tricks to reduce photoshop file size?
2005-04-05 by daniel
like many of you, i suspect, i store the photos i've worked on in photoshop format so i can
retain layers, etc, and readjust them easily later. but this creates huge files. the worst
discrepancy is for a jpeg that was taken as jpeg and not raw; the file often grows to 30MB
or more for a 6MP image.
my intuition -- and i'll admit i haven't checked the numbers -- is that this is much more
space than should be needed, even ignoring the effect of jpeg compression. hence my
question: are there some tricks people use to reduce the file size? yes, i know storage is
cheap, but using lots of unnecessary space has its costs (eg, in time spent backing up).
obviously, i don't want to lose information by reducing resolution. but i'm assuming that
much of the growth is because photoshop is caching information that can be deleted. for
example, if i have all my work in layers, i'm usually happy to clear the history, and
presumably a long history takes a lot of space. are there other things like this?
i wonder whether maybe photoshop itself is not well designed in this regard? a curves
layer, for example, shouldn't require more space to store than the amount of data entered
when you design the curve -- a few bytes for a couple of points -- as it should be able to
recompute the effect of the curve from its specification. it seems not to do this, however.
any thoughts?
/daniel
RE: [Digital BW] tricks to reduce photoshop file size?
2005-04-05 by Paul Roark
Daniel,
> ... i store the photos i've worked on in photoshop format so i can
> files. ...
I'm a contrarian here -- the fewer layers the better.  I always store the
files in un-compressed Tiff (or sometimes Photoshop) format, with the fewest
layers possible.  On the other hand, I'll have multiple older drafts and the
original scan available to go back to whenever I want.  The old draft may
have a few layers and masks that I can also pull when needed.
To be sure the information is easily accessible from the older drafts, I
avoid re-cropping or re-sizing the image after the original scan, until I'm
ready to print.  This allows the clone tool to be easily aligned at (0,0)
(top left corner) with a 1 pixel brush size.  (It's even easier in Picture
Window than Photoshop.)  Also, masks can be pulled from the same-size older
drafts.
2005-04-05 by Paul D. DeRocco
> From: daniel [mailto:dnj@...]
> things like this?
If it's disk space you're worried about, just compress the files--they
should be highly compressible. In Windows, on an NTFS file system, you can
just set the compressed property of the file (under the Advanced button), or
of the folder that contains them.
