(no subject)
2005-05-26 by photoian@comcast.net
Message: 5 Date: Wed, 25 May 2005 17:09:24 -0000
From: "dlruckus" <dlruckus@...> Subject: Re: A bit OT. Mounting Prints - effect of heat on inkjet print - any recommended --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Roy <thinkgreen@s...> wrote: > I've looked for a yahoo group that's about mounting inkjet prints but there > is none :-) > > What are > good "non dry mount" (wet ?) alternatives with glues and the like. Hi Roy. Look at 3M Scotch Positionable Mounting Adhesive. It is considered "Photo safe" and can be hand done(no press needed). You simply apply it, peel the backing sheet, position the print and burnish. It seems to work nicely where suspension mounting isn't effective for whatever reason. Regards. Duane I;ve found that the positionable adhesive will release in places over time giving a billowy effect to the print. I much prefer dry mounting and haven't seen any deleterious effects yet. Of course, I don't know what Wilhelm age testing would show for drymounted inkjets. Ian
