Wet Mounting - What is it?
2005-05-25 by Bob Marsolais
I know this is a bit off topic, but I saw mention earlier this week on this forum of "wet mounting" as a way of improving scanner output. What is this, how do you do it, and where can I get more information? Thanks!
2005-05-25 by Troy
I would recommend that you go to a user group for your specific scanner - I belong to the Coolscan 8000-9000 yahoo group; wet mounting is talked about all the time. The subject comes up also on the Epson 4870/4990 group. Wet mounting is a process used in drum scanning that has been applied to dedicated film scanners like the Nikon LS 8000 or flatbeds like the Epson Perfection series. The arguments for wet mounting are that you reduce the effects of film grain while minimizing dust and scatches. The evidence is difficult to show online due to monitor resolution - it is the kind of thing you would have to see in person. The thing that scares me is puting flammable fluids into my only scanner, without enough proof that wet mounting is actually superior enough to dry. There is also clean-up to do afterward. Anytime you soften grain, you risk some detail loss, depending on how it is handled and if it matters for your subject. For me detail is critical, so I keep the grain. - Troy --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Marsolais" <bob@m...> wrote:
> I know this is a bit off topic, but I saw mention earlier this week on > this forum of "wet mounting" as a way of improving scanner output. > What is this, how do you do it, and where can I get more information? > > Thanks!
2005-05-25 by Djon
1) You'll find evidence in favor of wet mounting with Nikon 8000 on the Kami website. 2) The fluids evaporate very rapidly and cleanly. 3) Wet mounting doesn't "dissolve grain," it reduces a scanner's tendency to exaggerate grain. 4) http://groups.yahoo.com/group/SCANMAX/?yguid=96117688 ... a wet mount-oriented site for flatbeds. Julio Fernandez is able to answer all questions in depth. He does sell wet mounting kits but he doesn't promote them actively on the site. Djon --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Troy" <troyb@s...> wrote: > I would recommend that you go to a user group for your specific scanner - I belong > to the Coolscan 8000-9000 yahoo group; wet mounting is talked about all the time. > The subject comes up also on the Epson 4870/4990 group. > > Wet mounting is a process used in drum scanning that has been applied to dedicated > film scanners like the Nikon LS 8000 or flatbeds like the Epson Perfection series. > > The arguments for wet mounting are that you reduce the effects of film grain while > minimizing dust and scatches. The evidence is difficult to show online due to monitor > resolution - it is the kind of thing you would have to see in person. > > The thing that scares me is puting flammable fluids into my only scanner, without > enough proof that wet mounting is actually superior enough to dry. There is also > clean-up to do afterward. Anytime you soften grain, you risk some detail loss, > depending on how it is handled and if it matters for your subject. For me detail is > critical, so I keep the grain. > > - Troy > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Marsolais" <bob@m...> > wrote: > > I know this is a bit off topic, but I saw mention earlier this week on
> > this forum of "wet mounting" as a way of improving scanner output. > > What is this, how do you do it, and where can I get more information? > > > > Thanks!
2005-05-26 by Frank Kolwicz
Regarding item #2 below: a friend has been using Kami fluid for some time on a PowerLook 3000 and I noticed a very marked hazing of the glass in the area where he normally mounted his film when it was dry. I don't know why he didn't clean it and don't remember if he ever did give a reason as this was several years ago. The haziness didn't affect the ability to make wet scans, but was quite visible when dry. As to evaporating very rapidly: I tried to use the system and found the rapid evaporation caused serious, expanding bubbles to form under the film or under the transparent cover sheet in an air conditioned house with temperatures in the 70s, but with dry conditions. I was so annoyed at the extreme fussiness that I never did get a single acceptable wet mount scan, but my friend did manage to do so. It's possible that he used a *lot* more of the expensive Kami fluid then I was trying to use, but I'm not sure; I thought that *I* was flooding the mounting area with it. If a less sensitive and easily cleanable fluid was available I would consider using wet mounting because it did make for cleaner scans, but at the time I tried the method, it was easier for me to clean up my lightly dusty scans than it was to get the wet mount to work. Frank _________________________________________________ Date: Wed, 25 May 2005 23:58:34 -0000 From: "Djon" <westsidemaurice@...> Subject: Re: Wet Mounting - What is it? 1) You'll find evidence in favor of wet mounting with Nikon 8000 on the Kami website. 2) The fluids evaporate very rapidly and cleanly.
2005-05-26 by hogarth@snappydsl.net
Frank Kolwicz wrote: > If a less sensitive and easily cleanable fluid was available I would > consider using wet mounting because it did make for cleaner scans, but at > the time I tried the method, it was easier for me to clean up my lightly > dusty scans than it was to get the wet mount to work. > > Frank There is a better alternative, IMHO. You can get Prazio anti-newton oil from Prazio in Canada: http://www.prazio.com/mounting.shtml For scanner cleanup, use their drum cleaner and scanner wipes: http://www.prazio.com/cleaning.shtml For film cleanup, use their film cleaner and scanner wipes. I've been using Prazio supplies for years for drum scanning. Works wonderfully, and it doesn't evaporate so quickly that you have trouble working with it. -- Bruce Watson
2005-05-26 by Ernst Dinkla
Frank Kolwicz wrote: >As to evaporating very rapidly: I tried to use the system and found the >rapid evaporation caused serious, expanding bubbles to form under the film >or under the transparent cover sheet in an air conditioned house with >temperatures in the 70s, but with dry conditions. I was so annoyed at the >extreme fussiness that I never did get a single acceptable wet mount scan, >but my friend did manage to do so. It's possible that he used a *lot* more >of the expensive Kami fluid then I was trying to use, but I'm not sure; I >thought that *I* was flooding the mounting area with it. > > > An extra sheet of polyester foil - PET, 0.1 mm thick and twice the size of the film you want to scan will increase the capillary force and reduce evaporation almost completely. I can leave a sandwich like that for 24 hours at room temperature and there's no air creeping in while I use a fast evaporating fluid that I even can't recommend for safety reasons but suits me well in every aspect. I can use that extra sheet several times. Most of the haze left on glass is of fingerprints etc that dissolve in the fluid, just take care that you work clean and little cleaning is needed afterwards. If you want to wet mount the film without any additional transparent material like described it becomes a problem in most cases. The 4x5 film base is too stiff and 120 film isn't flat enough for the build up of capillary force. Ernst
2005-05-26 by Bob Marsolais
Thank you everyone who responded to my post. As I said in my initial post, I know wet mounting is a bit off topic, but not knowing where to look, you pointed me in the right direction. I'll pursue this topic further in the appropriate place. Thanks again! Bob Marsolais --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Marsolais" <bob@m...> wrote: > I know this is a bit off topic, but I saw mention earlier this week on > this forum of "wet mounting" as a way of improving scanner output. > What is this, how do you do it, and where can I get more information? > > Thanks!
Ernst, I *was* using a larger transparent plastic cover sheet when I had the problems I described with the Kami fluid and I could sit there and watch the bubbles expand from around the film edges into the image area and there was no way I could get the scan done before they ruined it. This was with 220 color negatives. The cover sheet seemed to make the mounting even harder by providing that much more space in the second layer for bubbles to be trapped. How do you work out the bubbles in the first place? I tried flooding the surface with fluid and progressively laying the film in from one end (and likewise with the cover sheet), squeegeeing the layered film and cover sheet with some kind of smooth soft plastic scraper and finally flooding the entire surface of both sheets with a film of fluid. I never got rid of the bubbles, but did get them off the image area temporarily, until they crept back in as the edge bubbles expanded. I now use a ScanMultiPro and have the glass holder for flattening curled film: would you recommend using mounting fluid in that kind of holder? Frank _______________________________________________________ Date: Thu, 26 May 2005 18:55:11 +0200
From: Ernst Dinkla <E.Dinkla@...> Subject: Re: Re: Wet Mounting - What is it? An extra sheet of polyester foil - PET, 0.1 mm thick and twice the size of the film you want to scan will increase the capillary force and reduce evaporation almost completely. I can leave a sandwich like that for 24 hours at room temperature and there's no air creeping in while I use a fast evaporating fluid that I even can't recommend for safety reasons but suits me well in every aspect. I can use that extra sheet several times. Most of the haze left on glass is of fingerprints etc that dissolve in the fluid, just take care that you work clean and little cleaning is needed afterwards. If you want to wet mount the film without any additional transparent material like described it becomes a problem in most cases. The 4x5 film base is too stiff and 120 film isn't flat enough for the build up of capillary force. Ernst
Frank Kolwicz wrote: >Ernst, > >I *was* using a larger transparent plastic cover sheet when I had the >problems I described with the Kami fluid and I could sit there and watch the >bubbles expand from around the film edges into the image area and there was >no way I could get the scan done before they ruined it. This was with 220 >color negatives. > >The cover sheet seemed to make the mounting even harder by providing that >much more space in the second layer for bubbles to be trapped. > >How do you work out the bubbles in the first place? I tried flooding the >surface with fluid and progressively laying the film in from one end (and >likewise with the cover sheet), squeegeeing the layered film and cover sheet >with some kind of smooth soft plastic scraper and finally flooding the >entire surface of both sheets with a film of fluid. I never got rid of the >bubbles, but did get them off the image area temporarily, until they crept >back in as the edge bubbles expanded. > >I now use a ScanMultiPro and have the glass holder for flattening curled >film: would you recommend using mounting fluid in that kind of holder? > >Frank > Frank, I can repeat that mounting every day and I get the same results. The thinner MF film + an extra sheet of 0.1 mm PET being the best example of the long time you can keep the sandwich closed. Several scans of the same film without any air creeping in. I use a small polyethylene squeegee and an extra sheet of PET on top of the sandwich to avoid scratches on the top foil. On the Nikon 8000 wet mount carriers that I made I added small steel clamps to hold the foil so no tape has to be used. I lift that foil at the other edge, lay the film where it should be, drip the fluid with a pipet in the angle near the clamps, lower the PET foil and the squeegee pushes the fluid between the four surfaces in a few strokes. If it doesn't work in one attempt the second one will do the trick without failing. One has to keep the concept of capillary force in mind, that fluid will creep into the narrow spaces, there's no need to imitate the way you make normal sandwiches. Either your PET film reacts to the fluid, is too thick or the overlap of the foil is too small. I'm not familiar enough with the ScanMultiPro. The wet mount holders I made for the Nikon are based on the MF slide holder and have a glass area of approx. 11 x 23 cm. Sealed with polyurethane resin around the edges. That 's enough for the MF films scanned on that scanner. On the Epson 3200 I use a separate glass sheet for mounting 4x5 and the PET foil will overlap with 1.5" -2" around the film. I have PET on the roll so there's no need to check whether it is half an inch less or more. Ernst
2005-05-26 by Randy Rancier
I find using a soft rubber roller, called a brayer at art stores works very well instead of using a squeege. I put a pool of fluid on the glass, lay the film down gradually from one end of the film to the other to prevent trapping air. Then more fluid on top of the film, then the plastic overlay laid down same way as the film. Then I roll the "sandwich lightly using the roller checking for air bubbles. Afterward, wiping excess fluid off the "sandwich with lint- free dry wipes before scanning. Works like a charm! Sounds kind of complicated until you do it a few times, then it's a breeze, doesn't really add much time to my workflow Randy --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla <E.Dinkla@c...> wrote: > Frank Kolwicz wrote: > > >Ernst, > > > >I *was* using a larger transparent plastic cover sheet when I had the > >problems I described with the Kami fluid and I could sit there and watch the > >bubbles expand from around the film edges into the image area and there was > >no way I could get the scan done before they ruined it. This was with 220 > >color negatives. > > > >The cover sheet seemed to make the mounting even harder by providing that > >much more space in the second layer for bubbles to be trapped. > > > >How do you work out the bubbles in the first place? I tried flooding the > >surface with fluid and progressively laying the film in from one end (and > >likewise with the cover sheet), squeegeeing the layered film and cover sheet > >with some kind of smooth soft plastic scraper and finally flooding the > >entire surface of both sheets with a film of fluid. I never got rid of the > >bubbles, but did get them off the image area temporarily, until they crept > >back in as the edge bubbles expanded. > > > >I now use a ScanMultiPro and have the glass holder for flattening curled > >film: would you recommend using mounting fluid in that kind of holder? > > > >Frank > > > Frank, > > I can repeat that mounting every day and I get the same results. The > thinner MF film + an extra sheet of 0.1 mm PET being the best example of > the long time you can keep the sandwich closed. Several scans of the > same film without any air creeping in. I use a small polyethylene > squeegee and an extra sheet of PET on top of the sandwich to avoid > scratches on the top foil. On the Nikon 8000 wet mount carriers that I > made I added small steel clamps to hold the foil so no tape has to be > used. I lift that foil at the other edge, lay the film where it should > be, drip the fluid with a pipet in the angle near the clamps, lower the > PET foil and the squeegee pushes the fluid between the four surfaces in > a few strokes. If it doesn't work in one attempt the second one will do > the trick without failing. One has to keep the concept of capillary > force in mind, that fluid will creep into the narrow spaces, there's no > need to imitate the way you make normal sandwiches. > > Either your PET film reacts to the fluid, is too thick or the overlap of > the foil is too small. I'm not familiar enough with the ScanMultiPro. > The wet mount holders I made for the Nikon are based on the MF slide > holder and have a glass area of approx. 11 x 23 cm. Sealed with > polyurethane resin around the edges. That 's enough for the MF films > scanned on that scanner. On the Epson 3200 I use a separate glass sheet > for mounting 4x5 and the PET foil will overlap with 1.5" -2" around the > film. I have PET on the roll so there's no need to check whether it is
> half an inch less or more. > > Ernst
