterbein
