Re: [Digital BW] Re: Matte Black Ink and QTR.....Compatible?
2005-04-07 by Diane Fields
Steve, it doesn't matter there.  If you use the gray-matte profiled image, then that takes care of it.
Diane
  Sent: Wednesday, April 06, 2005 10:43 PM
  Subject: [Digital BW] Re: Matte Black Ink and QTR.....Compatible?
  I guess the second part of my question is...if the Matte black
  cartridge can be used, how do I choose it on the QTRgui?
I should have said---just switch your carts.  If you want to check to make sure its selected you need to open the driver, go to the maintenance tab and click on 'printer and option information' and you will see the matte black cartridge selected.  QTR doesn't need to be told you are using the matte black--it 'assumes' so LOL--if you are using a matte paper--and select the 'gray-matte' converted image.
Diane
  Sent: Wednesday, April 06, 2005 10:51 PM
  Subject: Re: [Digital BW] Re: Matte Black Ink and QTR.....Compatible?
  Diane
