Help! Custom paper size problem
2005-05-14 by krn_ptr
After setting a custom paper size in QTR, the print preview dialog shows the
image correctly oriented to print the way I want (landscape on an 8.5 x 17
sheet).  When I print, it prints across the width of the paper, cutting off most of
the image (it's a panorama shot).
If I switch the selected printer from QTR to Epson MK driver, it prints correctly
(except that it's tinted instead of B&W).  What am I doing wrong?  Of course, I
have a deadline for tomorrow for two prints for an exhibition.   Please help.
peter
Sorry for the cross post
Re: Help! Custom paper size problem
2005-05-14 by dlruckus
Don't know whats wrong but have you tried cheating and telling it to
print portrait to see if it prints the other way?
Duane
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "krn_ptr"
shows the
8.5 x 17
cutting off most of
prints correctly
Of course, I
Please help.
> Thanks,
> peter
Thanks for the suggestion, Duane, but yes, I have tried that.  It prints
horizontal bars across the paper width.  (See my new post on Yahoo QTR)
peter
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dlruckus" <
> Regards
> Duane
> shows the
> 8.5 x 17
> cutting off most of
> prints correctly
> Of course, I
> Please help.
> > Thanks,
> > peter
2005-05-14 by Boomcha
I had the same problem with the custom paper issue. I was printer colour
using the 2200 so I can't help you with QTR but, set the width of the paper
to no larger than 12.6 inches. This is the maximum width allowed by Epson.
Jorge
Re: [Digital BW] Re: Help! Custom paper size problem
2005-05-14 by Barbara White
Actually, I was just told by technical support at Epson to set mine
to 12.94, and it worked. So, perhaps that is now the maximum.
Barbara
> colour
> the paper
> Epson.
> Jorge
Thanks, Jorge.  You're absolutely right.  That was the problem.  I found out this
afternoon and i was just going to post when i saw your post.  Actually, i set it to
32.8mm because that's 0.01mm less than the Epson label for 13" paper.  It
worked fine.
Thanks to everyone who responded.
peter
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Boomcha <
> Jorge
You're right too, Barbara.    Actually, i set it to 32.8mm because that's 0.01mm
less than the Epson label for 13" paper.  It worked fine.
Thanks for helping.
peter
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Barbara White <
> Barbara
> > colour
> > the paper
> > Epson.
> > Jorge
