My first QTR paper curve---HELP!!
2005-04-24 by Johnny Eades
I finally got a densitometer and am in the process of creating my
first paper curve for Epson Heavyweight Matte paper(Neutral curve)
and MIS UT2 inks and an Epson 1280 printer.
I have charecterized the inks and found the black maxed out at 60%
ink when printed at 100% ink in the first pass. I am now at the stage
of just after printing the second calibration chart at that 60% and
have read the ink densities of each ink position. The results are:
K=1.56
C=1.13
M=1.09
Y=not used
LC=.96
LM=.97
From the help file "This process is repeated for each lighter ink,
comparing it to the next darker ink, calculating its density relative
to that ink and then converting it to a density relative to the
darkest ink. Record these values in the appropriate ink density box."
This is where my logic fails me. In the curve creator how do I
determine what density percentages to enter? I know there are many
who have created these curves, so could someone fill in the missing
information for me after telling me the method of determining the
density percentages? I would really appreciate all help from soneone
who has surmounted this step.
Your friend in Photography,
Johnny
Re: My first QTR paper curve---HELP!!
2005-04-24 by Shilesh Jani
Johnny,
It took me a while to figure out the madness.  Using your C=1.13 as
an example:  Go to the 21 steps of the black ink, and find which step
gives you d=1.13.  You may not find an exact match; you may find that
on the black ink steps X%=1.00 and X+5% is 1.2.  That means the true
value is somewhete in between.  Using the above as an example, it is
closer to x+5%, so I would type in X+4% as a SWAG.  It does not have
to be absolutely accurate.  You will be linearizing the whole mess
later on anyway.  This step just determines the amount and location
of overlap of adjacent density inks.
Hope this helps.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Johnny Eades"
stage
> K=1.56
> C=1.13
> M=1.09
> Y=not used
> LC=.96
> LM=.97
relative
box."
soneone
> Johnny
Thanks Shilesh,
I had partly thought this would be the procedure but the more that I
thought the more confused I got. I gues that is part of the reason
for this newsgroup. Group help...
Thanks again,
Johnny
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Shilesh Jani"
<shilesh.jani@s...> wrote:
> Johnny,
step
that
true
is
have
> Hope this helps.
> Shilesh
curve)
60%
> stage
and
> > K=1.56
> > C=1.13
> > M=1.09
> > Y=not used
> > LC=.96
> > LM=.97
ink,
> relative
> box."
many
missing
> soneone
> > Johnny
Re: [Digital BW] My first QTR paper curve---HELP!!
2005-04-24 by Daniel Staver
The numbers are written on the inkseparation image. If 100% M has the
same density as 43% K then the number for M is 43. In other words you
move up or down the K scale until you find a patch that matches the
density of 100% of the ink you're working with. That K percentage is
your value. Repeat for the other inks.
Like with the ink limits there is plenty room for error here. An
approximate guess is enough. The linearization will take care of any
remaining problems.
Daniel Staver
http://daniel.staver.no
> K=1.56
> C=1.13
> M=1.09
> Y=not used
> LC=.96
> LM=.97
2005-04-24 by Louis Dina
Daniel,
Now I am a little confused.  I am using the UC inkset in a 2200.  Are
you saying the density of ALL INKS relate back to equivalent K patch
with the same density, regardless of color?  I was under the impression
(perhaps a false one) that you would do the following:
LK density is based on the density of the equivalent patch of the K ink.
C, M and Y inks would not have any density input (left blank).
LC density is based on the equivalent density patch of the Cyan ink.
LM density is based on the equivalent density patch of the Magenta ink.
Is this right or wrong?
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Daniel Staver
> remaining problems.
> Daniel Staver
2005-04-25 by Daniel Staver
You do this for every ink that you want to be part of either the Gray
curve or the Toner curve. Also, for the new version that's coming you
will have a second toner curve.
The darkest ink in each of those curves will have 100 as a value, and
then the next darkest ink is measured in relation to that.
For the UC inkset you're correct to assume that the K and LK ink would
be part of the gray curve. There's nothing that says you would also use
it for LC and LM however. Unless you made a toner curve consisting of M
and LM, then you would use 100 for M and measure LM in relation to M.
The UC curves usually works a bit differently in that the toner inks
have no values of their own, they're just copied from the LK ink and
then the strength of the LC, LM and Y inks are controlled by setting
their ink limits.
For other inksets different inks are used. For the UT7 inkset we use K,
C and LC in the gray curve and M and LM in the toner curve.
Daniel Staver
Louis Dina wrote:
> Daniel,
> Thanks,
> Lou
2005-04-25 by Steve Kale
Lou
You should print the UC separation page and then compare the density of the
LC/LM(/Y) mix (the last "ink" printed) with K.  In essence, you have just
two "inks" which are being used for the greyscale: K and the combined
LC/LM(/Y).  You determine where LC/LM/(Y) partitions with respect to K.
Steve
PS:  I will email you separately the UC Ink Separation page.  In a multiple
grey ink setup the numbers are always linked back to grey.  Grey1 is x% of
K.   Grey2 is y% of grey1 and so is x%.y% of K etc
> From: Louis Dina <lbdina@...>
> Date: Sun, 24 Apr 2005 21:13:32 -0000
> Subject: Re: [Digital BW] My first QTR paper curve---HELP!!
> Daniel,
> Thanks,
> Lou
Sorry I should have typed LK/LC/LM/(Y).  It is the combination of all three
(or four) of these that is measured vs K (which at its particular ink limit
is 100%).
> From: Steve Kale <stevekale@...>
> Date: Mon, 25 Apr 2005 10:01:27 +0100
> Lou
> Steve
>> Daniel,
>> Thanks,
>> Lou
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the membership
> without notice.
> printing. Users who persistently make off-topic posts may be removed from the
> membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See „Group Topic, Rules and Guidelines‰ in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE „OWNER‰ AND
> „MODERATORS‰ OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  „OWNER‰ AND „MODERATORS‰ OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
> DIGITAL BW, THE PRINT YAHOO GROUP.
> is 100%).
You don't measure LC/LM/Y in relation to K for UC inksets. It's enough
to measure LK. LC/LM/Y will automatically get LK's curve, and then you
adjust the tone by setting the ink limit for each of those inks.
Daniel Staver
2005-04-25 by Louis Dina
Thanks, Daniel.  That makes it clearer.
BTW, I do have some UT7 inks in my 2200 now (Windows XP platform).
Are there any good QTR profiles built for this inkset that I can get
my grubby little mitts on?  I am trying to learn how to build good
profiles with QTR for this inkset, use toners, etc.
Lou Dina
lbdina@...
Gray
you
and
would
use
of M
M.
inks
and
setting
> their ink limits.
use K,
> Daniel Staver
> Louis Dina wrote:
> > Daniel,
Are
patch
impression
K ink.
ink.
Magenta ink.
> > Thanks,
> > Lou
I've made a few that's working great for me, but others say that they
block up in the shadows. They should work well as a starting point
anyway. You can download them here:
http://download.petraflux.com/qtr_ut7_profiles.zip
It includes cool, carbon and sepia profiles in both .quad and .qidf formats.
They're designed for EEM with Eboni black ink.
I also have UT7 curves for PKN in the black position and GLOP in the
yellow position.
Daniel Staver
Following a dialogue I had with Roy, he sent me an Ink Separation chart
which adds a UC_Neutralizer line.  It is really very handy for determine the
hue of the adjusted LK and for then doing the partitioning based on the
actual combined "second greyscale ink".  If you want the revised ink
separation chart let me know.
> From: Daniel Staver <daniel@...>
> Date: Mon, 25 Apr 2005 12:29:21 +0200
>> is 100%).
> Daniel Staver
Sure, it would be interesting to have a look.
Did you notice a difference in the curve after the linearization when
doing the partitioning this way? In my experience it seems like exact
partition values arent very important as long as you linearize.
Daniel Staver
Can I use a Photo 900 as a 1280?
2005-04-25 by Seth
Hi all-
I just got an Epson Photo 900 out of storage (I forgot about it).
In as much as it uses the same cartridges as the 1280, I know I can get the
B&W inks.
The question is can I use the 1280 settings in QTR to control the printing?
Seth
Done.  The difference in linearization falls generally within the limits of
"rough approximation" that can be largely eliminated by the Linearize
function although I guess at some point you are banging a lot more workload
onto this function.  But for hue it is very useful.
> Daniel Staver
