Can this be done with the QTR?
2005-04-14 by SteveZ
I have a sepia image I wanted to print with the QTR, can this be
done? When I convert the profile to gray matte, the image turns black
and white. The other option is to print it out the image using a warm
curve which I've tried but it doesn't look very pleasing.
Re: Can this be done with the QTR?
2005-04-14 by Scott Graham
There are sepia curves too.  So put a cold (or even warm) curve in the first position and the
sepia one in the second position and try different mix %'s.
Though I'm not sure how well they match a darkroom sepia which is what I presume you
are referring to.
Also on the QTR group we are in the midst of a discussion on editing curves to get the
color that you want, very cold black in my case.
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "SteveZ" <blizzie12@y...> wrote:
2005-04-14 by donbga
Scott,
curves to get the
What QTR group?
Don Bryant
http://groups.yahoo.com/group/QuadtoneRIP
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "donbga" <dstevenbryant@m...>
wrote:
> Scott,
> curves to get the
> What QTR group?
> Thanks,
> Don Bryant
2005-04-14 by Djon
Do you mean the entire B&W image is "sepia,"...all sepia, no black,
like extremely faded old photos?
Or do you want a conventional sepia-toned B&W  with real black and
sepia-toned greys on white? Or something else?
If you want photographic sepia-toned B&W (with real black) it's easy
as pie with QTRgui... precisely matching your original if you choose
the right paper.
If you don't want any black, just something in a sepia/brown/yellow
range on white paper of your choice,  you should be able to match
precisely, by eye and test-printing, using standard Epson printer driver.
> done?
