How Many Shades Of Gray - Dotless and Smooth Prints?
2005-04-24 by Shilesh Jani
Many on this forum use QTR on Epson UC printers (2200, 400, 7600, 9600) using OEM inks. We know that the "warm" profiles use only the black and light black inks, while the toned prints additionally use various mixtures of light cyan, light magenta, and yellow. Because density across the 0-100% ramp is built up primarily from two desnity inks, QTR OEM ink prints in general will be less smooth and more dotty in highlights. This is only true at VERY close viewing distances and of no consequence for a print hanging on the wall or even prints viewed on had at half arm's length. Sadly I am one of those "print to the nose" guys (perhaps I need to get a life!). So what does it take to get better prints? The original Piezpgraphy (and now PiezoTone) and MIS FS inks use 4 shades of gray (black, dark gray, medium gray, and light gray) to produce the absolute in ramp smoothness and dotless in highlights. I asked myself is this necessary? The approximate ink density relative to black for Piezotone and MIS FS inks are: Black = 100% Dark Gray = 55% Medium Gray = 10% Light Gray = 5% In contrast for Epson OEM Matte inks Black = 100% Light Black = 35% I have MIS FS inks loaded on a 1280, and went about creating QTR profiles using the following inks: (1) Full spectrum (quad tone): Black, Dark Gray, Medium Gray, and Light Gray. (2) Partial spectrum (tritone): Black, Dark Gray, and Medium Gray On the 1280 (and presumably other newer printers that are smaller than or equal to 4 pL droplet size): The tritone prints are just as smooth and dotless as the quad tone prints. Both are better (very, very slightly) than QTR prints uisng OEM inks. My guess is that the Light Gray (5%) ink was essential in the older Epson 3000 printer which has a much larger dot size. This has an important upshot, but only for advanced users who know how to write profiles with QTR (or other RIPs which allow individual ink control). The Piezotone inks are available in a number of hues (warm-neutral, cool-nuetral, cool-selenium, and sepia). The ability to make decent prints using only 3 inks allows users to combine the hues in a single printer. In contrast, on a 1280 using InkjetMall's Piezography ICC approach, one is stuck with a single hue. The 1280 is a 6 color printer and so it is possible to load black + 2 hues (say cool-seleniun AND warm-nuetral) of Dark Gray and Medium Gray. With this approach you have a redundant ink position which can be some sort of a toner, or used for full spectrum quadtone. For this option you would need to fill your own cartridges or create a custom loaded CIS unit. On the 2200, 4000, 7600, etc which are 7 color (neglecting the glossy Photo Black of the 4000), the upshot actually is very promising. You can load THREE hues of PiezoTone inks. InkjetMall offers 2 hues for these printers. But because the light density ink appears to be superfluous, a custom approach will allow 3 hues and countless mixing between the hues. Regards. Shilesh
