Wax
2005-05-24 by klog52756
Been wanting to experiment with wax, on my Photo Rag prints, and I just went through all the previous posts I saw. My objective is primarily visual. I want a deeper Dmax, and overal Deeper "look". The added protection is welcome as well. 1. Renaissance Wax: Never used it on prints, but I have used other waxes that are similar for woodworking, and I DO suspect that it would be a "pain in the butt" to use on prints. 2. Liquid Acrylic Wax: this actually sounds quite plausible to me, and sprayed, should be easy enough. Problem, water soluble 3. I have tried Clear Shield (Semi-Gloss),,, not bad, easy enough, but it does little if anything to increase the D-Max,,,and, again, it's water soluble So, I am looking to experiment. Now, one wax I am very familiar with, it's tough as nails, seemingly doesn't yellow or anything along that line, is car wax. The typical creme wax that comes in a short can (Turtle wax for example) that you apply, let dry (thoroughly) and then buff off the dried remains. Naturally, this wax, as with any wax or varnish, I would try on top of an isolation coat, such as Lascaux Fixative. So, any opinions/experience using car wax? Curious to hear. Archivability issues???? All the best, Kevin Logan
