DMax Epson 4000 vs Epson 7600 (9600)
2005-04-24 by Shilesh Jani
Yesterday I read a message on this forum (I forget in what context,
or by whom) that suggested the 4000 was weaker in black density than
the 7600 class printers.  It just so happened that I was helping a
friend write QTR profiles on various papers for his 7600 loaded with
OEM UC inks.  I own a 4000 also loaded with OEM inks.
The bottom line:  The 4000 and 7600 (presumambly 9600 also) are for
all intents identical in the DMax achieved with OEM Matte Black inks.
The test was conducted with good ol' EEM paper.  I used a Heiland
Electronics PM-Densitomemter in reflective mode.  On EEM both
printers were hitting ~1.67 DMax.
One important difference between my 4000 and my friend's 7600 is the
ink limit at which the maximum DMax was achieved.  The 4000 maxed out
at ~70% black density, while the 7600 maxed out at ~50% black
density.  It takes a RIP to properly characterize the appropriate ink
limit for each color.  I used QTR for my test.
There are valid reasons for choosing a 7600 (9600) over a 4000, but
DMax is NOT one of them.
Happy printing.
Shilesh
Re: DMax Epson 4000 vs Epson 7600 (9600)
2005-04-24 by Louis Dina
Shilesh,
I also own a 4000.  I agree that with QTR, you can achieve a great
Dmax, and mine also hits Dmax at about 65-70% on EEM.  No problem
there.
Using the Epson driver however, there is a problem getting good Dmax
out of the 4000 for color or B&W on matte papers.  At least on my
4000, the Epson driver seems to impose premature ink limits,
regardless of which matte paper setting I use.  I tried them all, and
I find that blacks are a bit weak compared to using the Epson driver
with my 2200.  All targets were read with a spectrophotometer.  I
think the reference to weak blacks was when using the Epson driver
with MIS quad inksets and matte papers.  I'd have to agree based on
my tests thus far.
On glossy papers, though, I find the Epson driver on the 4000
delivers great Dmax, (B&W and Color), which is even better than my
2200, which was very good.  I'm sure this has to do with the ink
limiting built into the various Epson driver settings.  I wish I
could figure out how to get the Epson driver to pump out a little
more ink with the various matte paper settings.
So, unless I can find a way around this driver/matte paper setting
limitation, I believe I will need a B&W or Color RIP solution to get
the most from matte papers using the 4000.
Maybe others find this doesn't agree with their experience.  If so, I
would love to know what you may be doing differently.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Shilesh Jani"
than
with
inks.
out
ink
> Happy printing.
> Shilesh
Louis,
I just tested out printing with the Epson driver.  Lo and behold,
you're absolutely right.  Using various approaches, I am hitting a
Dmax od only ~1.56 on EEM.  What gives?
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Louis Dina"
<lbdina@c...> wrote:
> Shilesh,
> there.
Dmax
and
driver
> my tests thus far.
get
I
> Regards,
> Lou
context,
> than
a
> with
for
> inks.
> the
> out
> ink
but
> > Happy printing.
> > Shilesh
Shilesh....
What's Up?  IMO, Epson has their head planted firmly up their kazoo.  I
have tried to get help, but they are worse than useless.  Epson builds
their ink limits into the driver's paper settings, and for whatever
reason, they set the ink limits too low on the matte paper settings in
their driver.  From what I can tell, all the matte choices are all on
the low side.  The glossy settings work fine and give great Dmax on my
printer.
The printer can spit out enough ink, as proven when printing an ink
limit chart from QTR, but the settings Epson programmed into driver are
the limitation.  So, if I want better Dmax and gamut on matte papers
using color inks, that means I have to spend more money for a RIP that
can control ink limits (ie, NOT ImagePrint, since it hard codes ink
limits into the inkset.  Perhaps the full verson of ColorBurst - not
the Epson version, or StudioPrint).
Paul Roark suggested another possible workaround, but I haven't tried
it.  Put Eboni black ink into a refilliable PK cartridge and put it
into the PK slot of the printer.  Then, tell the printer you are
printing on glossy stock and use a glossy paper setting.  Not sure if
this will work or not.  The 4000 has more sensors than Carter has
pills, and it may be able to sense the paper type.  Not sure about that
either.
My 2200 gets better Dmax on matte paper with the Epson driver than my
4000 does.  But, the 4000 does better on glossy papers than the 2200.
How about sending an email to Epson asking for an update to the driver
that allows more ink to the matte papers?  I'll do the same.
Lou
> Louis,
> Shilesh
2005-04-24 by scott_now_coming
Hi Lou,
I'm curious if you've ever check the Dmax of a b.o. print from your
4000.
(I know you use IJC and would like to thank you for writing that
tutorial. When I purchase my next printer, I'll probably go with IJC.
Thanks Lou.)
Scott
> Shilesh,
> there.
Dmax
and
driver
> my tests thus far.
get
I
> Regards,
> Lou
context,
> than
a
> with
for
> inks.
> the
> out
> ink
but
> > Happy printing.
> > Shilesh
