Re: [Digital BW] Re:Glossy, MAtte and Dmax- Is it physics?
2005-05-26 by Brian Ellis
>Now when the paper has a rough >texture (matte), the ink covers or travels > >over hills and >valleys and as the light hits it, some will >be reflected back and some >scattered >about. . . . As light hits the rough >surface it bounces back in >every >direction instead >of in a more discrete, coherent bundle. I'm probably missing something here but if this is the case then it would seem that matte paper should have a higher dMax than glossy paper, not the other way around, i.e. since the matte paper is scattering the light and not reflecting everything back one would expect that the blacks would be "blacker" than with glossy paper which is reflecting more light back to the viewer and hence should appear less "black."
Sent: Thursday, May 26, 2005 12:03 AM
Subject: [Digital BW] Re:Glossy, MAtte and Dmax- Is it physics?
Yes, all physics. The print you see, you see because light reached the
print and the
print reflected some of that light back to your eyes. On the way from the
light source to
the print and to your eyes the light underwent several transformations.
As the light hits the paper it is partially reflected back by the paper/ ink
back to you.
Some of the light is absorbed to varying degrees. It is the varying degree
to which the
light is absorbed and reflected that constitutes the image. If no light was
reflected and
all was absorbed you will se....black. If no light was absorbed you will
see white.
Now when the paper has a rough texture (matte), the ink covers or travels
over hills and
valleys and as the light hits it, some will be reflected back and some
scattered about.
To visualize the effect imagine spray painting a thin clear glossy finish
over very finely
sanded smooth hardwood (glossy) and then over roughly sanded wood (matte).
The same
finish will look glossy in the first instance and not so glossy over the
rough wood. To
get the highest sheen the wood surface must be very smooth. Why? light
scattering on the
rough surface. As light hits the rough surface it bounces back in every
direction instead
of in a more discrete, coherent bundle. Evidently, it is not possible on
rough surfaces
to achieve as high a contrast as on glossy surfaces. The range of
tonalities will always
be greater on smooth surfaces (higher DMAx). It will be higher still in the
original
transparency especially when wet mounted, because reflections and scattering
is minimized.
A problem arises with very smooth paper surfaces though: the surface can be
so mirror like
(high reflectivity) that stray light causes it to reflect other objects and
interfere with
the reflections you really want, those from the image. Thus the compromise
is semi-gloss.
Naturally if the light is diffuse, the glossy print will not suffer from
unwanted
reflections. But when the light is diffuse you will neither see the print
at its maximum
Dmax. Diffuse light is scattered at the source and it reaches the print as
such. The
effect of matte paper is more or less similar to what you get when you put
fine a
groundglass screen over a sharp print: the print will loose Dmax and
sharpness all because
of the physics of light.
Julio Fernandez
From: <DigitalBlackandWhiteThePrint@yahoogroups.com>
Sent: Wednesday, May 25, 2005 7:49 PM
Subject: [Digital BW] Digest Number 3138
There are 25 messages in this issue.
Topics in this digest:
1. Re: Wax
2. Wet Mounting - What is it?
3. Re: The Epson R1800 is the replacement for the 2100/2200
4. Re: Matte versus glossy dmax: a matter of physics?
5. Re: The Epson R1800 is the replacement for the 2100/2200
6. Re: Re: The Epson R1800 is the replacement for the 2100/2200
7. Re: Matte versus glossy dmax: a matter of physics?
8. Re: Thoughts on the new Epsons
9. Re: Matte versus glossy dmax: a matter of physics?
10. white sky
11. Re: white sky
12. Re: Matte versus glossy dmax: a matter of physics?
13. Re: Matte versus glossy dmax: a matter of physics?
14. Re: Matte versus glossy dmax: a matter of physics?
15. Re: white sky
16. RE: To all: 7000/7500??
17. Re: Grain and Photoshop
18. 9000 w/ Ethernet and IJC?
19. Re: The Epson R1800 is the replacement for the 2100/2200
20. RE: A bit OT. Mounting Prints - effect of heat on inkjet print -
any recommended
books
21. Re: Wet Mounting - What is it?
22. Re: white sky
23. Neutral profile goals
24. Photoshop brushes and Wacom tablet
25. Re: Thoughts on the new Epsons
________________________________________________________________________
Message: 1
Date: Wed, 25 May 2005 17:59:40 -0000
Subject: Re: Wax
I think Johnson's paste wax (floor wax), applied thinly and rubbed
gently with a rag, would not lower Dmax. I've not tried on inkjet
paper but it certainly didn't reduce Dmax of silver paper, a thousand
years ago when I last did it.
Wax in general is shiny (perhaps adding Dmax?) when polished (applied
with a gentle rub), but not shiny when applied without polishing.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Hal Gage
<halgage@a...> wrote:
> Don't know what the original questions was, but I have used artist's
> wax (low temp wax for encaustic painting) on canvas pieces. The net
> effect is a "film" appearance over the image leading to a lowered
> D-Max. The use of wax on a print would most certainly be for surface
> effect only (with the advantage of pigment protection as a secondary
> consideration).
> Hal Gage
Message: 2
Date: Wed, 25 May 2005 18:15:35 -0000
Subject: Wet Mounting - What is it?
I know this is a bit off topic, but I saw mention earlier this week on
this forum of "wet mounting" as a way of improving scanner output.
What is this, how do you do it, and where can I get more information?
Thanks!
Message: 3
Date: Wed, 25 May 2005 18:19:53 -0000
Subject: Re: The Epson R1800 is the replacement for the 2100/2200
Hi Kevin.
I don't know about which is what but, if it were me, I would be
equally insistant that if they could not give an "exact" replacement (
another new 2100 ) then I want my money returned. Then you can do as
you wish.
Regards.
Duane.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Kevin Bell"
<kevbell@e...> wrote:
> I thought the group may be interested in my resent experience with
> Epson Customer services in the UK regarding the replacement for the
> 2100 printer:
> On reading the recommendations on this forum I purchased a new Epson
> 2100 which was faulty when delivered. The supplier was insistent that
> I should not return it but to arrange to have a new replacement sent
> direct from Epson. The printer was taken to an Epson Express Centre
> for replacement. Three weeks passed before I was contacted by Epson
> and was informed that the 2100 is no longer being made, I was offered
> an R1800 instead. I pointed out that this was a less expensive printer
> and that according to a much respected user group, the R1800 is not a
> like for like replacement for the 2100. Epson insisted that the R1800
> was the replacement for the 2100 and will not move on their
> replacement offer. I offered to pay the difference between the 2100
> and the 2400 but they would not budge. I assumed that the 2400 was the
> replacement for the 2100 from the posts on this forum but Epson say
> no, the R1800 replaces the 2200.
> I would be interested to hear from anyone in the group who has any
> thoughts this.
> Regards, Kev Bell
Message: 4
Date: Wed, 25 May 2005 19:29:48 +0100
Subject: Re: Matte versus glossy dmax: a matter of physics?
The colour black is the sensation we perceive due to the absence of (in this
case) reflected light. Most of today's spectrophotometers project D50
lighting at 0 degrees and measure the light reflected back at 45 degrees.
The deeper blacks on photo paper with photo black ink have higher dMax
because they reflect less light not more. The fact that photo papers
produce a less diffuse reflection contributes to their sheen characteristic
but not their increased dMax. It's the properties of the ink and other
coatings in/on the paper which affect its ability to absorb light. The
specular reflection characteristics of the surface are a different issue?
I think what you are saying is that you are prepared to sacrifice dMax in
order to achieve less specular, more diffuse, reflection properties -
particularly if you don't have "perfect" lighting. (I agree.) But this is
not to say that glossy papers have an inherent advantage. In fact their
reflection properties is a big disadvantage - it is lucky they have better
dMax to make up for it. The question at hand is how much dMax loss are you
prepared to take in order to have a more diffuse reflection? The answer
probably hasn't changed much over the years (although I doubt it's been
measured), only the relevant performance of each competing type of
paper/ink.
> From: Paul Roark <paul.roark@...>
> The spectrophotometers we use for measuring dmax use nearly perfect
> lighting
> that avoids the problems of reflections. This gives the glossy papers a
> huge advantage.
> In the real world, a matte print sitting on my desk top appears to have a
> better dmax than a gloss print because the glossy print dmax is wiped out
> by
> reflections. That is, the nature of the lighting is what makes all the
> difference. If the display conditions are perfect, the glossy prints are
> terrific. If the lighting is bad, like a window behind the viewer, matte
> wins.
Message: 5
Date: Wed, 25 May 2005 19:32:06 +0100
They should replace it with a 2400 - I am in no doubt about that! Hold firm
and scour the internet for quotes (particularly from those that sell the
printers) as evidence to support your case.
> From: Kevin Bell <kevbell@...>
> Date: Wed, 25 May 2005 17:41:04 -0000
> Subject: [Digital BW] The Epson R1800 is the replacement for the 2100/2200
> 2100 printer:
> thoughts this.
> Regards, Kev Bell
Message: 6
Date: Wed, 25 May 2005 14:34:18 EDT
Subject: Re: Re: The Epson R1800 is the replacement for the 2100/2200
I am so sorry for you. Of course the 1800 does not replace the 2100.
Unfortunately this is typical for the Epson policy - they are the same in
Germany -
it seems to be a part of their corporate identity.
Message: 7
Date: Wed, 25 May 2005 19:04:08 -0000
> this
Good point, although I don't agree entirely. Black is the absence of light,
period. If
light is
either scattered back to the viewer from the object, or reflected, either
way it makes
gray
shall we say.
Again, I don't know if I agree. Reflected light reflects back at the same
angle it goes in
(towards the paper surface in this case). In the case of the 45 degree angle
with the
spectrophotometer, the photo papers reflect more (back at 0 degrees) but
don't scatter as
much (back to 45 degrees the way matte papers do). Thus photo versus matte
papers
show higher dmax as measured at 45 degrees. So to my way of thinking dmax
and
glossyness are inextricably tied. Witness Pauls observations on Arches hot
press. It is
not
just "lucky" that glossy papers have a higher dmax. It's because they are
glossy that they
have a high dmax. Put another way: Matte surfaces scatter a lot of light
relative to
glossy.
Light coming into a surface is scattered at a wide range of angles, making
everything in
effect grey.
> characteristic
> you
> paper/ink.
> > From: Paul Roark <paul.roark@v...>
> > lighting
> > huge advantage.
> > a
> > out by
> > are
> > matte
> > wins.
Message: 8
Date: Wed, 25 May 2005 22:08:57 +0200
Subject: Re: Thoughts on the new Epsons
Tyler Boley wrote:
>--- In DigitalBlackandWhiteThePrint@yahoogroups.com, hogarth@s... wrote:
>>Yes. Given a choice of 2.3+ Dmax on gloss, semi-gloss, or matte
>paper, I
>>would almost certainly pick the matte paper. I don't think I'm alone in
>>that. The market is there. It's just a matter of time.
>Bruce, Todd Gangler here in Seattle is one of the only (perhaps now
>the only) people making tri-color carbro prints left n the world.
>Near Ciba gamut and density on beautiful Magnani fine art papers, no
>glitzy gloss or fake surface.
>Incredibly beautiful, and inherently photographic. I've never seen
>anything like them, perhaps old dye transfer.
>I've heard people say inkjet prints on art papers are not photographs,
>as though only a photo paper surface is a photograph. I honestly don't
>know what they mean.
>Anyway, in terms of the nature of the media, it's whole new world in
>my opinion. But as above, the marketplace may dictate otherwise. Also,
>I think other inks need to be developed. Lyson dye or even Epson dye
>prints on the same fine art papers blow the UCs out of the water, but
>of course don't have Wilhelm's blessings. Mine either I guess.
>Tyler
When I compare the inkjet prints I made so far then the matte blacks of
dye (Lysonic, Epson) inks are the best, followed by Generations which is
just a bit more black than MIS Eboni. If I compare them with intaglio
prints (heliogravure, rotogravure, etc) and silkscreen matte blacks (on
Arches, Magnani, Fabriano etc) then all the mentioned inkjet matte
blacks appear as having more density. Given that, I don't expect much
more density in inkjet inks + matte paper coatings. What's the measured
density of carbro prints ? On the net I see evading descriptions on how
black they actually are. The impression of high black density in a
print can be subjective, if that impression is there it is not a bad
result either.
Taste for gloss and semigloss in photo shops is not just inherited from
analogue times. Like in analogue times gloss and semigloss serve the
goal better, the surface is better protected, the reflectance angle is
easily adjusted when prints go from hand to hand, the dynamic range is
wider. Photo shops will get less complaints from their normal customers
with gloss and semigloss prints.
Artist fall for the velvet black of inkjet ink on matte paper. They
think how it shows on the wall. The blacks they are used to don't have
that photo gloss density either. Another eye for black.
Many UC printers are not used in photo or art printing shops but are
used as proof printers in offset print shops, by graphic arts designers,
by textile designers, in CAD environments, whatever. They select the
more universal ink which is the PK and they can't be bothered by a loss
of Dmax on matte surfaces. That matte density loss is there in offset
printing too so why try to get the proof better and wet the appetite of
the customer for something he will not get ? This isn't the taste for
gloss quality but a practical decision.
There are not enough artists and photographers around that think of
their prints hanging in a gallery to get a 50-50% selling of PK and MK.
Maybe we better keep that quantity low too :-)
Ernst
Message: 9
Date: Wed, 25 May 2005 15:07:58 -0400
davelongviews wrote:
> There has been a lot of discussion over extended periods on the group
> regarding matte and glossy dmax. Is it true that light SCATTERED at
> the paper surface is what gives a matte surface its look, and that
> very same scattering is what reduces dmax? And with a glossy paper
> less light is scattered, more is REFLECTED, dmax is greater, and you
> have the glossyness to deal with. In other words isn't it true that
> you can't have a matte surface with a truely large dmax? Aren't paper
> surface/glossiness and dmax directly related in a way we wish they
> weren't? Is it physically possible to separate the two? Any thoughts?
> Dave
Yes to all. This is explained pretty well in the book /Light Science &
Magic/ by Hunter and Fuqua IIRC. In the early chapters they cover how
objects reflect light. I can't find the book right off, so I'll have to
broadly paraphrase.
Basically, matte object give a diffuse reflection, while glossy objects
give off direct reflection. If you are looking at a matte print on axis,
light coming from anywhere in front of the print is reflected difusely -
that is, light coming in at a 10 degree angle is reflected back fairly
equally across a 180 degree hemisphere. Some of this light reflects to
your eyes.
If you try that with a glossy print, the light coming in at a 10 degree
angle is reflected back off the print at 170 degrees. Almost none of it
will reflect back into your eyes.
What it all comes down to is, glossy surfaces reflect less light into
your eyes. It's the essence of being glossy. And it's the reason that
glossy surfaces exhibit greater Dmax.
Bruce Watson
Message: 10
Date: Wed, 25 May 2005 19:21:35 -0000
Subject: white sky
Hi
I know my question is completely OT. But: can anybody please tell me
quickly how they replace a completely white sky by a blue sky with a
few clouds in it. I seem to remember that there are actually a few PS
plug-ins around, but I can't remember which ones the are/were.
Thanks for any info
Chatzebussi
Message: 11
Date: Wed, 25 May 2005 19:32:10 -0000
Subject: Re: white sky
In Photoshop CS3 it is Filters->Regional->Fix New England Sky
Or perhaps will be... ;-) (we have had the 7th coldest May on record
and rain for part-of or all of the last 8 weekends.)
I don't know of a plug in. Perhaps a composite with a nice sunny sky
in another pic?
Guy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "chatzebussi"
<chatzebussi@y...> wrote:
> Hi
> Thanks for any info
> Chatzebussi
Message: 12
Date: Wed, 25 May 2005 19:37:06 -0000
Thanks very much Bruce for the informative reply. Say, is that book Light
Science and
Magic woth a read for printer types?
> > Dave
> broadly paraphrase.
> your eyes.
> Bruce Watson
Message: 13
Date: Wed, 25 May 2005 19:37:57 -0000
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
Actually that is only true in the spectrometer example. They really do
reflect more concentrated light. Just not where the spectrometer is
looking.
characteristic
The issues are pretty much one and the same from a practical
perspective. If the light direction enhances the "sheen" you have
visually less d'max and if it reduces the sheen you have more.
Yes, like glossy,satin, or matt coatings vs equal opacity/absorbant inks.
>The
issue?
I think it is - the - main issue. If you could get d'max 3.0, via an
ink improvement, on matt, it's not going to alter the specular
relationships. Glossy could still do better.( under certain
circumstances ie: 45 degree lighting )
dMax in
this is
better
I don't think they do.
> paper/ink.
perfect lighting
papers a
> > huge advantage.
have a
wiped out by
all the
prints are
viewer, matte
> > wins.
Message: 14
Date: Wed, 25 May 2005 15:56:32 -0400
> Light Science and
The Hunter and Fuqua book is actually about studio lighting for
photographers. They explain it from an interesting point of view, and
make it very easy to understand how to use lights and control
reflections while capturing an image. It's certainly worth reading if
you are interested in learning how things work.
If you are a straight up print maker, it might help you understand your
photographer and art reproduction customers better because it explains
what they go though to capture well lit images of 3d and 2d objects. The
book is about the front end image capture though, not about processing
or printing the captured image.
Bruce Watson
Message: 15
Date: Wed, 25 May 2005 13:00:22 -0700
At 12:21 PM 5/25/2005, you wrote:
>Hi
>Thanks for any info
>Chatzebussi
This from a struggling neophyte but I had the same issue. First I had a
picture of a nice sky. I selected the white sky and then did an inverse on
the select. This in turn selected every thing but the sky. I then copied
that scene onto the picture of the nice sky. I had to screw around getting
it positioned on the nice sky and play with transparencies and the like
which I don't remember well enough to tell you but at least you've got some
direction.
take a look at duendevision.com/images the grey horse has the original
sky and the brown one I put in.
Peace
Roy
Message: 16
Date: Wed, 25 May 2005 14:00:44 -0700
Subject: RE: To all: 7000/7500??
The 7500 may have a higher dmax. It would also have the firmware that does
more cleaning cycles, thus possibly resulting in fewer clogs. My 7500 is a
very nice B&W pigment printer. If you're going to use pigments, it may make
sense to buy a printer that was designed for them.
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of
> dlruckus
> Sent: Wednesday, May 25, 2005 9:31 AM
> Subject: [Digital BW] To all: 7000/7500??
> Hi all.
> I'm thinking of upscaling to one of the above. Would like input from
> those with experience with both in using pigment inks on the 7000.
> I'm aware that they seem to be the same base machine with "perhaps"
> some slight upgrade differences but have not seen these expressly
> deliniated anywhere.
> Is there a very strong reason not to consider either one as feasible?
> If not, what would be needed in setting up the 7000 to assure success?
> I have searched here and in the wide format group for info but would
> like current knowledgeable opinions if possible. (without "get a New
> printer" bias as I'm stretching here :-)) )
> Thanks.
> Duane.
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
Message: 17
Date: Thu, 26 May 2005 00:30:03 +0300
Subject: Re: Grain and Photoshop
> MS wrote:
> Doesn't an ASA 800 film give you more "noise" however it is termed, that
> say a 400 ASA
> > film?
"In principle" yes, but if you ask, doesn't Fuji NPZ 800, or Fujicolor Pro
800 Z, as it is
now called, give you more "noise" than all the 400 ASA films, "It ain't
necessarily so".
Since one should always expose for the deepest shadows, I appreciate the
speed of the film
more often than not, hand-holding my cameras in available light.
For more information. please see for eample
http://forums.photographyreview.com/showthread.php?t=8911
Ukko Heikkinen
Message: 18
Date: Wed, 25 May 2005 17:36:54 -0400
Subject: 9000 w/ Ethernet and IJC?
Can anyone tell me if IJC supports ethernet to a 9000? If not, can you tell
me where to get a USB adapter for the 9000?
Bill Morse
Digital Eye Editions
450 Harrison Ave. Studio 227
Boston, MA 02118
(617) 429-3298
http://digitaleyeeditions.com
Message: 19
Date: Wed, 25 May 2005 14:37:50 -0700
Kevin,
I've had a similar experience with Epson several years ago - not until
I threatened to post the problem on my site (30 - 50K hits/day) and
also post it on every forum I could think of did I get a response from
Epson. I flatly told them I would also sue them - and I refused to talk
to nobody but a supervisor/manager and I told him that unless they
called me the very next day I would go ahead.
They called me the next morning.
What they offer and tell you is unacceptable - you paid for one product
- you should - and must - get a similar product in return! The 1800 is
a totally different product from the 2100 - the 1800 replaces the
1280/1290.
Don't cave in!
Christer
Christer, AKA Christer Rosewell
http://www.ChristerArt.com
3.6 million visitors to date..
On May 25, 2005, at 10:49 AM,
> From: "Kevin Bell" <kevbell@...>
> Subject: The Epson R1800 is the replacement for the 2100/2200
> 2100 printer:
> thoughts this.
> Regards, Kev Bell
Message: 20
Date: Wed, 25 May 2005 14:40:19 -0700
Subject: RE: A bit OT. Mounting Prints - effect of heat on inkjet print -
any recommended
books
At 09:39 AM 5/25/2005, you wrote:
>Roy,
>I have measured test strips of MIS B&W inks before and after dry mounting
>and found no significant differences. I have the press set to 180 and use
>Seal Archival mount. I leave the prints in the press for 1 minute, but
>usually have to do more than one press per print for large prints. I do
>not
>press matte paper -- only sprayed Premium Semimatte.
>Paul
Thanks Paul
What do you do for matte?
Roy
Message: 21
Date: Wed, 25 May 2005 18:44:40 -0000
Subject: Re: Wet Mounting - What is it?
I would recommend that you go to a user group for your specific scanner - I
belong
to the Coolscan 8000-9000 yahoo group; wet mounting is talked about all the
time.
The subject comes up also on the Epson 4870/4990 group.
Wet mounting is a process used in drum scanning that has been applied to
dedicated
film scanners like the Nikon LS 8000 or flatbeds like the Epson Perfection
series.
The arguments for wet mounting are that you reduce the effects of film grain
while
minimizing dust and scatches. The evidence is difficult to show online due
to monitor
resolution - it is the kind of thing you would have to see in person.
The thing that scares me is puting flammable fluids into my only scanner,
without
enough proof that wet mounting is actually superior enough to dry. There is
also
clean-up to do afterward. Anytime you soften grain, you risk some detail
loss,
depending on how it is handled and if it matters for your subject. For me
detail is
critical, so I keep the grain.
- Troy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Marsolais"
<bob@m...>
> Thanks!
Message: 22
Date: Wed, 25 May 2005 18:16:51 -0400
Open two photographs in Photoshop, one with the foreground you want (i.e.
the one with the white sky), the other with the good sky. Make sure they're
the same size and dpi and in 8 bit mode Then take the following steps:
1. Mark the entire foreground image as a selection (Select > All).
2. Copy the foreground image (Edit > Copy).
3.Close the foreground image, the sky image should become active, if it
doesn't click on it to make it active.
4. Edit > Paste. Now you will see only the foreground image. Use the
Background Eraser tool (Eraser > Background Eraser) to erase the white sky
and you will see the sky from the sky image showing through. Use a large
eraser size until you get close to things like mountain tops, trees,
buildings, etc., then switch to a small tool when you get to those areas.
You have created two layers so when you're through flatten the image (Layers
> Flatten Layers).
I'm sure there are other, perhaps better, ways to do it and there probably
is a plug-in out there somewhere but this method is easy and works well as
long as you take some time and care to get the transition from sky to
objects (horizon line, mountain tops, trees, buildings, etc.) correct so
that there isn't a thin white line showing between them and the new sky.
Sent: Wednesday, May 25, 2005 3:21 PM
Subject: [Digital BW] white sky
Hi
Thanks for any info
Chatzebussi
page.
them short.
the membership.
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND
Yahoo! Groups Links
Message: 23
Date: Wed, 25 May 2005 18:41:35 -0400
Subject: Neutral profile goals
When creating a neutral profile, how far into the highlights do you try to
"force" neutral against a paper with brighteners.
I'm about to try making a QTR profile for my 2200 using Kirkland glossy with
UC ink, and was wondering if there was any general thoughts on this.
John
Message: 24
Date: Wed, 25 May 2005 23:41:00 -0000
Subject: Photoshop brushes and Wacom tablet
For those of you who have downloaded the Photoshop brush set from the
ZuberPhotographics web site, there is now a customized version of the
brush set designed to be used with the Wacom tablets with Touch Strip.
The download instructions include instructions for programming the
Wacom tablet so you can increase/decrease the size of a brush tip
just by sliding the Wacom pen on the Touch Strip. Your Wacom tablet
must have the Touch Strip feature for this to work.
The brush set and instructions can be found at the following url.
http://www.zuberphotographics.com/page_Downloads.htm
Thomas
Message: 25
Date: Wed, 25 May 2005 23:49:30 -0000
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
>...If I compare them with intaglio
I should have been less imprecise in my rave. I honestly don't know
what the gamut or dmax of the carbros may be. I can only say how they
looked on the wall next to traditional prints. The certainly appeared
more dramatic than even type Cs.
But I could ask Todd, he would probably know.
Also, I believe the pigments have a surface quality of their own, are
translucent (they go down in registered layers) and don't go into the
paper much.
> result either.
At this point I'm only talking subjective, I'd better be clear about that.
One point I was trying to make is that the Matte vrs Glossy may not
always equate to density range, and the experience of an impressive
gamut and dramatic density range on a beautiful paper surface is
beautiful. Hopefully something we can get to one day with inkjet.
Tyler
they are often
being updated.
unsubscribe,
please edit your Membership preferences by visiting this same page.
them short.
Hostile,
aggressive or argumentative users may be removed from the membership without
notice.
printing. Users
who persistently make off-topic posts may be removed from the membership.
guidelines, and to
abide by the actions and decisions of the group Owner and Moderators. See
"Group Topic,
YAHOO! GROUP YOU
EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL
BW, THE PRINT
YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL,
CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES
FOR LOSS OF
"OWNER" AND
POSSIBILITY OF
SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE
DIGITAL BW, THE
PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
TRANSMISSIONS OR
DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
PRINT YAHOO
GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO
GROUP.
Yahoo! Groups Links
Checked by AVG Anti-Virus.
Version: 7.0.308 / Virus Database: 266.11.16 - Release Date: 24/05/2005
page.
them short.
the membership.
Yahoo! Groups Links
