B&W Digital negative with R800 printer successful for silver printing
2005-05-22 by Scott Jones
My experience with making injet digital negatives for silver prints
Being somewhat frustrated by my lack of more precise control in the
traditional darkroom now that I have been exposed to Photoshop, I
have experimented with Mark Nelson's Precision Digital Negative
system to make black and white digital injet negatives and then
contact print them on silver paper.
I have used my Epson R800 printer and Pictorico White film for the
negative. I have used Ilford Multigrade IV fiber glossy paper and
traditional processing with selenium toning. I feel that I have been
completely sucessful and have been able to avoid the microbanding
that others have complained about.
Here are more details:
The precision Digital Negative process uses these steps.
-Determine a standard silver printing time with a 21 step wedge
-determine a color density to use for printing the negative
-use this to fit the range of tones to the paper and process
-print a negative with a full range of tones using the above steps
and make a contact print
-measure those contact printed tones with a densitometer or scanner.
-manufacture a correction Photoshop curve to linearize those tones.
What this gives you is a repeatable process that takes advantage of
the full range of your paper and makes it possible to transfer what
you see on the screen directly to your darkroom paper. No more
manual dodging, burning, flashing, contrast filter manipulation,
exposure determination,unsharp masking, waiting for drydown etc.
The Precision Digital Negative system gives you all the instructions
and the software to do all the steps very precisely so that all of
this is repeatable once you calibrate your working environment.
I noticed two main things as I worked my way through this prcess.
First, the system has you pick a color density of ink to use for
making the negative because I believe most people who use this
system are interested in platinum work where UV light is used and
therefore using the different color inks can make a difference here.
I found that for silver work, choosing just a color of ink did not
supply enough density to fit a full range of tones on variable
contrast paper without cranking the contrast filter of my enlarger
(used as a fancy contact printing light source) way up to level five
and this did not look good at all. So I fell back on using the
printer's full bore ink rendition of producing a black and white
negative with all the color inks. Now it was possible to make a
negative that worked with varible contrast paper set at the filter
#1 level and the results looked great.
Secondly, I found that indeed I did get very faint microbanding when
I printed the inkjet negative at the "best photo" setting of the
R800 which corresponds to a dpi setting of 2880. It was very faint
and only visible in the creamy highlights of skin tones. My friends
didn't see it until I pointed it out and then they could. I was not
satisfied with this and felt maybe this process couldn't be done
well with silver paper. BUT, I tried again with the "RPM" setting on
the Epson driver which corresponds to a dpi setting of 5760. Well,
after recalibrating the process to this new dpi setting, the results
were fabulous. Recalibrating the system was absolutely necessary in
that it was clear that the ink was laid down with very different
density at this higher setting. This step solved, in my system,
the microbanding issue that some have spoken of in forums. I believe
now that this print is indistinguishable from my enlarger made print
except that the control of the tones is so much better than I am
amazed.
This was an 8x10 negative and print. My original plan was to upgrade
to the R1800 printer so that I could make 11x14 negatives and
prints. With the new Epson R2400 coming out, I will hold off to see
what that printer will be like. However, both printers offer
the "RPM" or 5760 dpi setting that appears to be crucial to getting
rid of the light microbanding on exceptionally unforgiving silver
gelatin paper. My suspicion is that this might not work with the
2200 printer. For platinum work on art papers, this system will have
no problems and if I did those processes, I would be all over this
system in a heart beat!
So there you have it. After a month of experimenting, I feel that
this sytem will truly work with the current newest Epson printers
and may be an ideal hybridization between the control of Photoshop
and the wonderful dmax and luster/feel of silver gelatin papers.
Please feel free to comment.
Re: [Digital BW] B&W Digital negative with R800 printer successful for silver printing
2005-05-22 by Martin Sluka
There is Agfa SelectJet and CopyJet films, they shoud work for such
negatives too.
My 0.02 EUR
Martin
Re: B&W Digital negative with R800 printer successful for silver printing
2005-05-23 by al_charbonneau
Thanks for sharing your experience. What did you mean by "using the
printers full bore ink rendition?
Al Charbonneau
 In DigitalBlackandWhiteThePrint@yahoogroups.com, "Scott Jones"
been
scanner.
of
what
instructions
here.
five
when
friends
not
on
results
in
believe
print
> amazed.
upgrade
see
getting
have
2005-05-24 by Scott Jones
"Thanks for sharing your experience. What did you mean by "using the
printers full bore ink rendition?"
Mark Nelson's Precision Digital Negative system has you pick a
"color" for printing your negatives that is determined in the
calibration process. It is usually a pure R, G, or B tone plus a
slight mix in of one of the other two. This makes for a brightly
colored negative and is used because of the varying UV transmision
characteristics of the colored inks, since most of his work is
platinum which uses a UV light source.
In my case, I am using silver variable contrast paper. I found that
if I used one of his color mixes, I could not get enough density of
ink on the negative substrate to get a wide range of tones without
cranking the contrast filter setting way up to the top and the image
looked terrible.
So, I abandoned (at his suggestion) the color picking step and just
let the printer driver use all of its inks to make a full Black and
white negative image on the negative substrate. This way there was a
lot more ink on the substrate and it worked beautifully.
Don't hesitate to ask more questions...
Re: [Digital BW] Re: B&W Digital negative with R800 printer successful for silver printing
2005-05-24 by R Murai
Scott,
Is there any way that we can see some examples?
Sounds exciting.
Rick Murai
www.richardmurai.com
http://www.hawaii.edu/mjournal/text/issues/descriptions/cambodia04.html
> looked terrible.
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the membership
> without notice.
> printing. Users who persistently make off-topic posts may be removed from the
> membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
> “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
> DIGITAL BW, THE PRINT YAHOO GROUP.
2005-05-26 by al_charbonneau
There is a good article "Precision Digital Negatives: From Silver to
Ink" in the December 2004/January2005 issue of Camera Arts
magazine.  The article was written by Mark Nelson, the fellow who
invented this approach.
Al
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, R Murai
<rmurai@e...> wrote:
> Scott,
> Sounds exciting.
> Rick Murai
ml
transmision
that
of
without
> > looked terrible.
just
and
was a
resources as
wish to
this same
> > page.
messages to keep
> > them short.
flames.
the membership
> > without notice.
digital B&W
removed from the
> > membership.
and
group Owner and
> > Moderators. See "Group Topic, Rules and Guidelines" in the Files
section:
THE PRINT
> > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
AND
> > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO YOU
EXEMPLARY
PROFITS, GOODWILL,
> > USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER"
AND "MODERATORS" OF
POSSIBILITY OF SUCH
THE DIGITAL BW,
OF YOUR
PARTY ON THE
RELATING TO THE
> > Yahoo! Groups Links
