2400 profiles are on the loose!
2005-05-19 by dfaprinting
The 2400 profiles are on the loose!
http://forums.dpreview.com/forums/read.asp?forum=1003&message=13547405
Don't get too excited, they have been edited to give very large gamut
in a profile viewer. Looks like you will need custom profiles right
out of the gate again!
Re: [Digital BW] 2400 profiles are on the loose!
2005-05-19 by Steve Kale
And B&W Mode is Same as Source anyway.
I have been corresponding with Bruce Fraser and he and Jeff are looking at
doing softproof profiles when they get a printer.  They will likely do for
each paper one profile for each of the main settings (neutral, cool, warm
and sepia for each of darkest, darker, dark, normal, light) so 20 profiles
per paper.  One can already use EyeOne Match to do your own profiles
following Carl Schofield's workflow (if you had a printer!).  Bruce will be
using a lot higher patch count than 21 or 51.
I still think the more interesting and relevant issue is profiling the
luminance axis.  This k3 situation is just like QTR a year or so ago (and
where black-only is today).  We found a way to soft proof but still did not
have a way of managing the difference between the workspace luminance
profile to the printer reflectance profile. The old 'why do my QTR prints
print "light" and "lack contrast" issue?'.
Epson has loaded into the driver five transforms - darkest, darker, dark,
normal, and light - but these must only be simple transforms keyed off the
paper selection.  Thus they take no account of changes in workspace nor
individual printer differences in linearity.  They certainly won't
accommodate a change to the inks.  Think of them as Black-only work flow
with five preset curves to choose from.  The smarter money will figure out
if there is a way to manage the luminance/reflectance compression with a
(greyscale) ICC output profile a la Roy's generics for QTR.  The only issue
I can see is in how Epson applies the transforms. Specifically, if they are
simply always applied to incoming file data then data already adjusted by a
ICC profile conversion that was intended to alter the file data to reflect
the print space would then still be transformed again. Then you're stuck
with what Epson has hard coded and it will become progressively out of date.
Steve
> From: Ernst Dinkla <E.Dinkla@...>
> Date: Thu, 19 May 2005 11:41:48 +0200
> Subject: Re: [Digital BW] 2400 profiles are on the loose!
> It is far too early to judge the printers by their profiles. The drivers
> show changes that may well explain why Epson decided to extend the soft
> proof gamut. There's an AdobeRGB mode in the 2400 and 4800 drivers
> (R1800 had that as a first) next to the sRGB mode that was the default
> of the older drivers. This influences the gamut possible. The gamut of
> the new Epson will differ from the R1800 as the LM and LC inks deliver
> more gamut in the light color mixes (better subtractive mixing, less
> paper white) while the R1800 has its gamut gain at the blue and red
> regions of the gamut. The CM inks of the R1800 were more diluted
> compared to the CM inks of the CcMmYKk Ultrachrome printers according to
> Robert Krawitz. A compromise between not using LC and LM and what the
> finer droplets could produce in color mixing at the highlights.
> Depending on the inklimit possible in the R1800 that could mean there's
> some gamut loss at the full C-M  hues. There's also a hue shift in the
> new 4800 CM Ultrachrome inks compared to the old C-M UC inks according
> to Joseph Holmes.
> I think you need a very good 3D profile viewer to see where the shapes
> of the three printer generations differ. Not to speak of the differences
> between the soft proof part of the profiles and the actual printing
> gamuts and what is shown in a 3D viewer.
> I doubt Epson is returning to inflated profiles again after their
> excellent Atkinson etc profiles for the UC printers.
> How to get the new drivers is explained in the first message of that
> link above.
> Ernst
2005-05-19 by Ernst Dinkla
to Joseph Holmes.
link above.
Ernst
BTW if anyone is interested in making a more accurate soft proof for their
B&W work I used Colorlab to make a 256 step test chart and corresponding
reference file which Eye One Match can use (Carl's method).  The EyeOne
scans the chart easily and quickly.  Let me know if this is something that
should be posted in the files section of the group.
In playing with this I noticed something which puzzled me.  When I look at
the test chart tiff in PS it is obviously the data I told it to be: equal
RGB steps (Lab a*=b*=0).  When I assign the profile generated by Eye One
Match the a* and b* of the patches alter (looking in the info palette),
reflecting the colour in the inks used to print the test chart, but for all
steps R=G=B still.  I guess it is because I assigned the profile thereby not
altering the RGB file info but "giving it meaning" with the profile.  That
meaning is reflected in  the Lab info.  That is, for example, patch RGB
80,80,80 with the profile means Lab 39,4,-3.
> Yes, the B&W driver may be less sophisticated than I figured out it
> could be.
> BTW I'm not familiar with the R1800 driver but in the 4800 driver there
> are two B&W modes, Advanced B&W and what they simply call Black. It
> would be very inappropriate if the last isn't Black Only printing. 180
> nozzles at 3.5 picoliter and possibly 8 pass like the 10000 firmware
> upgrade had must deliver a nice BO print. Clayton are you there ?
> I do not see the same option in the 2400 driver. Nor am I able to get to
> Advanced B&W in that driver but I have little time right now.
> Ernst
>Steve
could be.
Ernst
2005-05-19 by Clayton Jones
there
I'm here, waiting eagerly for what early users have to say.
Clayton
They did indeed go back to the garbage profiles. I checked it in 4
different viewers, including 2D and 3D views (where possible). Remember
the LAB L of 3 for the gloss/luster papers that Epson reports, well the
gamut view reports black as being ZERO. Too bad they went backwards.
The latest profiles for the R1800 are at least believeable. And you are
right, this is way to early to tell what is realy going on with these
printers, I had just hoped for a more concrete performance spec from
Epson.
On a side note, one person has tried the 4800 driver with the 4000. If
I'm reading it correctly, the B/W driver is working, and using all
three black inks. It might be as simple as exchanging the chips between
the carts for the 4800 and the 4000 to use the new inks on your old
printer. It also means that for a $500 RIP, you can do the same and
more with the 4000. You can see this in the Epson forum at DPReview.
Isn't this in conflict with the information Roy gave about the 4000,
that it is impossible to drive both black lines at the same time even
with QTR that doesn't use the Epson driver ?
Or could there be a new command in the printer language so far unused
that opens that possibility ?
Ernst
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
> Ernst
I'm not really sure. I contacted the programmer for the RIP I've been
using, and he said the same thing, it can be either matte or glossy. I
wish I had one of these to try. I might also consider sending the 4800
firmware to the 4000 to see what happens, but that is a bit risky, and
could cause the printer to stop working, without a cheap fix. Other
printers that use the same head seem to be able to print all 8
channels, so I'm pretty sure the problem lies in the firmware. Also the
4000 is capable of addressing all 8 heads individually, if it couldn't,
you would not be able to run the nozzel check function. Maybe someone
needs to contact a really good hardware programmer, and hack the 4000
firmware. Since both the 4000 and the 4800 firmware are available,
making the 4000 look and act like the 4800 shouldn't be too hard. At
least then you could use the new driver, and the new inks. It might
take something like this to force Epson into releasing an up date to do
the same.
The thread is here for anyone that wants to keep track of this topic:
http://forums.dpreview.com/forums/read.asp?forum=1013&message=13551031
I'm wondering if the new driver is driving the black channel, and both
inks are spraying at the same time, but not independently controllable,
which would make a big mess.
It still looks like a solution for the 4000 is to just use better inks
and a RIP. If time allows, I'll work on setting that up. Haven't had
the time to try and find a discount for the RIP, but things at work are
finally slowing down, so hopefully I'll get a chance to call. I think
the better inks are already here, as I've had good luck with them in my
9500, and they really shouldn't work very well with that printer. In an
Ultrachrome printer they should work very well. A lot of that has to do
with the dot gain, and these inks don't have much dot gain, so it's
harder with the older printers. I did compare the new to the old last
night, and the new ink does have a slightly "thicker" black ink as
compared to Eboni. Dmax looked about the same visually, but I think the
new has slightly better measured dmax. Mostly it just gives you less
ink on the paper, so that can help when layering with colors (which are
also much heavier pigment than other inks I've tried).
