old soft-proof curves?
2005-04-01 by avellan67
Hello everyone,
Just today I tried starting to use the soft-proofing features of QTR
2.1. However, the install
script did not install the .psf files. I tried to do it manually
through Photoshop CS but it
says that it cannot because "this file is not compatible with this
version of Photoshop".
When I say manually I mean I went to "view-setup-load". I am running
a G5 with 10.3.8
and using the UT2 inks on a 1280.
I found on Roy's website an install script for the 1270 UT2 inks and
those worked but I
rather not use those because it doesn't have the lustre psf's.
Also to note. originally when I looked into the profile folder on the
.dmg folder for the
1280 the files were text files not .psf's. I figured they were
downloaded wrong so I
changed the suffix. Either way it doesn't work.
Can someone help out?
Thank you.
