Re: [Digital BW] Quad loaded made a print..think I did something wrong
2005-04-03 by Diane Fields
Okay, Ann. Hope this will help. First of all---the ICC profiles should be (for windows) in the windows folder (should be available in your dropdown if it and the other 2 ICC profiles--gray-matte and gray-photo--were placed in your C/Windows/system 32/spool/drivers/color). Process your print in PS, convert to gray-LAB. Now, you can softproof this by going to view/proof setup/custom and in 'profile' browse for the QTR-gray matte, set your intent to 'perceptual' and check 'ink black'. You will def. see a difference--and it probably will be 'flatter' looking. So--here's where you can tweak--add an adjustment layer of curves perhaps, dodge and burn-- (new layer/overlay check 18% gray and use your black and white brushes at about 7-9% opacity) but as far as tonality/contrast, wysiwyg (what you see is what you get)--but not as far as the 'color tone' though. As far as the profiles, did you put them in C/program/Quadtone RIP/profiles/2200-uc? I think you are printing with a 2200 and OEM inks--not sure. If so, this is where they should go and they will show up in your dropdowns for your curves. Diane
----- Original Message ----- From: montauklady To: DigitalBlackandWhiteThePrint@yahoogroups.com Sent: Sunday, April 03, 2005 2:02 PM Subject: [Digital BW] Quad loaded made a print..think I did something wrong I made a print in QTR..print looke good..a little warm..then I re-read the instructions and saw I was supposed to first change it into photoshop to grey scale from RGB. I did that and the print was terrible..flat no contrast. How am I supposed to use the grey space zip file which contains gray matte icc, gray photo icc, rgb lab icc...etc.? They were moved to the QTR folder. Also I downloaded the curves for various papers, extracted them into QTR, but I do not see them pop up in the GUI interface. What am I doing wrong. As always thanks for your support..Ann [Non-text portions of this message have been removed]
