Need Help! Confused about UT7 Options
2005-05-11 by SteveZ
I wanted to order some MIS UT7 cartridges for my 2200, but I'm a
little confused about what my options are. Must I order two different
sets...one for the Epson Driver (Paul Roark's version) and one for
QTR? Or can one set of ink cartridges work for both drivers? By the
way, I have a Windows XP platform and I remember reading somewhere
that I must specify which OS I am using...is this true? Thanks!
SteveZ
Re: Need Help! Confused about UT7 Options
2005-05-11 by Louis Dina
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "SteveZ"
> SteveZ
Steve, I have the exact same setup and platform.  Not sure why MIS says
that on their site.  If you want to use Paul's curves with the Epson
driver, you will need the configuration that works with them.  That's
what I bought.  That same configuration works fine with both QTR and
IJC/OPM. I built a basic set of curves for both QTR and IJC/OPM for
this inkset on my 2200, if you want them.  Both RIPs will accept any
inkset you can cram into your printer.  Works fine.
Lou
