7600 & QTR
7600 & QTR
2005-05-24 by Paul Roark
Is anyone using QTR with the 7600?
How about with the 7600 loaded with UT7?
I just tried QTR with the existing UC curves to see if the dmax was any
better than with the Epson driver.  With MIS Eboni installed, I'm getting no
better dmax from QTR.  QTR is obviously pouring on more ink, but it does not
seem to help.  (Increasing the ink limit in the Epson driver also does not
help.)
Any suggestions for getting a better dmax from the 7600 would be most
welcomed.
Re: [Digital BW] 7600 & QTR
2005-05-24 by Ernst Dinkla
>help.)
>welcomed.
>Paul
Paul,
What is the Dmax you get with both drivers ?  Is there a Dmax difference
between the different dpi resolutions and bidirectional versus
unidirectional ? The effect of drying time between strokes.
With Eboni and a 9000 I can't get higher than 1.7.  Boosting the black
with the next grey may help or not, I use it to compensate the
irregularity of the black head but I probably loose some density by it.
In general it is more the ink that is at its max than anything else.
Reflection of the ink surface limits the Dmax, how much ink you pour on
doesn't matter.  I guess the ink limit you can use is at 80-85% while I
shut it off at 60%. The total ink will be similar but the 9000 hasn't
the more gradual ink squirting of the newer models. I have taken 60% as
it is a bit higher than my Spectrometer reads the maximum because the
linearising seems to take away a bit of the ink again.
Ernst
RE: [Digital BW] 7600 & QTR
Ernst,
On EEM with Eboni installed the dmax with the Epson driver is usually about
1.60 - 1.61.  IJC produced the same initially with one of their pre-made
curves.  QTR hit 1.62.  The Epson driver set to Premium Glossy paper (PK
chip on Eboni cart) with 2880 and High Speed UN-checked hit 1.63.  With IJC
and some dark cool ink added to the Eboni I've seen 1.66 in some tests, but
I have not been able to replicate that in a curves set yet.  On the 7500
with this batch of paper 1.67 is typical (and a whole lot easier to achieve
-- I'm seriously thinking of dumping the 7600).  (These are all initial
readings that typically will increase by 0.01 overnight.)
I should be so lucky.
With UC ink in the 7600 I could do a little better than I'm not doing with
it by having the dark cyan supplementing the UC MK.
> doesn't matter.
Yes, clearly just pouring on more ink is not the answer.
The dither pattern, speed, and other factors seem to be working here.  The
4000 appears to be even worse.  It'll be interesting to see if the newer
4800, etc. have cured the problem.  The R1800 is capable of very good dmax
from what I've seen.  I'll bet they are using some cyan and/or blue to do
it.  That might account for there not being a "BO" mode on those printers.
With the 2200, the best dmax I've been able to achieve is by having a second
Eboni in the printer and using a rip.  However, at this point the rips still
have too many problems for me to be enthusiastic about having an inkset that
can only be run by them.  On the other hand, maybe if I used a rip I could
just forward all the e-mail I'd get about printing problems to those who
wrote the code! ;-)
2005-05-24 by Louis Dina
Paul,
On my 4000, I can hit 1.7 or better with EEM using IJC or QTR.  I
know, it's not a 7600, but they seem to have the same Dmax issues, at
least with Epson's matte paper settings in their driver. IJC
previously had narrow ink limits on the 4000, but Joe opened them up
and it is easy to hit these numbers now.  I typically reach the black
ink limit at about 50-55% on my 4000 now.  This was with the UC
inkset, but I have gotten similar Dmax numbers with UT7 inks on my
2200.
Lou
<paul.roark@v...> wrote:
> Ernst,
usually about
made
paper (PK
With IJC
tests, but
7500
achieve
initial
doing with
else.
pour on
> > doesn't matter.
here.  The
newer
good dmax
to do
printers.
a second
rips still
inkset that
I could
those who
> wrote the code! ;-)
> Paul
> www.PaulRoark.com
Re: 7600 & QTR
2005-05-24 by ccolbertbw
Paul,
On my 7600 on EEM using eboni in the LK slot, my readings with an eye-one are all
1.63-1.66. That's with about .04 to .05  on the paper (not sure if you are subtracting that
off). Using the boost yielded slightly higher values, but I had problems with linearization of
95% up. On HPR the numbers are 1.73 - 1.74.
These are using 1440, which uses the (3) variable drop sizes. You can configure QTR to
use only 2 or even 1 drop size. Perhaps the 7500 wins on larger dot sizes? Although one
would expect the larger dots to be used at the high end. However, I am not sure how the
ink  lmits/dot sizes interact. Perhaps with a 55-60% ink limit the largest dots are not being
used. Maybe Roy knows.
Costa
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...>
wrote:
> Ernst,
2005-05-24 by John Custodio
On my 4000 printing on Hahnemuehle Photo Rag I get
Dmax of:
1.54 - 1.6 using Studio Print 11 and either PiezoTone
Portfoilo Black or Eboni
1.6 using the current XP version of IJC and either
Portfolio Black or Eboni
1.73 using the Epson driver photo paper setting and
Eboni
1.59 Using the Epson driver matte paper setting and
Portfolio Black
This 4000 has The PiezoTones hand loaded into carts on
the left side, and MIS FSN on the right side.
My other 4000 has Ultrachrome ink. Dmax is 1.6 with
Studio Print 11 and Ultrachrome matte black (also on
HPR).
Lou Dina reports a Dmax of 1.7 on EEM and Ultrachrome
matte black with the new (as yet not released) XP
version of IJC.
I know 1.73 is possible with HPR and Eboni on the 4000
because I can get it with the Epson driver.
By way of comparison, when I had my 7000, I always got
1.72 - 1.75 with SP10 and Portfolio Black.
-John
Do you Yahoo!?
Yahoo! Small Business - Try our new Resources site
http://smallbusiness.yahoo.com/resources/
2005-05-25 by Paul Roark
John,
Thanks for posting your experiences and dmax numbers.  They sound mostly
within the range that I'd expect.  (The 7600 may not have a "photo paper"
setting that did so well on your 4000.  Is that the name in the Media Type
list?)
I have finished my first UT7 Neutral curve for IJC and the 7600.  (I'll be
making my curves available, as usual.)  It's getting 1.65, which is the best
I've consistently seen on the 7600 with this batch of EEM.  There are other
and better EEM batches out there.  This one hits 1.67 on the 7500.
So far, I think the IJC image is, overall, the best I've seen.  The Epson
driver has a dmax of close, at 1.63, but that's at 2880, where it also has a
vertical rippling type of banding.  (So far all the hardware and driver
adjustments have not phased it.)  The Epson driver at 1440 is fine at 16
bits.  (I can see a highlight stepping difference.)  At this depth, my RGB
files start to get more cumbersome, so the IJC 16 bit grayscale printing
seems to be one source of its advantages.
If I'm going to go with a rip, I may put a second Eboni (or other ink) in
the LK spot.  I think LK is just wasted for dedicated B&W printers.  The
dual Eboni setup in the 2200 achieved the best dmax.  Two jets seem to do a
better job than just one.
> Dmax of:
> Eboni
> Portfolio Black
> HPR).
> version of IJC.
> -John
> Do you Yahoo!?
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See Group Topic, Rules and Guidelines in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND
> MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
2005-05-25 by John Custodio
Paul-
--- Paul Roark <paul.roark@...> wrote:
> John,
> list?)
I picked a photo paper in the Media Type list (like
Lustre), thus forcing the printer to use the ink in
the Photo Black position (which was Eboni) and
probably increasing the ink limit for that ink over
the lower ink limit for the ink in the Matte Black
position (which was Portfolio Black).
-John
Do you Yahoo!?
John,
OK, so you found the same thing I did with the 7600 -- the PK paper list's
glossy papers give a better dmax with MK.  I put a PK chip on the Eboni cart
and found "Premium Glossy Photo Paper" gave me the best dmax even with EEM.
I'm going to try a second Eboni in the LK next.
