What RIPs are available for the Epson 4000?
Re: What RIPs are available for the Epson 4000?
2005-04-17 by richard_h95050
Hi Myron,
QTR is heavily supported in this forum and will give you the results
you want with the 4000 and UltraChromes. You can download it from:
http://harrington.com/QuadToneRIP.html
There is also a QTR Yahoo forum at:
http://groups.yahoo.com/group/QuadtoneRIP/
It produces excellent results and is shareware -- try before you buy
and the price is only $50 which is a far less than its value!
Also IJC/OPM has 4000 support -- costs a bit more but the UI is a bit
more developed for profiling. It's $250 and you can read more at:
http://www.bowhaus.com/services/IJCOPMmain.htm
IP is an acceptable solution for basic B&W output from the
Ultrachrome ink set -- however, it is a "closed system" to the user
and won't grow with you as your expertise increases because you are
locked into the IP profiles that you can't really modify to your
environment. Plus, it's pretty expensive for what you get.
Try QTR because you can download it, install it and be up and running
today -- or this evening ;>) That way you don't get too caught up in
all the choices out there, can get started printing instead of
pondering and may very well find QTR to be your long term solution!
Enjoy!
Richard
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Myron Wellan"
<mwellan@b...> wrote:
> Just purchased an Epson 4000.  Besides Image Print, are there any
other
> options to use to obtain castfree B&W  printed images?
> Thanks
