Change Over
Change Over
2005-05-08 by Peter Mc Mahon
Paul,
thanks for your quick response and I follow your comments. However, like
all technology, things are moving on quickly. I am a high end amatuer
photographer, who enjoys being able to print my own images, for
exhibition and personal use. I also don't produce a great volume, 300
-400 A3 a year.
 My reason for saying this is, do I carry on with my 1160, or put my
energies into the 2100[2200]? I enjoy the 1160, MIS VM,  nice images, a
little slow by comparison to 2100. I have a 2100 that I use for my
colour and recently some BO prints.
Is technology, user input, printer quality, favouring the 2100.[UC or
Carbon] for B&W over printers like the 1160? because they actually or
potentially produce better prints?
I have just installed QTRgui and not being a techno buff, I like the
user friendly concept, but it is noticable, that the  setup seems to
favour printers like the 2100 more than the 1160 with the range of made
profiles.
Living in New Zealand, the other side of your world, any change is
considerable, as most of what is required, I have to import. I don't see
that as a major, providing I can see good reason.
So, the extension to my first mail is,
 do I change my 1160 MIS VM setup to the UT or....................???????
Trust you are able to fill in some knowledge gaps, in assisting with my
decision.
once again thanks,
Peter.
Subject: RE: change over procedure
Peter,
The UT inks are the replacement for the VM inks.  I made some UT curves for
the 1160 also.
In general, I think the UT inks show a bit more dot that the VM because the
warm gray is warmer -- pure carbon (what the VM warm gray would fade to
after a while).
If you want variable tone, however, the UT is it.
If you mostly do the same tones and they are within the range of the UT-FS
or FSN, then those monotone inksets will print a bit smoother on the 1160.
I have also made some curves for them, and they are much easier to make new
curves for if and when you want.
I would replace the old carts with new ones.  That is, don't mix the inks.
Good luck with the change over.
>> -----Original Message-----
>> From: DigitalBlackandWhiteThePrint@yahoogroups.com
>> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Peter
>> Mc Mahon
>> Sent: Saturday, May 07, 2005 1:20 PM
>> To: DigitalBlackandWhiteThePrint@yahoogroups.com
>> Subject: [Digital BW] change over procedure
>> I have finally got around to look at changing the MIS  VM cart  inks for
>> my 1160. A couple of questions.
>> [a] Do I need to completely change the cart setup and replace with new?
>> [b] If I don't, what is the best procedure for ink replacement?
>> [c] What would you suggest as being the best inkset replacement either
>> way?
>> all advice would be greatly appreciated.
>> thanks,
>> Peter.
