R800 and black and white
2005-04-25 by Daniel Ridings
I usually use a C86 with MIS UT EZW inks for A4 prints.
But I have this R800 sitting around and I hardly ever work in color. I
don't do digital capture. I scan b/w negs.
So I got curious.
Mode -> greyscale
Mode -> assign profile Gray 2.2
Print with preview. Document source Gray 2.2, Print Space as source
In the Epson driver I set ICM and then turned off further conversion
(just pass it through).
It was a little too dark. Warm, but too dark.
I piffed up the brightness in Photoshop (+5) and tried again.
Not bad. Not bad at all. I'm printing on Epson Premium Glossy. I wanted
to see a glossy print, that's why I even bothered with this. I have the
CIS with Eboni black so glossy is usually not an option on the C86.
You might want to give it a try. I suspect the Kirkwood everyone is
pleased with would work quite well also.
Daniel Ridings
http://www.dlridings.com/paw2005/16.html
Re: R800 and black and white
2005-04-25 by scott_now_coming
Danial,
I printed a few b&w with my R800 also.
If I could get rid of the cyan cast, they would look awesome (I did
use the Kirkland, btw).
I think this printer has great up-side potential for B&W printing.
I hope someone makes a "rip" for it. IJC, QTR, .......
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Daniel Ridings
color. I
> So I got curious.
> Mode -> greyscale
conversion
wanted
> Daniel Ridings
Re: [Digital BW] Re: R800 and black and white
Scott, don't use the Epson color controls (= cyan). Choose ICM and then
"not color conversion" (after using Print preview, Gray 2.2 source and
print space same as source). Jack up the brightness +5 before you get
that far ... and see what you get.
I get warm pictures, not cyan. Quite pleasant, actually.
Daniel
scott_now_coming wrote:
> Danial,
