Which would you choose?
2005-05-08 by Tim Timmermans
Hi gang,
Say you have to get a 13 x 19 printer. Your choices are the 2200 or
the 1800. Which do you choose and why?
If you could get two printers would you get a 2200 for color and an
1800 for BW?
What if you already had a 1280? Would you dedicate that to BW using a
CFS and if so, which of the other two would you get for color?
Additional info... Someone is giving me a 1280 tomorrow. I don't know
it's condition but I think it's in good working order.
I also have a 2200 which I feel so-so about. I have a replacement
warranty on it so I could return it and get full store credit for it
(not cash unfortunately)  I already have $399 store credit so by
returning the 2200 I'd have about $1000 store credit. Would it make
sense to move up to a larger format printer? I have been selling my
13x19 images pretty well. Getting $175 to $225 for them at shows but I
don't show that often. Could probably get more for larger images.
Thanks for considering these questions. I obviously have decisions to
make and soon.
Re: Which would you choose?
2005-05-08 by Steven Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tim
Timmermans" <zenphoto7@a...> wrote:
Hi Tim;
Having just bought an 1800 on Thursday and taken it back on Friday,
I may have a bit better perspective on tis than most list members:
> 1800 for BW?
You've got it backwards here: The 1800 does the better color,
especially with the premium profiles provided by Epson, but is
worthless for B&W. The one I took back showed at least some banding
at even the highest quality settings. At some point Paul Roark may
work up a set of curves for it, and QTR may also support it, but
until then you're stuck with either an expensive RIP or making do
with the Epson driver for B&W.
using a
Do you need pigment color? if not, the 1280 does a good job with
dyes, especially with a couple of custom profiles. It also has B&W
support, and does a good job, but tends to require more cleaning and
is more clog-prone than the 2200.
it
Most people doing B&W on a 2200 are very happy with them. The
printer has wide support for b&w, a definite advantage.
>> Would it make
I have a 7600, care and feeding of the beast runs a good deal higher
if you wind up doing mostly small prints anyway. I think about 20%
of each cartridge gets wasted by those incessant cleaning cyles, and
you can't put anything smaller than 8x10 through it. It is also
slower, and has a coarser droplet size than the 2200, ie, forget
doing Black Only unless you happen to be a 35mm Tri-X/Rodinal fan.
If you're not sure you have a good market for the bigger prints,
test the waters by paying for a couple bigger prints and see if they
sell at your next show. If you decide to go up, probably the 4000
makes a logical next step up.
If you're really itching to spend that money, I would wait a few
weeks for the new generation to hit the market, I think Epson will
make the announcement this week, so I heard. The new machines will
finally address B&W printing, hopefully reasonably well.
I hope this helps
Steve Karafyllakis
